[petsc-users] What does PCASMSetOverlap do?
Wed Apr 13 08:14:40 CDT 2022
On Wed, Apr 13, 2022 at 9:11 AM Mark Adams <mfadams at lbl.gov> wrote:
> On Wed, Apr 13, 2022 at 8:56 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Apr 13, 2022 at 6:42 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> No, without overlap you have, let say:
>>> core 1:   1:32, 1:32
>>> core 2:   33:64,  33:64
>>> Overlap will increase the size of each domain so you get:
>>> core 1:   1:33, 1:33
>>> core 2:   32:65,  32:65
>> I do not think this is correct. Here is the algorithm. Imagine the matrix
>> is a large graph. When you divide rows, you
>> can think of that as dividing the vertices into sets. If overlap = 1, it
>> means start with my vertex set, and add all vertices
>> that are just 1 edge away from my set.
> I think that is what was said. You increase each subdomain by one row of
> vertices.
> So in 1D, vertex 32 and 33 are in both subdomains and you have an overlap
> region of size 2.
> They want an overlap region of size 1, vertex 33.
This is true, but I did not think they specified a 1D mesh.
  Matt
>>   Thanks,
>>      Matt
>>> What you want is reasonable but requires PETSc to pick a separator set,
>>> which is not well defined.
>>> You need to build that yourself with gasm (I think) if you want this.
>>> Mark
>>> On Wed, Apr 13, 2022 at 3:17 AM Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>>> Hi,
>>>> I hope that everything is going well with everybody.
>>>> I have a question about the PCASMSetOverlap. If I have a 128x128 matrix
>>>> and I use 4 cores with overlap=1. Does it mean that from core 1 to core 4,
>>>> the block ranges are (starting from 1):
>>>> core 1:   1:33, 1:33
>>>> core 2:   33:65,  33:65
>>>> core 3:   65:97,  65:97
>>>> core 4:   95:128, 95:128
>>>> Or is it something else? I cannot tell from the manual.
>>>> Many thanks in advance.
>>>> Zhuo Chen
>>>> Department of Astronomy
>>>> Tsinghua University
>>>> Beijing, China 100084
>>>> *https://czlovemath123.github.io/ <https://czlovemath123.github.io/>*
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220413/357d36c7/attachment.html>
