[petsc-users] Allocating the diagonal for MatMPIAIJSetPreallocation
Samuel Estes samuelestes91 at gmail.com
Fri Apr 1 12:07:58 CDT 2022
Thank you for all the help. I think I'm mostly clear now.
I think my only remaining question relates to point 1:
So let's call the global matrix across all processors A and let's say it's
a square matrix of size n. Then each processor has a subset of the rows of
A so that there's in principle a contiguous rectangular chunk of A on each
proc. Now we want to use this preallocator matrix to determine the non-zero
structure of each processors chunk of A. Let's call this matrix P. You say
that P should also be square. But I would think that, at least locally, P
should be rectangular on each proc and basically have the same size as the
local chunks of A. Do you mean that P is square when considered globally
across all processors? I guess my question is a bit subtle, but basically,
is P essentially a parallel Mat type which exists nominally across all
procs, or is it a serial type object which is local to each proc? I think I
was viewing it in the second way since it doesn't obviously require
communication but I guess if you consider it in the first way it makes
sense that it would be nxn.
On Fri, Apr 1, 2022 at 12:00 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Apr 1, 2022 at 12:57 PM Samuel Estes <samuelestes91 at gmail.com>
> wrote:
>> Ah, so let me see if I understand this now. So basically you preallocate
>> for this "dummy matrix" of type MatPreallocator. But rather than simply
>> calling MatXXXAIJSetPreallocation() to allocate space, you actually tell
>> this "dummy matrix" exactly where the non-zeros will be. You then call this
>> MatPreallocatorPreallocate() routine to pass the non-zero structure of the
>> "dummy matrix" to the actual matrix that you're using for the linear
>> system. You then call MatSetValues() (or a variant thereof) to set the
>> values of this preallocated matrix.
>> A couple more clarifying questions:
>> 1. So this MatPreallocator matrix should have a rectangular structure of
>> (rEnd-rStart) rows and n columns (where n is the total size of the system?
>> I'm assuming here that the global matrix across all processors is square.
> This "dummy matrix" will look exactly like your system matrix, meaning it
> is square, and you tell it the nonzeros by just calling MatSetValues(),
> exactly as you would for your system matrix. That is why you can reuse
> exactly the same code.
>> 2. You preallocate for the dummy matrix by calling matsetvalues rather
>> than the usual way of preallocating?
> Yes.
>> 3. That's what you mean by looping twice? You loop over once using
>> matsetvalues to preallocate, then you have to loop using matsetvalues again
>> a second time to actually set the values of the parallel Mat you actually
>> use to solve the system?
> Yes.
>   Thanks,
>     Matt
>> On Fri, Apr 1, 2022 at 11:50 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Apr 1, 2022 at 12:45 PM Samuel Estes <samuelestes91 at gmail.com>
>>> wrote:
>>>> Thanks! This seems like it might be what I need. I'm still a little
>>>> unclear on how it works though? My problem is basically that for any given
>>>> row, I know the total non-zeros but not how many occur in the diagonal vs
>>>> off-diagonal. Without knowledge of the underlying grid, I'm not sure how
>>>> there could be a black box utility to figure this out? Am I
>>>> misunderstanding how this is used?
>>> So each process gets a stack of rows, [rStart, rEnd). A nonzero (r, c)
>>> is in the diagonal block if rStart <= c < rEnd. So if you know (r, c) for
>>> each nonzero, you know whether it is in the diagonal block.
>>>   Thanks,
>>>      Matt
>>>> On Fri, Apr 1, 2022 at 11:34 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Fri, Apr 1, 2022 at 12:27 PM Samuel Estes <samuelestes91 at gmail.com>
>>>>> wrote:
>>>>>> Hi,
>>>>>> I have a problem in which I know (roughly) the number of non-zero
>>>>>> entries for each row of a matrix but I don't have a convenient way of
>>>>>> determining whether they belong to the diagonal or off-diagonal part of the
>>>>>> parallel matrix. Is there some way I can just allocate the total number of
>>>>>> non-zeros in a row regardless of which part they belong to? I'm assuming
>>>>>> that this is not possible but I just wanted to check. It seems like it
>>>>>> should be possible in principle since the matrix is only split by the rows
>>>>>> but the columns of a row are all on the same processor (at least as I
>>>>>> understand it). Thanks!
>>>>> In serial, the matrix is stored by rows. In parallel, it is split into
>>>>> a diagonal and off-diagonal block, so that we can overlap communication and
>>>>> computation in the matvec.
>>>>> However, we have a convenience structure for figuring this out, called
>>>>> MatPreallocator,
>>>>> https://petsc.org/main/docs/manualpages/Mat/MATPREALLOCATOR.html
>>>>> In my code, I wrote a loop around the code that filled up my matrix,
>>>>> which executed twice. On the first pass, I fed in the MatPreallocator
>>>>> matrix. When this finished
>>>>> you can call
>>>>> https://petsc.org/main/docs/manualpages/Mat/MatPreallocatorPreallocate.html#MatPreallocatorPreallocate
>>>>> on your system amtrix, then on the second
>>>>> pass use the system matrix. This was only a few extra lines of code
>>>>> for me. If you want to optimize further, you can have a flag that only
>>>>> computes the values on the
>>>>> second pass.
>>>>>   Thanks,
>>>>>       Matt
>>>>> Sam
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220401/e1b55410/attachment.html>
