[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Wed Sep 29 16:18:46 CDT 2021
I come back with _almost_ the original question:
I would like to add an integer information (*our* original element
number, not petsc one) on each element of the DMPlex I create with
DMPlexBuildFromCellListParallel.
I would like this interger to be distribruted by or the same way
DMPlexDistribute distribute the mesh.
Is it possible to do this?
Eric
On 2021-07-14 1:18 p.m., Eric Chamberland wrote:
> Hi,
> I want to use DMPlexDistribute from PETSc for computing overlapping
> and play with the different partitioners supported.
> However, after calling DMPlexDistribute, I noticed the elements are
> renumbered and then the original number is lost.
> What would be the best way to keep track of the element renumbering?
> a) Adding an optional parameter to let the user retrieve a vector or
> "IS" giving the old number?
> b) Adding a DMLabel (seems a wrong good solution)
> c) Other idea?
> Of course, I don't want to loose performances with the need of this
> "mapping"...
> Thanks,
> Eric
Eric Chamberland, ing., M. Ing
Professionnel de recherche
GIREF/Université Laval
(418) 656-2131 poste 41 22 42
