[petsc-users] What does PCASMSetOverlap do?
Pierre Jolivet
pierre at joliv.et
Wed Apr 13 08:36:39 CDT 2022
> On 13 Apr 2022, at 3:30 PM, Zhuo Chen <chenzhuotj at gmail.com> wrote:
> Dear Matthew and Mark,
> Thank you very much for the reply! Much appreciated!
> The question was about a 1D problem. I think I should say core 1 has row 1:32 instead of 1:32, 1:32 as it might be confusing.
> So the overlap is extended to both directions for the middle processor but only toward the increasing direction for the first processor and the decreasing direction for the last processor. In 1D, this makes sense as the domain is contiguous. However, in 2D with domain decomposition with spacial overlaps, this overlapping would not work as one subdomain can have several neighbor domains. Mark mentioned generalized ASM, is that the correct direction that I should look for?
What is it that you want to do exactly?
If you are using a standard discretisation kernel, e.g., piecewise linear finite elements, MatIncreaseOverlap() called by PCASM will generate an overlap algebraically which is equivalent to the overlap you would have gotten geometrically.
If you know that “geometric” overlap (or want to use a custom definition of overlap), you could use https://petsc.org/release/docs/manualpages/PC/PCASMSetLocalSubdomains.html <https://petsc.org/release/docs/manualpages/PC/PCASMSetLocalSubdomains.html>
Pierre
> Best regards.
> On Wed, Apr 13, 2022 at 9:14 PM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> On Wed, Apr 13, 2022 at 9:11 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> On Wed, Apr 13, 2022 at 8:56 AM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> On Wed, Apr 13, 2022 at 6:42 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> No, without overlap you have, let say:
> core 1: 1:32, 1:32
> core 2: 33:64, 33:64
> Overlap will increase the size of each domain so you get:
> core 1: 1:33, 1:33
> core 2: 32:65, 32:65
> I do not think this is correct. Here is the algorithm. Imagine the matrix is a large graph. When you divide rows, you
> can think of that as dividing the vertices into sets. If overlap = 1, it means start with my vertex set, and add all vertices
> that are just 1 edge away from my set.
> I think that is what was said. You increase each subdomain by one row of vertices.
> So in 1D, vertex 32 and 33 are in both subdomains and you have an overlap region of size 2.
> They want an overlap region of size 1, vertex 33.
> This is true, but I did not think they specified a 1D mesh.
> Matt
> Thanks,
> Matt
> What you want is reasonable but requires PETSc to pick a separator set, which is not well defined.
> You need to build that yourself with gasm (I think) if you want this.
> Mark
> On Wed, Apr 13, 2022 at 3:17 AM Zhuo Chen <chenzhuotj at gmail.com <mailto:chenzhuotj at gmail.com>> wrote:
> Hi,
> I hope that everything is going well with everybody.
> I have a question about the PCASMSetOverlap. If I have a 128x128 matrix and I use 4 cores with overlap=1. Does it mean that from core 1 to core 4, the block ranges are (starting from 1):
> core 1: 1:33, 1:33
> core 2: 33:65, 33:65
> core 3: 65:97, 65:97
> core 4: 95:128, 95:128
> Or is it something else? I cannot tell from the manual.
> Many thanks in advance.
> Zhuo Chen
> Department of Astronomy
> Tsinghua University
> Beijing, China 100084
> https://czlovemath123.github.io/ <https://czlovemath123.github.io/>
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
> Zhuo Chen
> Tsinghua University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220413/9343a0e2/attachment.html>
