[petsc-users] CHKERRQ in PETSc 3.17 Fortran
Satish Balay
balay at mcs.anl.gov
Mon Apr 18 15:35:03 CDT 2022
All CHKERRQ usages were initially removed from fortran examples
[now they are added back in main branch]
Satish
On Mon, 18 Apr 2022, Matthew Knepley wrote:
> How did any Fortran tests compile in the CI?
> Thanks,
> Matt
> On Mon, Apr 18, 2022 at 4:09 PM Satish Balay via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Its deprecated - but the removal in fortran interface was not intentional.
> > So its added in
> > https://gitlab.com/petsc/petsc/-/commit/1d07488b31e9919329a73f04131a9987c281eb5e
> > and should be in petsc-3.17.1
> > Satish
> > On Mon, 18 Apr 2022, Albert Mollen via petsc-users wrote:
> > > Hi,
> > > Our code uses PETSc in both C++ and Fortran. After updating to using
> > PETSc
> > > 3.17.0 CHKERRQ is not found when compiling the Fortran part. I see that
> > > CHKERRQ is now deprecated but is it intentional to remove it?
> > > I could easily solve it by adding
> > > #if PETSC_VERSION_GE(3,17,0)
> > > #define CHKERRQ(...) PetscCall(__VA_ARGS__)
> > > #endif
> > > Thanks
> > > Albert Mollén
> > > Associate Research Physicist
> > > Theory Department
> > > Princeton Plasma Physics Laboratory
