[petsc-users] Local refinements of tetrahedron elements
Pierre Jolivet pierre at joliv.et
Tue Apr 12 10:26:39 CDT 2022
> On 12 Apr 2022, at 5:20 PM, Ce Qin <qince168 at gmail.com> wrote:
> I am sorry for the unclear description.
> By hierarchical, I mean that each cell in the coarse mesh marked for refinement is subdivided into several small cells.
[Par]Mmg does not do that. They generate unstructured meshes without a particular hierarchy between the input and output meshes.
Pierre
> For example, the mesh refined by the SBR method is hierarchical.
> Best regards,
> Ce
> Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> 于2022年4月12日周二 18:47写道:
> On Tue, Apr 12, 2022 at 2:10 AM Ce Qin <qince168 at gmail.com <mailto:qince168 at gmail.com>> wrote:
> Thanks for your reply, Matthew.
> One more question, I want to get a hierarchical mesh after mesh adaptation, so does the adaptation method implemented in ParMMG support this feature?
> What exactly does that mean?
>   Thanks,
>      Matt
> Best regards,
> Ce
> Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> 于2022年4月11日周一 21:17写道:
> On Fri, Apr 1, 2022 at 10:14 AM Ce Qin <qince168 at gmail.com <mailto:qince168 at gmail.com>> wrote:
> Dear all,
> I want to implement the adaptive finite element method using the DMPlex interface. So I would like to know whether DMPlex supports local (also hierarchical) refinements of tetrahedron elements. I found that there is an adaptation method called SBR, but it seems that it only supports triangle elements.
> Sorry this took me a while.
> You are right, I have not implemented the 3D version yet. It is straightforward, but in the paper there are 96 cases. I would like
> to automatically generate that, but I need to figure out how that would go. Right now all the adaptation requests have been for
> 2D, or used ParMMG which works in 3D for PETSc right now.
>   Thanks,
>      Matt
> Best regards,
> Ce
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220412/f919afc1/attachment.html>
