[petsc-users] What does PCASMSetOverlap do?
    Zhuo Chen
    chenzhuotj at gmail.com
    Thu Apr 14 05:16:02 CDT 2022
Hi Matt and Pierre,
Thank you very much for your help. I indeed want to solve a 2D problem with
geometric block domain decomposition and the blocks are in the Hilbert
space curve ordering. Each block may have 32x32 cells.
I am a Fortran user and I apologize that I do not know how to use
-pc_asm_print_subdomains. Should I use call PetscOptionsGetBool(NULL, NULL,
"-pc_asm_print_subdomains", .true., NULL, ierr)? It would be great if you
can point me to the right tutorial.
After reading some example programs, I would like to know if it is possible
to use
IS, allocatable, dimension(:) :: is1,is2
integer :: nlocalblk
call PCASMGetLocalSubdomains(pc,nlocalblk,is1,is2,ierr)
call ISView(is1,PETSC_VIEWER_STDOUT_SELF,ierr)
call ISView(is2,PETSC_VIEWER_STDOUT_SELF,ierr)
to realize the function you have mentioned.
Thank you very much!
On Wed, Apr 13, 2022 at 10:18 PM Zhuo Chen <chenzhuotj at gmail.com> wrote:
> Thank you, Pierre!
> On Wed, Apr 13, 2022 at 10:05 PM Pierre Jolivet <pierre at joliv.et> wrote:
>> You can also use the uncommented option -pc_asm_print_subdomains which
>> will, as Matt told you, show you that it is exactly the same algorithm.
>> Thanks,
>> Pierre
>> On 13 Apr 2022, at 3:58 PM, Zhuo Chen <chenzhuotj at gmail.com> wrote:
>> Thank you, Matt! I will do that.
>> On Wed, Apr 13, 2022 at 9:55 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Wed, Apr 13, 2022 at 9:53 AM Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>>> Dear Pierre,
>>>> Thank you! I looked into the webpage you sent me and I think it is not
>>>> the situation that I am talking about.
>>>> I think I need to attach a figure for an illustrative purpose. This
>>>> figure is Figure 14.5 of "Iterative Method for Sparse Linear Systems" by
>>>> Saad.
>>>> <domaindecompostion.png>
>>>> If I divide the domain into these three subdomains, as you can see, the
>>>> middle block has two interfaces. In the matrix form, its rows are not
>>>> contiguous, i.e., distributed in different processors. If ASM only expands
>>>> in the contiguous direction, the domain decomposition become ineffective, I
>>>> guess.
>>> No, we get exactly this picture. Saad is talking about exactly the
>>> algorithm we use.
>>> Maybe you should just look at the subdomains being produced, -mat_view
>>> draw -draw_pause 3
>>>    Matt
>>>> On Wed, Apr 13, 2022 at 9:36 PM Pierre Jolivet <pierre at joliv.et> wrote:
>>>>> On 13 Apr 2022, at 3:30 PM, Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>>>> Dear Matthew and Mark,
>>>>> Thank you very much for the reply! Much appreciated!
>>>>> The question was about a 1D problem. I think I should say core 1 has
>>>>> row 1:32 instead of 1:32, 1:32 as it might be confusing.
>>>>> So the overlap is extended to both directions for the middle processor
>>>>> but only toward the increasing direction for the first processor and the
>>>>> decreasing direction for the last processor. In 1D, this makes sense as the
>>>>> domain is contiguous. However, in 2D with domain decomposition with spacial
>>>>> overlaps, this overlapping would not work as one subdomain can have several
>>>>> neighbor domains. Mark mentioned generalized ASM, is that the correct
>>>>> direction that I should look for?
>>>>> What is it that you want to do exactly?
>>>>> If you are using a standard discretisation kernel, e.g., piecewise
>>>>> linear finite elements, MatIncreaseOverlap() called by PCASM will generate
>>>>> an overlap algebraically which is equivalent to the overlap you would have
>>>>> gotten geometrically.
>>>>> If you know that “geometric” overlap (or want to use a custom
>>>>> definition of overlap), you could use
>>>>> https://petsc.org/release/docs/manualpages/PC/PCASMSetLocalSubdomains.html
>>>>> Thanks,
>>>>> Pierre
>>>>> Best regards.
>>>>> On Wed, Apr 13, 2022 at 9:14 PM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Wed, Apr 13, 2022 at 9:11 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> On Wed, Apr 13, 2022 at 8:56 AM Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Wed, Apr 13, 2022 at 6:42 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>>> No, without overlap you have, let say:
>>>>>>>>> core 1:   1:32, 1:32
>>>>>>>>> core 2:   33:64,  33:64
>>>>>>>>> Overlap will increase the size of each domain so you get:
>>>>>>>>> core 1:   1:33, 1:33
>>>>>>>>> core 2:   32:65,  32:65
>>>>>>>> I do not think this is correct. Here is the algorithm. Imagine the
>>>>>>>> matrix is a large graph. When you divide rows, you
>>>>>>>> can think of that as dividing the vertices into sets. If overlap =
>>>>>>>> 1, it means start with my vertex set, and add all vertices
>>>>>>>> that are just 1 edge away from my set.
>>>>>>> I think that is what was said. You increase each subdomain by one
>>>>>>> row of vertices.
>>>>>>> So in 1D, vertex 32 and 33 are in both subdomains and you have an
>>>>>>> overlap region of size 2.
>>>>>>> They want an overlap region of size 1, vertex 33.
>>>>>> This is true, but I did not think they specified a 1D mesh.
>>>>>>   Matt
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> What you want is reasonable but requires PETSc to pick a separator
>>>>>>>>> set, which is not well defined.
>>>>>>>>> You need to build that yourself with gasm (I think) if you want
>>>>>>>>> this.
>>>>>>>>> Mark
>>>>>>>>> On Wed, Apr 13, 2022 at 3:17 AM Zhuo Chen <chenzhuotj at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> I hope that everything is going well with everybody.
>>>>>>>>>> I have a question about the PCASMSetOverlap. If I have a 128x128
>>>>>>>>>> matrix and I use 4 cores with overlap=1. Does it mean that from core 1 to
>>>>>>>>>> core 4, the block ranges are (starting from 1):
>>>>>>>>>> core 1:   1:33, 1:33
>>>>>>>>>> core 2:   33:65,  33:65
>>>>>>>>>> core 3:   65:97,  65:97
>>>>>>>>>> core 4:   95:128, 95:128
>>>>>>>>>> Or is it something else? I cannot tell from the manual.
>>>>>>>>>> Many thanks in advance.
>>>>>>>>>> Zhuo Chen
>>>>>>>>>> Department of Astronomy
>>>>>>>>>> Tsinghua University
>>>>>>>>>> Beijing, China 100084
>>>>>>>>>> *https://czlovemath123.github.io/
>>>>>>>>>> <https://czlovemath123.github.io/>*
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> Zhuo Chen
>>>>> Tsinghua University
>>>>> *https://czlovemath123.github.io/ <https://czlovemath123.github.io/>*
>>>> Zhuo Chen
>>>> Tsinghua University
>>> experiments lead.
>>> -- Norbert Wiener
>> Zhuo Chen
>> Tsinghua University
> Zhuo Chen
> Tsinghua University
Zhuo Chen
Tsinghua University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220414/14ebddce/attachment.html>
