[petsc-users] MatSetNullSpace results in nan with MUMPS
Bhargav Subramanya
bhargav.subramanya at kaust.edu.sa
Mon Apr 4 10:25:45 CDT 2022
Dear Matt,
Thank you for the reply.
On Sun, Apr 3, 2022 at 4:00 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Apr 2, 2022 at 8:59 PM Bhargav Subramanya <
> bhargav.subramanya at kaust.edu.sa> wrote:
>> Dear All,
>> I am trying to solve Ax = b in parallel using MUMPS, where x is composed
>> of velocity, pressure, and temperature. There is a null space due to the
>> homogeneous Neumann pressure boundary conditions.
>> 1. Without explicitly removing the null space, the solution is bounded
>> and robust, and I am able to iterate in time, although I need to check if
>> the solution is physically correct. I am not sure if MUMPS is able to
>> detect the null space in this case.
> MUMPS should fail with a 0 pivot. I do not understand this.
>> 2. However, when I explicitly use MatSetNullSpace as shown below, the
>> solution blows up in 2-3 temporal iterations, resulting in nan. Could you
>> please share your thoughts regarding this problem?
> Did you check that this is a nullspace vector using
> https://petsc.org/main/docs/manualpages/Mat/MatNullSpaceTest.html
> <https://urldefense.com/v3/__https://petsc.org/main/docs/manualpages/Mat/MatNullSpaceTest.html__;!!Nmw4Hv0!xGtCbXmv5pFV2xcOa8sYXVsvJ5ZBq-DjqjcYkhdAhaqrNUkfz8gR5oPpDoHp0UmKNtnpRIvkN2M3iq_wt9Ep9wMmVJA$>
--My apologies. I had a bug with the null vector assembly. I fixed it and
confirmed it with MatNullSpaceTest. My solution doesn't blow up now. Thanks
a lot.
> Thanks,
> Matt
>> Thanks,
>> Bhargav
>> Output for -pc_type svd -pc_svd_monitor
>> SVD: condition number 3.159257564649e+16, 1 of 1080 singular values are
>> (nearly) zero
>> SVD: smallest singular values: 3.693890048955e-17 2.902795363876e-10
>> 2.902795486255e-10 2.902796682780e-10 7.614221123356e-10
>> SVD: largest singular values : 1.166981958972e+00 1.166981958972e+00
>> 1.166995008014e+00 1.166995008014e+00 1.166995008014e+00
>> PetscErrorCode *SetNullVector*(Mat MatGlobalLinear,Mesh mesh,Equations
>> eq){
>> Vec NullVector;
>> PetscInt numNullVectors,disp,i,j;
>> PetscScalar constantValue = 1.0,nrm;
>> MatNullSpace NullSp = NULL;
>> PetscErrorCode ierr;
>> PetscFunctionBeginUser;
>> numNullVectors = 1;
>> disp = mesh.numLayers*mesh.numEdges + (eq.pressure-1)*mesh.numCells;
>> ierr = *MatCreateVecs*(MatGlobalLinear,&NullVector,NULL);CHKERRQ(ierr);
>> *for*(i=0; i<mesh.numLayers; i++){
>> *for*(j=0; j<mesh.numCells; j++){
>> ierr = VecSetValue(NullVector,j + i*mesh.numCells + disp,constantValue,
>> *INSERT_VALUES*);CHKERRQ(ierr);
>> ierr = *VecAssemblyBegin*(NullVector);CHKERRQ(ierr);
>> ierr = *VecAssemblyEnd*(NullVector);CHKERRQ(ierr);
>> ierr = *VecNorm*(NullVector,*NORM_2*,&nrm);CHKERRQ(ierr);
>> ierr = *VecScale*(NullVector,1.0/nrm);CHKERRQ(ierr);
>> /* set null space */
>> ierr = *MatNullSpaceCreate*(MPI_COMM_WORLD,*PETSC_FALSE*
>> ,numNullVectors,&NullVector,&NullSp);CHKERRQ(ierr);
>> ierr = *MatSetNullSpace*(MatGlobalLinear,NullSp);CHKERRQ(ierr);
>> /* clean up */
>> ierr = *MatNullSpaceDestroy*(&NullSp);CHKERRQ(ierr);
>> ierr = *VecDestroy*(&NullVector);CHKERRQ(ierr);
>> PetscFunctionReturn(0);
>> This message and its contents, including attachments are intended solely
>> for the original recipient. If you are not the intended recipient or have
>> received this message in error, please notify me immediately and delete
>> this message from your computer system. Any unauthorized use or
>> distribution is prohibited. Please consider the environment before printing
>> this email.
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!Nmw4Hv0!xGtCbXmv5pFV2xcOa8sYXVsvJ5ZBq-DjqjcYkhdAhaqrNUkfz8gR5oPpDoHp0UmKNtnpRIvkN2M3iq_wt9EpP92ZqUc$>
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220404/13ae1b1d/attachment-0001.html>
