[petsc-users] How to combine different element types into a single DMPlex?
Karin&NiKo niko.karin at gmail.com
Wed Sep 22 02:04:35 CDT 2021
Dear Matthew,
This is great news!
For my part, I would be mostly interested in the parallel input interface.
Sorry for that...
Indeed, in our application,  we already have a parallel mesh data structure
that supports hybrid meshes with parallel I/O and distribution (based on
the MED format). We would like to use a DMPlex to make parallel mesh
adaptation.
 As a matter of fact, all our meshes are in the MED format. We could
also contribute to extend the interface of DMPlex with MED (if you consider
it could be usefull).
Best regards,
Nicolas
Le mar. 21 sept. 2021 à 21:56, Matthew Knepley <knepley at gmail.com> a écrit :
> On Tue, Sep 21, 2021 at 10:31 AM Karin&NiKo <niko.karin at gmail.com> wrote:
>> Dear Eric, dear Matthew,
>> I share Eric's desire to be able to manipulate meshes composed of
>> different types of elements in a PETSc's DMPlex.
>> Since this discussion, is there anything new on this feature for the
>> DMPlex object or am I missing something?
> Thanks for finding this!
> Okay, I did a rewrite of the Plex internals this summer. It should now be
> possible to interpolate a mesh with any
> number of cell types, partition it, redistribute it, and many other
> manipulations.
> You can read in some formats that support hybrid meshes. If you let me
> know how you plan to read it in, we can make it work.
> Right now, I don't want to make input interfaces that no one will ever
> use. We have a project, joint with Firedrake, to finalize
> parallel I/O. This will make parallel reading and writing for
> checkpointing possible, supporting topology, geometry, fields and
> layouts, for many meshes in one HDF5 file. I think we will finish in
> November.
>   Thanks,
>      Matt
>> Thanks,
>> Nicolas
>> Le mer. 21 juil. 2021 à 04:25, Eric Chamberland <
>> Eric.Chamberland at giref.ulaval.ca> a écrit :
>>> Hi,
>>> On 2021-07-14 3:14 p.m., Matthew Knepley wrote:
>>> On Wed, Jul 14, 2021 at 1:25 PM Eric Chamberland <
>>> Eric.Chamberland at giref.ulaval.ca> wrote:
>>>> Hi,
>>>> while playing with DMPlexBuildFromCellListParallel, I noticed we have
>>>> to
>>>> specify "numCorners" which is a fixed value, then gives a fixed number
>>>> of nodes for a series of elements.
>>>> How can I then add, for example, triangles and quadrangles into a
>>>> DMPlex?
>>> You can't with that function. It would be much mich more complicated if
>>> you could, and I am not sure
>>> it is worth it for that function. The reason is that you would need
>>> index information to offset into the
>>> connectivity list, and that would need to be replicated to some extent
>>> so that all processes know what
>>> the others are doing. Possible, but complicated.
>>> Maybe I can help suggest something for what you are trying to do?
>>> Yes: we are trying to partition our parallel mesh with PETSc functions.
>>> The mesh has been read in parallel so each process owns a part of it, but
>>> we have to manage mixed elements types.
>>> When we directly use ParMETIS_V3_PartMeshKway, we give two arrays to
>>> describe the elements which allows mixed elements.
>>> So, how would I read my mixed mesh in parallel and give it to PETSc
>>> DMPlex so I can use a PetscPartitioner with DMPlexDistribute ?
>>> A second goal we have is to use PETSc to compute the overlap, which is
>>> something I can't find in PARMetis (and any other partitionning library?)
>>> Thanks,
>>> Eric
>>>   Thanks,
>>>       Matt
>>>> Thanks,
>>>> Eric
>>>> Eric Chamberland, ing., M. Ing
>>>> Professionnel de recherche
>>>> GIREF/Université Laval
>>>> (418) 656-2131 poste 41 22 42
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210922/51ee6d8a/attachment-0001.html>
