[petsc-users] Starting in debugger
Sanjay Govindjee s_g at berkeley.edu
Sun Apr 17 13:58:55 CDT 2022
Codesigning is not the issue.  My gdb is properly codesigned (here are
my synopsized instructions based off the page your reference but with
out the extraneous details
http://feap.berkeley.edu/wiki/index.php?title=GDB).
I think this is one of those nutty Apple quirks.  I do notice that in
the debug windows that, if I use gdb I am just looking at hex codes for
the backtrace, whereas with lldb I can see they names of the routines.
Unfortunately, lldb does not play nice with Fortran so I need gdb.
Notwithstanding, I tried everything out a Fedora box and the debugging
worked just fine -- attached properly, symbols showing, variables are
accessible.
When I get a chance, I will try a from scratch build of gdb to see if
that helps.
Thanks again for the help.
-sanjay
On 4/17/22 8:12 AM, Barry Smith wrote:
>   Is the error of the form?
> Attaching to program:
> /Users/barrysmith/Src/petsc/src/snes/tutorials/ex19, process 79461
> Unable to find Mach task port for process-id 79461: (os/kern) failure
> (0x5).
>  (please check gdb is codesigned - see taskgated(8))
> /Users/barrysmith/79461: No such file or directory.
>  These errors have nothing to do with PETSc. It is a security feature
> of MacOS that makes it difficult to have random programs access other
> running programs.
> There are two ways around this.
> 1) codesign gdb. I found some instructions on how to give gdb the
> correct permissions. https://sourceware.org/gdb/wiki/PermissionsDarwin
> I have not followed them since they are rather convoluted; I am
> puzzled why brew doesn't automatically sign the gdb it installed.
> 2) Skip the codesigning. Just do -start_in_debugger -with-debug="sudo
> gdb" or run ./configure with --with-debugger="sudo gdb".
> When I use GDB on Mac OS 12.3.1 I get the error message from gdb
> warning: unhandled dyld version (17)
> This is because the brew gdb release has not been fully updated for
> the latest MacOS release.
> But you might not have this version of MacOS. I suggest you just try
> the -with-debug="sudo gdb" and see if it works for you before
> switching over to Linux.
>> On Apr 17, 2022, at 1:10 AM, Sanjay Govindjee <s_g at berkeley.edu> wrote:
>> Thanks Barry.
>> mpirun -n 2 myapp -start_in_debugger now starts up two Terminal
>> windows with gdb.
>> I still face issues [2] and [3], but I think I am going to move over
>> to a linux box for a bit where I can control things better.
>> -sanjay
>> On 4/16/22 8:13 PM, Barry Smith wrote:
>>>    You should be able to use -start_in_debugger -debug_terminal xterm
>>>    When I added support for Apple Terminal it seems I hardwired it
>>> only for lldb. I've attached a patch that will make it also work for
>>> gdb so that just -start_in_debugger should open Terminal windows
>>> with the gdb debugger for you.
>>>   Barry
>>>> On Apr 16, 2022, at 8:17 PM, Sanjay Govindjee <s_g at berkeley.edu> wrote:
>>>> I would like to start up some runs in the debugger and am running
>>>> into two primary issues.
>>>> (1) seem to not be able to control which debugger is used and
>>>> (2) there are errors in the start up, lastly
>>>> (3) if I do manage to start to job in the debugger (through manual
>>>> means), then running it is a bit of roulette as to if the job will
>>>> continue in the debugger.
>>>> I have petsc-3.17 built with GCC compilers and
>>>> --with-debugger=/usr/local/bin/gdb (using a patch Barry Smith
>>>> created today).
>>>> [1] When I execute "mpirun -n 2 hellow  -debugger_terminal
>>>> Terminal"   or  "mpirun -n 2 hellow -start_in_debugger gdb
>>>> -debugger_terminal Terminal".   I am getting lldb in the debugging
>>>> windows.
>>>> [2] The second problem I am seeing is that in the window where I
>>>> have run mpirun, the job exits with an mpirun message as shown.
>>>> $ mpirun -n 2 hellow -start_in_debugger gdb -debugger_terminal Terminal
>>>> mpirun has exited due to process rank 1 with PID 0 on
>>>> node Sanjays-MacBook-Pro2020 exiting improperly. There are three
>>>> reasons this could occur:
>>>> 1. this process did not call "init" before exiting, but others in
>>>> the job did. This can cause a job to hang indefinitely while it waits
>>>> for all processes to call "init". By rule, if one process calls "init",
>>>> then ALL processes must call "init" prior to termination.
>>>> 2. this process called "init", but exited without calling "finalize".
>>>> By rule, all processes that call "init" MUST call "finalize" prior to
>>>> exiting or it will be considered an "abnormal termination"
>>>> 3. this process called "MPI_Abort" or "orte_abort" and the mca
>>>> parameter
>>>> orte_create_session_dirs is set to false. In this case, the
>>>> run-time cannot
>>>> detect that the abort call was an abnormal termination. Hence, the only
>>>> error message you will receive is this one.
>>>> This may have caused other processes in the application to be
>>>> terminated by signals sent by mpirun (as reported here).
>>>> You can avoid this message by specifying -quiet on the mpirun
>>>> command line.
>>>> [3] If I just do something like "mpirun -n 5 xterm -e
>>>> /usr/local/bin/gdb hellow"; I get gdb running in xterm which is ok
>>>> to some extent, though I prefer Terminal.  However, I do run into
>>>> the problem that the order in which I issue 'run' at the (gdb)
>>>> prompt dictates if the program will launch or not.  Sometimes I
>>>> guess the order correctly and the job runs, other times it just hangs.
>>>> -sanjay
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220417/0cd3e2c8/attachment.html>
