[petsc-users] CHKERRQ in PETSc 3.17 Fortran
Matthew Knepley
knepley at gmail.com
Mon Apr 18 15:30:22 CDT 2022
How did any Fortran tests compile in the CI?
Matt
On Mon, Apr 18, 2022 at 4:09 PM Satish Balay via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Its deprecated - but the removal in fortran interface was not intentional.
> So its added in
> https://gitlab.com/petsc/petsc/-/commit/1d07488b31e9919329a73f04131a9987c281eb5e
> and should be in petsc-3.17.1
> Satish
> On Mon, 18 Apr 2022, Albert Mollen via petsc-users wrote:
> > Hi,
> > Our code uses PETSc in both C++ and Fortran. After updating to using
> PETSc
> > 3.17.0 CHKERRQ is not found when compiling the Fortran part. I see that
> > CHKERRQ is now deprecated but is it intentional to remove it?
> > I could easily solve it by adding
> > #if PETSC_VERSION_GE(3,17,0)
> > #define CHKERRQ(...) PetscCall(__VA_ARGS__)
> > #endif
> > Thanks
> > Albert Mollén
> > Associate Research Physicist
> > Theory Department
> > Princeton Plasma Physics Laboratory
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220418/a3fb9320/attachment.html>
