[petsc-users] Petsc memory consumption keep increasing in my loop
Medane TCHAKOROM
medane.tchakorom at univ-fcomte.fr
Fri Sep 24 09:08:01 CDT 2021
Hello,
I have problem with a code i'am working on.
To illustrate my problem, here is an example:
int main(int argc, char *argv[])
PetscErrorCode ierr;
ierr = PetscInitialize(&argc, &argv, (char *)0, NULL);
if (ierr)
return ierr;
int i = 0;
for (i = 0; i < 1; i++)
Mat A;
ierr = MatCreate(PETSC_COMM_WORLD, &A);
CHKERRQ(ierr);
ierr = MatSetSizes(A, 16, 16, PETSC_DECIDE,PETSC_DECIDE);
CHKERRQ(ierr);
ierr = MatSetFromOptions(A);
CHKERRQ(ierr);
ierr = MatSetUp(A);
CHKERRQ(ierr);
ierr = MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
CHKERRQ(ierr);
ierr = MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
CHKERRQ(ierr);
/// SOME CODE HERE....
MatDestroy(&A);
FILE *fPtr;
fPtr = fopen("petsc_dump_file.txt", "a");
PetscMallocDump(fPtr);
fclose(fPtr);
ierr = PetscFinalize();
CHKERRQ(ierr);
return 0;
The problem is , in the loop, the memory consumption keep increasing
till the end of the program.
I checked memory leak with PetscMallocDump, and found out that the
problem may be due to matrix creation.
I'am new to Petsc and i don't know if i'am doing something wrong. Thanks
Médane
