[petsc-users] New error on Summit
Barry Smith bsmith at petsc.dev
Thu Sep 23 09:24:20 CDT 2021
  Not really fixed, the problem is still there. You just bypassed the problem that BuildSystem has.
> On Sep 23, 2021, at 10:16 AM, Mark Adams <mfadams at lbl.gov> wrote:
> This is fixed now. I did not have a gcc module loaded so it was picking up some default.
> On Thu, Sep 23, 2021 at 8:56 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> This was working before but now I get this (strange) error:
>   Run Build Command(s):/usr/bin/gmake -f Makefile cmTC_429f1/fast && /usr/bin/gmake  -f CMakeFiles/cmTC_429f1.dir/build.make CMakeFiles/cmTC_429f1.dir/build
>     gmake[1]: Entering directory '/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-cuda/externalpackages/git.kokkos/petsc-build/CMakeFiles/CMakeTmp'
>     Building CXX object CMakeFiles/cmTC_429f1.dir/testCXXCompiler.cxx.o
>     /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-cuda/externalpackages/git.kokkos/bin/nvcc_wrapper   -fPIC -g -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4 -O -+ -qPIC  -std=gnu++14 -o CMakeFiles/cmTC_429f1.dir/testCXXCompiler.cxx.o -c /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-cuda/externalpackages/git.kokkos/petsc-build/CMakeFiles/CMakeTmp/testCXXCompiler.cxx
>     nvcc_wrapper has been given GNU extension standard flag -std=gnu++14 - reverting flag to -std=c++14
>     nvcc warning : The 'compute_35', 'compute_37', 'compute_50', 'sm_35', 'sm_37' and 'sm_50' architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
>     g++: error: unrecognized command line option �~@~X-qPIC�~@~Y; did you mean �~@~X-fPIC�~@~Y?
>     gmake[1]: *** [CMakeFiles/cmTC_429f1.dir/build.make:78: CMakeFiles/cmTC_429f1.dir/testCXXCompiler.cxx.o] Error 1
>     gmake[1]: Leaving directory '/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-cuda/externalpackages/git.kokkos/petsc-build/CMakeFiles/CMakeTmp'
>     gmake: *** [Makefile:127: cmTC_429f1/fast] Error 2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210923/f0c1c8aa/attachment.html>
