[petsc-users] How to combine different element types into a single DMPlex?
Matthew Knepley
knepley at gmail.com
Wed Sep 22 06:20:29 CDT 2021
On Wed, Sep 22, 2021 at 3:04 AM Karin&NiKo <niko.karin at gmail.com> wrote:
> Dear Matthew,
> This is great news!
> For my part, I would be mostly interested in the parallel input interface.
> Sorry for that...
> Indeed, in our application, we already have a parallel mesh data
> structure that supports hybrid meshes with parallel I/O and distribution
> (based on the MED format). We would like to use a DMPlex to make parallel
> mesh adaptation.
> As a matter of fact, all our meshes are in the MED format. We could
> also contribute to extend the interface of DMPlex with MED (if you consider
> it could be usefull).
An MED interface does exist. I stopped using it for two reasons:
1) The code was not portable and the build was failing on different
architectures. I had to manually fix it.
2) The boundary markers did not provide global information, so that
parallel reading was much harder.
Feel free to update my MED reader to a better design.
Matt
> Best regards,
> Nicolas
> Le mar. 21 sept. 2021 à 21:56, Matthew Knepley <knepley at gmail.com> a
> écrit :
>> On Tue, Sep 21, 2021 at 10:31 AM Karin&NiKo <niko.karin at gmail.com> wrote:
>>> Dear Eric, dear Matthew,
>>> I share Eric's desire to be able to manipulate meshes composed of
>>> different types of elements in a PETSc's DMPlex.
>>> Since this discussion, is there anything new on this feature for the
>>> DMPlex object or am I missing something?
>> Thanks for finding this!
>> Okay, I did a rewrite of the Plex internals this summer. It should now be
>> possible to interpolate a mesh with any
>> number of cell types, partition it, redistribute it, and many other
>> manipulations.
>> You can read in some formats that support hybrid meshes. If you let me
>> know how you plan to read it in, we can make it work.
>> Right now, I don't want to make input interfaces that no one will ever
>> use. We have a project, joint with Firedrake, to finalize
>> parallel I/O. This will make parallel reading and writing for
>> checkpointing possible, supporting topology, geometry, fields and
>> layouts, for many meshes in one HDF5 file. I think we will finish in
>> November.
>> Thanks,
>> Matt
>>> Thanks,
>>> Nicolas
>>> Le mer. 21 juil. 2021 à 04:25, Eric Chamberland <
>>> Eric.Chamberland at giref.ulaval.ca> a écrit :
>>>> Hi,
>>>> On 2021-07-14 3:14 p.m., Matthew Knepley wrote:
>>>> On Wed, Jul 14, 2021 at 1:25 PM Eric Chamberland <
>>>> Eric.Chamberland at giref.ulaval.ca> wrote:
>>>>> Hi,
>>>>> while playing with DMPlexBuildFromCellListParallel, I noticed we have
>>>>> to
>>>>> specify "numCorners" which is a fixed value, then gives a fixed number
>>>>> of nodes for a series of elements.
>>>>> How can I then add, for example, triangles and quadrangles into a
>>>>> DMPlex?
>>>> You can't with that function. It would be much mich more complicated if
>>>> you could, and I am not sure
>>>> it is worth it for that function. The reason is that you would need
>>>> index information to offset into the
>>>> connectivity list, and that would need to be replicated to some extent
>>>> so that all processes know what
>>>> the others are doing. Possible, but complicated.
>>>> Maybe I can help suggest something for what you are trying to do?
>>>> Yes: we are trying to partition our parallel mesh with PETSc
>>>> functions. The mesh has been read in parallel so each process owns a part
>>>> of it, but we have to manage mixed elements types.
>>>> When we directly use ParMETIS_V3_PartMeshKway, we give two arrays to
>>>> describe the elements which allows mixed elements.
>>>> So, how would I read my mixed mesh in parallel and give it to PETSc
>>>> DMPlex so I can use a PetscPartitioner with DMPlexDistribute ?
>>>> A second goal we have is to use PETSc to compute the overlap, which is
>>>> something I can't find in PARMetis (and any other partitionning library?)
>>>> Thanks,
>>>> Eric
>>>> Thanks,
>>>> Matt
>>>>> Thanks,
>>>>> Eric
>>>>> Eric Chamberland, ing., M. Ing
>>>>> Professionnel de recherche
>>>>> GIREF/Université Laval
>>>>> (418) 656-2131 poste 41 22 42
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210922/0bc5a8b4/attachment.html>
