[petsc-users] Can not understand why convert matrix type from MPIAIJ to MATIS failed.
    Junchao Zhang
    junchao.zhang at gmail.com
    Thu Apr 14 17:31:22 CDT 2022
Since you already have the test matrix, could you add "-mat_view binary" to
dump the matrix and send us the binaryoutput.* files for reproduce?
--Junchao Zhang
On Thu, Apr 14, 2022 at 10:09 AM 459543524 via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Sir, I can not understand why my convert from MPIAIJ to MATIS failed.
> I already have a matrix A, create by follow commands
> Mat A;
> MatCreateAIJ(...)
> MatSetValues(...)
> MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
> I want convert the matrix A to MATIS type for future BDDC operation, as
> advised by ex 72.
> Mat J;
> MatConvert(A, MATIS, MAT_INITIAL_MATRIX, &J);
> The command failed with the stacktrace
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Argument out of range
> [0]PETSC ERROR: Scatter indices in ix are out of range
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.15.4, Sep 01, 2021
> [0]PETSC ERROR: Unknown Name on a  named xuhui-Office by xuhui Thu Apr 14
> 23:06:08 2022
> [0]PETSC ERROR: Configure options --prefix=/opt/petsc/debug_int64
> --download-mumps --download-scalapack --download-superlu_dist
> --download-parmetis --download-metis --with-64-bit-indices=1
> [0]PETSC ERROR: #1 VecScatterCreate() at
> /home/xuhui/Temp/petsc-3.15.4/src/vec/is/sf/interface/vscat.c:767
> [0]PETSC ERROR: #2 MatISSetUpScatters_Private() at
> /home/xuhui/Temp/petsc-3.15.4/src/mat/impls/is/matis.c:2403
> [0]PETSC ERROR: #3 MatSetLocalToGlobalMapping_IS() at
> /home/xuhui/Temp/petsc-3.15.4/src/mat/impls/is/matis.c:2501
> [0]PETSC ERROR: #4 MatSetLocalToGlobalMapping() at
> /home/xuhui/Temp/petsc-3.15.4/src/mat/interface/matrix.c:2093
> [0]PETSC ERROR: #5 MatConvert_XAIJ_IS() at
> /home/xuhui/Temp/petsc-3.15.4/src/mat/impls/is/matis.c:651
> [0]PETSC ERROR: #6 MatConvert() at
> /home/xuhui/Temp/petsc-3.15.4/src/mat/interface/matrix.c:4439
> ^C[mpiexec at xuhui-Office] Sending Ctrl-C to processes as requested
> I have no idea why this happen. Thanks for your time.
> Further information:
> The matrix A is distributed on 4 processes.
> We can view the matrix as follows:
> Mat Object: 4 MPI processes
>   type: mpiaij
> row 0: (0, 168.75)  (1, 0.)  (2, 0.)  (3, 0.)  (4, 0.)  (5, 0.)  (6, 0.)
> (7, 0.)
> row 1: (0, 0.)  (1, 168.75)  (2, 0.)  (3, 0.)  (4, 0.)  (5, 0.)  (6, 0.)
> (7, 0.)
> row 2: (0, 0.)  (1, 0.)  (2, 168.75)  (3, 0.)  (6, 0.)  (7, 0.)  (8, 0.)
> (9, 0.)  (12, 0.)  (13, 0.)
> row 3: (0, 0.)  (1, 0.)  (2, 0.)  (3, 168.75)  (6, 0.)  (7, 0.)  (8, 0.)
> row 4: (0, 0.)  (1, 0.)  (4, 150.)  (5, -25.)  (6, -100.)  (7, 25.)  (16,
> -25.)  (17, 25.)  (18, 0.)  (19, -25.)
> row 5: (0, 0.)  (1, 0.)  (4, -25.)  (5, 150.)  (6, 25.)  (7, -50.)  (16,
> 0.)  (17, -50.)  (18, -25.)  (19, 0.)
> row 6: (0, 0.)  (1, 0.)  (2, 0.)  (3, 0.)  (4, -100.)  (5, 25.)  (6,
> 300.)  (7, -50.)  (12, -100.)  (13, 25.)  (18, -50.)  (19, 25.)  (24, 0.)
> (25, -25.)
> row 7: (0, 0.)  (1, 0.)  (2, 0.)  (3, 0.)  (4, 25.)  (5, -50.)  (6, -50.)
> (7, 300.)  (12, 25.)  (13, -50.)  (18, 25.)  (19, -100.)  (24, -25.)  (25,
> 0.)
> row 8: (2, 0.)  (3, 0.)  (8, 150.)  (9, 0.)  (10, 0.)  (11, 0.)  (12, 0.)
> (13, 0.)  (14, 0.)  (15, 0.)
> row 9: (2, 0.)  (3, 0.)  (8, 0.)  (9, 150.)  (10, 0.)  (11, 0.)  (12, 0.)
> row 10: (8, 0.)  (9, 0.)  (10, 150.)  (11, 0.)  (14, 0.)  (15, 0.)
> row 11: (8, 0.)  (9, 0.)  (10, 0.)  (11, 150.)  (14, 0.)  (15, 0.)
> row 12: (2, 0.)  (3, 0.)  (6, -100.)  (7, 25.)  (8, 0.)  (9, 0.)  (12,
> 300.)  (13, -50.)  (14, -100.)  (15, 25.)  (24, -50.)  (25, 25.)  (26, 0.)
> (27, -25.)
> row 13: (2, 0.)  (3, 0.)  (6, 25.)  (7, -50.)  (8, 0.)  (9, 0.)  (12,
> -50.)  (13, 300.)  (14, 25.)  (15, -50.)  (24, 25.)  (25, -100.)  (26,
> -25.)  (27, 0.)
> row 14: (8, 0.)  (9, 0.)  (10, 0.)  (11, 0.)  (12, -100.)  (13, 25.)  (14,
> 150.)  (15, -25.)  (26, -25.)  (27, 0.)
> row 15: (8, 0.)  (9, 0.)  (10, 0.)  (11, 0.)  (12, 25.)  (13, -50.)  (14,
> -25.)  (15, 150.)  (26, 25.)  (27, -50.)
> row 16: (4, -25.)  (5, 0.)  (16, 150.)  (17, -25.)  (18, -100.)  (19,
> 25.)  (20, -25.)  (21, 25.)  (22, 0.)  (23, -25.)
> row 17: (4, 25.)  (5, -50.)  (16, -25.)  (17, 150.)  (18, 25.)  (19,
> -50.)  (20, 0.)  (21, -50.)  (22, -25.)  (23, 0.)
> row 18: (4, 0.)  (5, -25.)  (6, -50.)  (7, 25.)  (16, -100.)  (17, 25.)
> (18, 300.)  (19, -50.)  (22, -50.)  (23, 25.)  (24, -100.)  (25, 25.)  (28,
> 0.)  (29, -25.)
> row 19: (4, -25.)  (5, 0.)  (6, 25.)  (7, -100.)  (16, 25.)  (17, -50.)
> (18, -50.)  (19, 300.)  (22, 25.)  (23, -100.)  (24, 25.)  (25, -50.)  (28,
> -25.)  (29, 0.)
> row 20: (16, -25.)  (17, 0.)  (20, 75.)  (21, -25.)  (22, -50.)  (23, 25.)
> row 21: (16, 25.)  (17, -50.)  (20, -25.)  (21, 75.)  (22, 0.)  (23, -25.)
> row 22: (16, 0.)  (17, -25.)  (18, -50.)  (19, 25.)  (20, -50.)  (21, 0.)
> (22, 150.)  (23, -25.)  (28, -50.)  (29, 25.)
> row 23: (16, -25.)  (17, 0.)  (18, 25.)  (19, -100.)  (20, 25.)  (21,
> -25.)  (22, -25.)  (23, 150.)  (28, 0.)  (29, -25.)
> row 24: (6, 0.)  (7, -25.)  (12, -50.)  (13, 25.)  (18, -100.)  (19, 25.)
> (24, 300.)  (25, -50.)  (26, -100.)  (27, 25.)  (28, -50.)  (29, 25.)  (30,
> 0.)  (31, -25.)
> row 25: (6, -25.)  (7, 0.)  (12, 25.)  (13, -100.)  (18, 25.)  (19, -50.)
> (24, -50.)  (25, 300.)  (26, 25.)  (27, -50.)  (28, 25.)  (29, -100.)  (30,
> -25.)  (31, 0.)
> row 26: (12, 0.)  (13, -25.)  (14, -25.)  (15, 25.)  (24, -100.)  (25,
> 25.)  (26, 150.)  (27, -25.)  (30, -25.)  (31, 0.)
> row 27: (12, -25.)  (13, 0.)  (14, 0.)  (15, -50.)  (24, 25.)  (25, -50.)
> (26, -25.)  (27, 150.)  (30, 25.)  (31, -50.)
> row 28: (18, 0.)  (19, -25.)  (22, -50.)  (23, 0.)  (24, -50.)  (25, 25.)
> (28, 150.)  (29, -25.)  (30, -50.)  (31, 25.)
> row 29: (18, -25.)  (19, 0.)  (22, 25.)  (23, -25.)  (24, 25.)  (25,
> -100.)  (28, -25.)  (29, 150.)  (30, 0.)  (31, -25.)
> row 30: (24, 0.)  (25, -25.)  (26, -25.)  (27, 25.)  (28, -50.)  (29, 0.)
> (30, 75.)  (31, 0.)
> row 31: (24, -25.)  (25, 0.)  (26, 0.)  (27, -50.)  (28, 25.)  (29, -25.)
> (30, 0.)  (31, 75.)
> 徐辉,Xu Hui
> 清华大学航天航空学院博士研究生
> PhD Candidate, School of Aerospace Engineering
> Tsinghua University
> Tel: 188-1152-7137
> Mail:459543524 at qq.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220414/dc9ed4ac/attachment.html>
