[petsc-users] GMRES Breakdown
TARDIEU Nicolas
nicolas.tardieu at edf.fr
Tue Sep 28 08:29:06 CDT 2021
Dear Jose and Matt,
I thank you very much for your super-fast answers. And I apologize for not having checked the list of changes.
Best regards,
Nicolas
Nicolas Tardieu
Ingénieur Chercheur
Groupe Dynamique des Equipements - T6B
EDF - R&D Dpt ERMES
Tél. : 01 78 19 37 49
De : knepley at gmail.com <knepley at gmail.com>
Envoyé : mardi 28 septembre 2021 14:54
À : TARDIEU Nicolas
Cc : petsc-users at mcs.anl.gov
Objet : Re: [petsc-users] GMRES Breakdown
On Tue, Sep 28, 2021 at 8:39 AM TARDIEU Nicolas via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Dear PETSc Team,
We, code_aster's development team, are using PETSc in our application for years now, mainly for the KSP et PC features. We run tests cases every week without problems.
After upgrading from PETSc 3.12.3 to 3.15.3, a test case using GMRES failed with KSP_DIVERGED_BREAKDOWN. By rolling back to 3.12.3, we have checked that the upgrade is the origin of the failure.
We know this can occur with GMRES but it is the first time we are facing this situation.
Is it a bug ? If yes, how can we help to fix it ? If no, what can we do ? Could the flexible version of GMRES be an alternative ?
This is not a bug, but we did change the operation. We now check whether there is a significant residual spike after a restart. We
want to let the user know that this likely means that the solver is inappropriate for the problem. As Jose notes, you can turn off this
behavior.
Matt
Best regards,
Nicolas
Nicolas Tardieu
Ing, PhD
Ce message et toutes les pièces jointes (ci-après le 'Message') sont établis à l'intention exclusive des destinataires et les informations qui y figurent sont strictement confidentielles. Toute utilisation de ce Message non conforme à sa destination, toute diffusion ou toute publication totale ou partielle, est interdite sauf autorisation expresse.
Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de votre système, ainsi que toutes ses copies, et de n'en garder aucune trace sur quelque support que ce soit. Nous vous remercions également d'en avertir immédiatement l'expéditeur par retour du message.
Il est impossible de garantir que les communications par messagerie électronique arrivent en temps utile, sont sécurisées ou dénuées de toute erreur ou virus.
____________________________________________________
This message and any attachments (the 'Message') are intended solely for the addressees. The information contained in this Message is confidential. Any use of information contained in this Message not in accord with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval.
If you are not the addressee, you may not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return message.
E-mail communication cannot be guaranteed to be timely secure, error or virus-free.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210928/92ee0286/attachment-0001.html>
