[petsc-users] Possibilities to VecScatter to a sparse Vector-Format
Matthew Knepley
knepley at gmail.com
Thu Sep 30 08:44:01 CDT 2021
On Thu, Sep 30, 2021 at 9:39 AM Hannes Phil Niklas Brandt <
s6hsbran at uni-bonn.de> wrote:
> Hello,
> I intend to compute a parallel Matrix-Vector-Product (via MPI) and
> therefore would like to scatter the entries of the input MPI-Vec v to a
> local vector containing all entries relevant to the current process.
> To achieve this I tried defining a VecScatter, which scatters from v to a
> sequential Vec v_seq (each process has it's own version of v_seq). However,
> storing v_seq (which has one entry for each global row, thus containing a
> large amount of zero-entries) may demand too much storage space (in
> comparison to my data-sparse Matrix-Storage-Format).
> I am interested in possibilities to scatter v to a sparse Vec-type to
> avoid storing unnecessary large amounts of zero-entries. Is there a sparse
> Vector format in Petsc compatible to the VecScatter procedure or is there
> another efficient way to compute Matrix-Vector-Products without usinglarge
> amounts of storage space on each process?
I think you misunderstand VecScatter. Parallel to sequential is one
possibility, but also parallel-parallel, seq-parallel, etc. Second, you can
give
whatever indices you want into it. Thus you can index only a few places in
a large array, or compact a sparse array into a contiguous one. I am
not sure what other possibilities may exist.
Matt
> Best Regards
> Hannes Brandt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210930/f76e4259/attachment.html>
