[petsc-users] What does PCASMSetOverlap do?
Zhuo Chen chenzhuotj at gmail.com
Thu Apr 14 07:30:21 CDT 2022
Hi Pierre,
Thank you so much! It helps a lot! Petsc correctly identifies the
neighboring cells and the geometry is quite complicated as shown below.
[image: dd.png]
I guess Petsc identifies the non-zero off-diagonal rows and columns and
marks them as the 1 layer overlap region. For more layers, one needs the
off-diagonal information of A*A (I am solving Ax=b), is that correct?
Best regards.
On Thu, Apr 14, 2022 at 6:44 PM Pierre Jolivet <pierre at joliv.et> wrote:
> On 14 Apr 2022, at 12:16 PM, Zhuo Chen <chenzhuotj at gmail.com> wrote:
> Hi Matt and Pierre,
> Thank you very much for your help. I indeed want to solve a 2D problem
> with geometric block domain decomposition and the blocks are in the Hilbert
> space curve ordering. Each block may have 32x32 cells.
> I am a Fortran user and I apologize that I do not know how to use
> -pc_asm_print_subdomains.
> You can just put this on your command line. For example,
> $ cd ${PETSC_DIR}/src/ksp/ksp/tutorials && make ex2f && mpirun -n 2 ./ex2f
> -pc_type asm -pc_asm_print_subdomains
> [0:2] Subdomain 0 with overlap:
> 0 1 2 3 4
> [1:2] Subdomain 0 with overlap:
> 5 6 7 8
> Norm of error  0.1205E-04 iterations     4
> Should I use call PetscOptionsGetBool(NULL, NULL,
> "-pc_asm_print_subdomains", .true., NULL, ierr)? It would be great if you
> can point me to the right tutorial.
> You could also use the following line of code:
>       call
> PetscOptionsInsertString(PETSC_NULL_OPTIONS,'-pc_asm_print_subdomains',ierr)
> After reading some example programs, I would like to know if it is
> possible to use
> IS, allocatable, dimension(:) :: is1,is2
> integer :: nlocalblk
> call PCASMGetLocalSubdomains(pc,nlocalblk,is1,is2,ierr)
> call ISView(is1,PETSC_VIEWER_STDOUT_SELF,ierr)
> call ISView(is2,PETSC_VIEWER_STDOUT_SELF,ierr)
> to realize the function you have mentioned.
> That is another way to do it, yes.
> In fact, for debugging purposes, I’d advise that you use GASM instead of
> ASM because it prints slightly more coherent information.
> E.g., with PCASM, the above log shows that the displayed information is
> _wrong_. These are not the subdomains with overlap, but the subdomains
> _without_ overlap.
> Furthermore, if you increase -pc_asm_overlap, you’ll still get the same
> subdomains.
> $ mpirun -n 2 ./ex2f -pc_type asm -pc_asm_overlap 4
> 0 1 2 3 4
> 5 6 7 8
> Norm of error  0.1192E-05 iterations     4
> On the contrary, with PCGASM, you get the proper subdomains with and
> without overlap.
> $ mpirun -n 2 ./ex2f -pc_type gasm -pc_gasm_print_subdomains
> Inner subdomain:
> 0 1 2 3 4
> Outer subdomain:
> 0 1 2 3 4
> Inner subdomain:
> 5 6 7 8
> Outer subdomain:
> 5 6 7 8
> -pc_gasm_overlap 4
> Inner subdomain:
> 0 1 2 3 4
> Outer subdomain:
> 0 1 2 3 4 5 6 7 8
> Inner subdomain:
> 5 6 7 8
> Outer subdomain:
> 0 1 2 3 4 5 6 7 8
> Thanks,
> Pierre
> Thank you very much!
> On Wed, Apr 13, 2022 at 10:18 PM Zhuo Chen <chenzhuotj at gmail.com> wrote:
>> Thank you, Pierre!
>> On Wed, Apr 13, 2022 at 10:05 PM Pierre Jolivet <pierre at joliv.et> wrote:
>>> You can also use the uncommented option -pc_asm_print_subdomains which
>>> will, as Matt told you, show you that it is exactly the same algorithm.
>>> Thanks,
>>> Pierre
>>> On 13 Apr 2022, at 3:58 PM, Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>> Thank you, Matt! I will do that.
>>> On Wed, Apr 13, 2022 at 9:55 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Wed, Apr 13, 2022 at 9:53 AM Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>>>> Dear Pierre,
>>>>> Thank you! I looked into the webpage you sent me and I think it is not
>>>>> the situation that I am talking about.
>>>>> I think I need to attach a figure for an illustrative purpose. This
>>>>> figure is Figure 14.5 of "Iterative Method for Sparse Linear Systems" by
>>>>> Saad.
>>>>> <domaindecompostion.png>
>>>>> If I divide the domain into these three subdomains, as you can see,
>>>>> the middle block has two interfaces. In the matrix form, its rows are not
>>>>> contiguous, i.e., distributed in different processors. If ASM only expands
>>>>> in the contiguous direction, the domain decomposition become ineffective, I
>>>>> guess.
>>>> No, we get exactly this picture. Saad is talking about exactly the
>>>> algorithm we use.
>>>> Maybe you should just look at the subdomains being produced, -mat_view
>>>> draw -draw_pause 3
>>>>    Matt
>>>>> On Wed, Apr 13, 2022 at 9:36 PM Pierre Jolivet <pierre at joliv.et>
>>>>> wrote:
>>>>>> On 13 Apr 2022, at 3:30 PM, Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>>>>> Dear Matthew and Mark,
>>>>>> Thank you very much for the reply! Much appreciated!
>>>>>> The question was about a 1D problem. I think I should say core 1 has
>>>>>> row 1:32 instead of 1:32, 1:32 as it might be confusing.
>>>>>> So the overlap is extended to both directions for the middle
>>>>>> processor but only toward the increasing direction for the first processor
>>>>>> and the decreasing direction for the last processor. In 1D, this makes
>>>>>> sense as the domain is contiguous. However, in 2D with domain decomposition
>>>>>> with spacial overlaps, this overlapping would not work as one subdomain can
>>>>>> have several neighbor domains. Mark mentioned generalized ASM, is that the
>>>>>> correct direction that I should look for?
>>>>>> What is it that you want to do exactly?
>>>>>> If you are using a standard discretisation kernel, e.g., piecewise
>>>>>> linear finite elements, MatIncreaseOverlap() called by PCASM will generate
>>>>>> an overlap algebraically which is equivalent to the overlap you would have
>>>>>> gotten geometrically.
>>>>>> If you know that “geometric” overlap (or want to use a custom
>>>>>> definition of overlap), you could use
>>>>>> https://petsc.org/release/docs/manualpages/PC/PCASMSetLocalSubdomains.html
>>>>>> Thanks,
>>>>>> Pierre
>>>>>> Best regards.
>>>>>> On Wed, Apr 13, 2022 at 9:14 PM Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Wed, Apr 13, 2022 at 9:11 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> On Wed, Apr 13, 2022 at 8:56 AM Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Wed, Apr 13, 2022 at 6:42 AM Mark Adams <mfadams at lbl.gov>
>>>>>>>>> wrote:
>>>>>>>>>> No, without overlap you have, let say:
>>>>>>>>>> core 1:   1:32, 1:32
>>>>>>>>>> core 2:   33:64,  33:64
>>>>>>>>>> Overlap will increase the size of each domain so you get:
>>>>>>>>>> core 1:   1:33, 1:33
>>>>>>>>>> core 2:   32:65,  32:65
>>>>>>>>> I do not think this is correct. Here is the algorithm. Imagine the
>>>>>>>>> matrix is a large graph. When you divide rows, you
>>>>>>>>> can think of that as dividing the vertices into sets. If overlap =
>>>>>>>>> 1, it means start with my vertex set, and add all vertices
>>>>>>>>> that are just 1 edge away from my set.
>>>>>>>> I think that is what was said. You increase each subdomain by one
>>>>>>>> row of vertices.
>>>>>>>> So in 1D, vertex 32 and 33 are in both subdomains and you have an
>>>>>>>> overlap region of size 2.
>>>>>>>> They want an overlap region of size 1, vertex 33.
>>>>>>> This is true, but I did not think they specified a 1D mesh.
>>>>>>>   Matt
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> What you want is reasonable but requires PETSc to pick a
>>>>>>>>>> separator set, which is not well defined.
>>>>>>>>>> You need to build that yourself with gasm (I think) if you want
>>>>>>>>>> this.
>>>>>>>>>> Mark
>>>>>>>>>> On Wed, Apr 13, 2022 at 3:17 AM Zhuo Chen <chenzhuotj at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> I hope that everything is going well with everybody.
>>>>>>>>>>> I have a question about the PCASMSetOverlap. If I have a 128x128
>>>>>>>>>>> matrix and I use 4 cores with overlap=1. Does it mean that from core 1 to
>>>>>>>>>>> core 4, the block ranges are (starting from 1):
>>>>>>>>>>> core 1:   1:33, 1:33
>>>>>>>>>>> core 2:   33:65,  33:65
>>>>>>>>>>> core 3:   65:97,  65:97
>>>>>>>>>>> core 4:   95:128, 95:128
>>>>>>>>>>> Or is it something else? I cannot tell from the manual.
>>>>>>>>>>> Many thanks in advance.
>>>>>>>>>>> Zhuo Chen
>>>>>>>>>>> Department of Astronomy
>>>>>>>>>>> Tsinghua University
>>>>>>>>>>> Beijing, China 100084
>>>>>>>>>>> *https://czlovemath123.github.io/
>>>>>>>>>>> <https://czlovemath123.github.io/>*
>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> Zhuo Chen
>>>>>> Tsinghua University
>>>>>> *https://czlovemath123.github.io/ <https://czlovemath123.github.io/>*
>>>>> Zhuo Chen
>>>>> Tsinghua University
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Zhuo Chen
>>> Tsinghua University
>> Zhuo Chen
>> Tsinghua University
> Zhuo Chen
> Tsinghua University
Zhuo Chen
Tsinghua University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220414/d7e41838/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220414/d7e41838/attachment-0001.png>
