[petsc-users] What does PCASMSetOverlap do?
Matthew Knepley
knepley at gmail.com
Thu Apr 14 07:56:22 CDT 2022
On Thu, Apr 14, 2022 at 8:30 AM Zhuo Chen <chenzhuotj at gmail.com> wrote:
> Hi Pierre,
> Thank you so much! It helps a lot! Petsc correctly identifies the
> neighboring cells and the geometry is quite complicated as shown below.
> [image: dd.png]
> I guess Petsc identifies the non-zero off-diagonal rows and columns and
> marks them as the 1 layer overlap region. For more layers, one needs the
> off-diagonal information of A*A (I am solving Ax=b), is that correct?
For more layers, you are just doing Breadth First Search in the matrix
graph.
Matt
> Best regards.
> On Thu, Apr 14, 2022 at 6:44 PM Pierre Jolivet <pierre at joliv.et> wrote:
>> On 14 Apr 2022, at 12:16 PM, Zhuo Chen <chenzhuotj at gmail.com> wrote:
>> Hi Matt and Pierre,
>> Thank you very much for your help. I indeed want to solve a 2D problem
>> with geometric block domain decomposition and the blocks are in the Hilbert
>> space curve ordering. Each block may have 32x32 cells.
>> I am a Fortran user and I apologize that I do not know how to use
>> -pc_asm_print_subdomains.
>> You can just put this on your command line. For example,
>> $ cd ${PETSC_DIR}/src/ksp/ksp/tutorials && make ex2f && mpirun -n 2
>> ./ex2f -pc_type asm -pc_asm_print_subdomains
>> [0:2] Subdomain 0 with overlap:
>> 0 1 2 3 4
>> [1:2] Subdomain 0 with overlap:
>> 5 6 7 8
>> Norm of error 0.1205E-04 iterations 4
>> Should I use call PetscOptionsGetBool(NULL, NULL,
>> "-pc_asm_print_subdomains", .true., NULL, ierr)? It would be great if you
>> can point me to the right tutorial.
>> You could also use the following line of code:
>> call
>> PetscOptionsInsertString(PETSC_NULL_OPTIONS,'-pc_asm_print_subdomains',ierr)
>> After reading some example programs, I would like to know if it is
>> possible to use
>> IS, allocatable, dimension(:) :: is1,is2
>> integer :: nlocalblk
>> call PCASMGetLocalSubdomains(pc,nlocalblk,is1,is2,ierr)
>> call ISView(is1,PETSC_VIEWER_STDOUT_SELF,ierr)
>> call ISView(is2,PETSC_VIEWER_STDOUT_SELF,ierr)
>> to realize the function you have mentioned.
>> That is another way to do it, yes.
>> In fact, for debugging purposes, I’d advise that you use GASM instead of
>> ASM because it prints slightly more coherent information.
>> E.g., with PCASM, the above log shows that the displayed information is
>> _wrong_. These are not the subdomains with overlap, but the subdomains
>> _without_ overlap.
>> Furthermore, if you increase -pc_asm_overlap, you’ll still get the same
>> subdomains.
>> $ mpirun -n 2 ./ex2f -pc_type asm -pc_asm_overlap 4
>> 0 1 2 3 4
>> 5 6 7 8
>> Norm of error 0.1192E-05 iterations 4
>> On the contrary, with PCGASM, you get the proper subdomains with and
>> without overlap.
>> $ mpirun -n 2 ./ex2f -pc_type gasm -pc_gasm_print_subdomains
>> Inner subdomain:
>> 0 1 2 3 4
>> Outer subdomain:
>> 0 1 2 3 4
>> Inner subdomain:
>> 5 6 7 8
>> Outer subdomain:
>> 5 6 7 8
>> -pc_gasm_overlap 4
>> Inner subdomain:
>> 0 1 2 3 4
>> Outer subdomain:
>> 0 1 2 3 4 5 6 7 8
>> Inner subdomain:
>> 5 6 7 8
>> Outer subdomain:
>> 0 1 2 3 4 5 6 7 8
>> Thanks,
>> Pierre
>> Thank you very much!
>> On Wed, Apr 13, 2022 at 10:18 PM Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>> Thank you, Pierre!
>>> On Wed, Apr 13, 2022 at 10:05 PM Pierre Jolivet <pierre at joliv.et> wrote:
>>>> You can also use the uncommented option -pc_asm_print_subdomains which
>>>> will, as Matt told you, show you that it is exactly the same algorithm.
>>>> Thanks,
>>>> Pierre
>>>> On 13 Apr 2022, at 3:58 PM, Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>>> Thank you, Matt! I will do that.
>>>> On Wed, Apr 13, 2022 at 9:55 PM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Wed, Apr 13, 2022 at 9:53 AM Zhuo Chen <chenzhuotj at gmail.com>
>>>>> wrote:
>>>>>> Dear Pierre,
>>>>>> Thank you! I looked into the webpage you sent me and I think it is
>>>>>> not the situation that I am talking about.
>>>>>> I think I need to attach a figure for an illustrative purpose. This
>>>>>> figure is Figure 14.5 of "Iterative Method for Sparse Linear Systems" by
>>>>>> Saad.
>>>>>> <domaindecompostion.png>
>>>>>> If I divide the domain into these three subdomains, as you can see,
>>>>>> the middle block has two interfaces. In the matrix form, its rows are not
>>>>>> contiguous, i.e., distributed in different processors. If ASM only expands
>>>>>> in the contiguous direction, the domain decomposition become ineffective, I
>>>>>> guess.
>>>>> No, we get exactly this picture. Saad is talking about exactly the
>>>>> algorithm we use.
>>>>> Maybe you should just look at the subdomains being produced, -mat_view
>>>>> draw -draw_pause 3
>>>>> Matt
>>>>>> On Wed, Apr 13, 2022 at 9:36 PM Pierre Jolivet <pierre at joliv.et>
>>>>>> wrote:
>>>>>>> On 13 Apr 2022, at 3:30 PM, Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>>>>>> Dear Matthew and Mark,
>>>>>>> Thank you very much for the reply! Much appreciated!
>>>>>>> The question was about a 1D problem. I think I should say core 1 has
>>>>>>> row 1:32 instead of 1:32, 1:32 as it might be confusing.
>>>>>>> So the overlap is extended to both directions for the middle
>>>>>>> processor but only toward the increasing direction for the first processor
>>>>>>> and the decreasing direction for the last processor. In 1D, this makes
>>>>>>> sense as the domain is contiguous. However, in 2D with domain decomposition
>>>>>>> with spacial overlaps, this overlapping would not work as one subdomain can
>>>>>>> have several neighbor domains. Mark mentioned generalized ASM, is that the
>>>>>>> correct direction that I should look for?
>>>>>>> What is it that you want to do exactly?
>>>>>>> If you are using a standard discretisation kernel, e.g., piecewise
>>>>>>> linear finite elements, MatIncreaseOverlap() called by PCASM will generate
>>>>>>> an overlap algebraically which is equivalent to the overlap you would have
>>>>>>> gotten geometrically.
>>>>>>> If you know that “geometric” overlap (or want to use a custom
>>>>>>> definition of overlap), you could use
>>>>>>> https://petsc.org/release/docs/manualpages/PC/PCASMSetLocalSubdomains.html
>>>>>>> Thanks,
>>>>>>> Pierre
>>>>>>> Best regards.
>>>>>>> On Wed, Apr 13, 2022 at 9:14 PM Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Wed, Apr 13, 2022 at 9:11 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>>> On Wed, Apr 13, 2022 at 8:56 AM Matthew Knepley <knepley at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> On Wed, Apr 13, 2022 at 6:42 AM Mark Adams <mfadams at lbl.gov>
>>>>>>>>>> wrote:
>>>>>>>>>>> No, without overlap you have, let say:
>>>>>>>>>>> core 1: 1:32, 1:32
>>>>>>>>>>> core 2: 33:64, 33:64
>>>>>>>>>>> Overlap will increase the size of each domain so you get:
>>>>>>>>>>> core 1: 1:33, 1:33
>>>>>>>>>>> core 2: 32:65, 32:65
>>>>>>>>>> I do not think this is correct. Here is the algorithm. Imagine
>>>>>>>>>> the matrix is a large graph. When you divide rows, you
>>>>>>>>>> can think of that as dividing the vertices into sets. If overlap
>>>>>>>>>> = 1, it means start with my vertex set, and add all vertices
>>>>>>>>>> that are just 1 edge away from my set.
>>>>>>>>> I think that is what was said. You increase each subdomain by one
>>>>>>>>> row of vertices.
>>>>>>>>> So in 1D, vertex 32 and 33 are in both subdomains and you have an
>>>>>>>>> overlap region of size 2.
>>>>>>>>> They want an overlap region of size 1, vertex 33.
>>>>>>>> This is true, but I did not think they specified a 1D mesh.
>>>>>>>> Matt
>>>>>>>>>> Thanks,
>>>>>>>>>> Matt
>>>>>>>>>>> What you want is reasonable but requires PETSc to pick a
>>>>>>>>>>> separator set, which is not well defined.
>>>>>>>>>>> You need to build that yourself with gasm (I think) if you want
>>>>>>>>>>> this.
>>>>>>>>>>> Mark
>>>>>>>>>>> On Wed, Apr 13, 2022 at 3:17 AM Zhuo Chen <chenzhuotj at gmail.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> I hope that everything is going well with everybody.
>>>>>>>>>>>> I have a question about the PCASMSetOverlap. If I have a
>>>>>>>>>>>> 128x128 matrix and I use 4 cores with overlap=1. Does it mean that from
>>>>>>>>>>>> core 1 to core 4, the block ranges are (starting from 1):
>>>>>>>>>>>> core 1: 1:33, 1:33
>>>>>>>>>>>> core 2: 33:65, 33:65
>>>>>>>>>>>> core 3: 65:97, 65:97
>>>>>>>>>>>> core 4: 95:128, 95:128
>>>>>>>>>>>> Or is it something else? I cannot tell from the manual.
>>>>>>>>>>>> Many thanks in advance.
>>>>>>>>>>>> Zhuo Chen
>>>>>>>>>>>> Department of Astronomy
>>>>>>>>>>>> Tsinghua University
>>>>>>>>>>>> Beijing, China 100084
>>>>>>>>>>>> *https://czlovemath123.github.io/
>>>>>>>>>>>> <https://czlovemath123.github.io/>*
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> Zhuo Chen
>>>>>>> Tsinghua University
>>>>>>> *https://czlovemath123.github.io/ <https://czlovemath123.github.io/>*
>>>>>> Zhuo Chen
>>>>>> Tsinghua University
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> Zhuo Chen
>>>> Tsinghua University
>>> Zhuo Chen
>>> Tsinghua University
>> Zhuo Chen
>> Tsinghua University
> Zhuo Chen
> Tsinghua University
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220414/fbfd7187/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220414/fbfd7187/attachment-0001.png>
