[petsc-users] Convergence rate for spatially varying Helmholtz system
Ramakrishnan Thirumalaisamy rthirumalaisam1857 at sdsu.edu
Wed Sep 29 16:37:12 CDT 2021
Hi all,
I am trying to solve the Helmholtz equation for temperature T:
(C I  + Div D grad) T = f
in IBAMR, in which C is the spatially varying diagonal entries, and D is
the spatially varying diffusion coefficient.   I use a matrix-free solver
with matrix-based PETSc preconditioner. For the matrix-free solver, I use
gmres solver and for the matrix based preconditioner, I use Richardson ksp
+ Jacobi as a preconditioner. As the simulation progresses, the iterations
start to increase. To understand the cause, I set D to be zero, which
results in a diagonal system:
C T = f.
This should result in convergence within a single iteration, but I get
convergence in 3 iterations.
Residual norms for temperature_ solve.
  0 KSP preconditioned resid norm 4.590811647875e-02 true resid norm
2.406067589273e+09 ||r(i)||/||b|| 4.455533946945e-05
  1 KSP preconditioned resid norm 2.347767895880e-06 true resid norm
1.210763896685e+05 ||r(i)||/||b|| 2.242081505717e-09
  2 KSP preconditioned resid norm 1.245406571896e-10 true resid norm
6.328828824310e+00 ||r(i)||/||b|| 1.171966730978e-13
Linear temperature_ solve converged due to CONVERGED_RTOL iterations 2
To verify that I am indeed solving a diagonal system I printed the PETSc
matrix from the preconditioner and viewed it in Matlab. It indeed shows it
to be a diagonal system. Attached is the plot of the spy command on the
printed matrix. The matrix in binary form is also attached.
My understanding is that because the C coefficient is varying in 4 orders
of magnitude, i.e., Max(C)/Min(C) ~ 10^4, the matrix is poorly scaled. When
I rescale my matrix by 1/C then the system converges in 1 iteration as
expected. Is my understanding correct, and that scaling 1/C should be done
even for a diagonal system?
When D is non-zero, then scaling by 1/C seems to be very inconvenient as D
is stored as side-centered data for the matrix free solver.
In the case that I do not scale my equations by 1/C, is there some solver
setting that improves the convergence rate? (With D as non-zero, I have
also tried gmres as the ksp solver in the matrix-based preconditioner to
get better performance, but it didn't matter much.)
San Diego State University.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210929/3550a3b9/attachment-0001.html>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210929/3550a3b9/attachment-0001.pdf>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210929/3550a3b9/attachment-0001.obj>
