[petsc-users] Local refinements of tetrahedron elements
Tue Apr 12 16:01:58 CDT 2022
On Tue, Apr 12, 2022 at 11:20 AM Ce Qin <qince168 at gmail.com> wrote:
> I am sorry for the unclear description.
> By hierarchical, I mean that each cell in the coarse mesh marked for
> refinement is subdivided into several small cells.
> For example, the mesh refined by the SBR method is hierarchical.
Even here you do not get edge-nested meshes.
   Matt
> Best regards,
> Ce
> Matthew Knepley <knepley at gmail.com> 于2022年4月12日周二 18:47写道:
>> On Tue, Apr 12, 2022 at 2:10 AM Ce Qin <qince168 at gmail.com> wrote:
>>> Thanks for your reply, Matthew.
>>> One more question, I want to get a hierarchical mesh after mesh
>>> adaptation, so does the adaptation method implemented in ParMMG support
>>> this feature?
>> What exactly does that mean?
>>   Thanks,
>>      Matt
>>> Best regards,
>>> Ce
>>> Matthew Knepley <knepley at gmail.com> 于2022年4月11日周一 21:17写道:
>>>> On Fri, Apr 1, 2022 at 10:14 AM Ce Qin <qince168 at gmail.com> wrote:
>>>>> Dear all,
>>>>> I want to implement the adaptive finite element method using the
>>>>> DMPlex interface. So I would like to know whether DMPlex supports local
>>>>> (also hierarchical) refinements of tetrahedron elements. I found that there
>>>>> is an adaptation method called SBR, but it seems that it only supports
>>>>> triangle elements.
>>>> Sorry this took me a while.
>>>> You are right, I have not implemented the 3D version yet. It is
>>>> straightforward, but in the paper there are 96 cases. I would like
>>>> to automatically generate that, but I need to figure out how that would
>>>> go. Right now all the adaptation requests have been for
>>>> 2D, or used ParMMG which works in 3D for PETSc right now.
>>>>   Thanks,
>>>>      Matt
>>>>> Best regards,
>>>>> Ce
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220412/79e78a91/attachment.html>
