[petsc-users] What does PCASMSetOverlap do?
    Zhuo Chen
    chenzhuotj at gmail.com
    Wed Apr 13 09:18:52 CDT 2022
Thank you, Pierre!
On Wed, Apr 13, 2022 at 10:05 PM Pierre Jolivet <pierre at joliv.et> wrote:
> You can also use the uncommented option -pc_asm_print_subdomains which
> will, as Matt told you, show you that it is exactly the same algorithm.
> Thanks,
> Pierre
> On 13 Apr 2022, at 3:58 PM, Zhuo Chen <chenzhuotj at gmail.com> wrote:
> Thank you, Matt! I will do that.
> On Wed, Apr 13, 2022 at 9:55 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Apr 13, 2022 at 9:53 AM Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>> Dear Pierre,
>>> Thank you! I looked into the webpage you sent me and I think it is not
>>> the situation that I am talking about.
>>> I think I need to attach a figure for an illustrative purpose. This
>>> figure is Figure 14.5 of "Iterative Method for Sparse Linear Systems" by
>>> Saad.
>>> <domaindecompostion.png>
>>> If I divide the domain into these three subdomains, as you can see, the
>>> middle block has two interfaces. In the matrix form, its rows are not
>>> contiguous, i.e., distributed in different processors. If ASM only expands
>>> in the contiguous direction, the domain decomposition become ineffective, I
>>> guess.
>> No, we get exactly this picture. Saad is talking about exactly the
>> algorithm we use.
>> Maybe you should just look at the subdomains being produced, -mat_view
>> draw -draw_pause 3
>>    Matt
>>> On Wed, Apr 13, 2022 at 9:36 PM Pierre Jolivet <pierre at joliv.et> wrote:
>>>> On 13 Apr 2022, at 3:30 PM, Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>>> Dear Matthew and Mark,
>>>> Thank you very much for the reply! Much appreciated!
>>>> The question was about a 1D problem. I think I should say core 1 has
>>>> row 1:32 instead of 1:32, 1:32 as it might be confusing.
>>>> So the overlap is extended to both directions for the middle processor
>>>> but only toward the increasing direction for the first processor and the
>>>> decreasing direction for the last processor. In 1D, this makes sense as the
>>>> domain is contiguous. However, in 2D with domain decomposition with spacial
>>>> overlaps, this overlapping would not work as one subdomain can have several
>>>> neighbor domains. Mark mentioned generalized ASM, is that the correct
>>>> direction that I should look for?
>>>> What is it that you want to do exactly?
>>>> If you are using a standard discretisation kernel, e.g., piecewise
>>>> linear finite elements, MatIncreaseOverlap() called by PCASM will generate
>>>> an overlap algebraically which is equivalent to the overlap you would have
>>>> gotten geometrically.
>>>> If you know that “geometric” overlap (or want to use a custom
>>>> definition of overlap), you could use
>>>> https://petsc.org/release/docs/manualpages/PC/PCASMSetLocalSubdomains.html
>>>> Thanks,
>>>> Pierre
>>>> Best regards.
>>>> On Wed, Apr 13, 2022 at 9:14 PM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Wed, Apr 13, 2022 at 9:11 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> On Wed, Apr 13, 2022 at 8:56 AM Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Wed, Apr 13, 2022 at 6:42 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> No, without overlap you have, let say:
>>>>>>>> core 1:   1:32, 1:32
>>>>>>>> core 2:   33:64,  33:64
>>>>>>>> Overlap will increase the size of each domain so you get:
>>>>>>>> core 1:   1:33, 1:33
>>>>>>>> core 2:   32:65,  32:65
>>>>>>> I do not think this is correct. Here is the algorithm. Imagine the
>>>>>>> matrix is a large graph. When you divide rows, you
>>>>>>> can think of that as dividing the vertices into sets. If overlap =
>>>>>>> 1, it means start with my vertex set, and add all vertices
>>>>>>> that are just 1 edge away from my set.
>>>>>> I think that is what was said. You increase each subdomain by one row
>>>>>> of vertices.
>>>>>> So in 1D, vertex 32 and 33 are in both subdomains and you have an
>>>>>> overlap region of size 2.
>>>>>> They want an overlap region of size 1, vertex 33.
>>>>> This is true, but I did not think they specified a 1D mesh.
>>>>>   Matt
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> What you want is reasonable but requires PETSc to pick a separator
>>>>>>>> set, which is not well defined.
>>>>>>>> You need to build that yourself with gasm (I think) if you want
>>>>>>>> this.
>>>>>>>> Mark
>>>>>>>> On Wed, Apr 13, 2022 at 3:17 AM Zhuo Chen <chenzhuotj at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Hi,
>>>>>>>>> I hope that everything is going well with everybody.
>>>>>>>>> I have a question about the PCASMSetOverlap. If I have a 128x128
>>>>>>>>> matrix and I use 4 cores with overlap=1. Does it mean that from core 1 to
>>>>>>>>> core 4, the block ranges are (starting from 1):
>>>>>>>>> core 1:   1:33, 1:33
>>>>>>>>> core 2:   33:65,  33:65
>>>>>>>>> core 3:   65:97,  65:97
>>>>>>>>> core 4:   95:128, 95:128
>>>>>>>>> Or is it something else? I cannot tell from the manual.
>>>>>>>>> Many thanks in advance.
>>>>>>>>> Zhuo Chen
>>>>>>>>> Department of Astronomy
>>>>>>>>> Tsinghua University
>>>>>>>>> Beijing, China 100084
>>>>>>>>> *https://czlovemath123.github.io/
>>>>>>>>> <https://czlovemath123.github.io/>*
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> Zhuo Chen
>>>> Tsinghua University
>>>> *https://czlovemath123.github.io/ <https://czlovemath123.github.io/>*
>>> Zhuo Chen
>>> Tsinghua University
>> experiments lead.
>> -- Norbert Wiener
> Zhuo Chen
> Tsinghua University
Zhuo Chen
Tsinghua University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220413/d6d90538/attachment-0001.html>
