[petsc-users] [EXTERNAL] Re: Redirecting petsc output
Fackler, Philip facklerpw at ornl.gov
Wed Sep 15 11:52:26 CDT 2021
Just to follow up here, I figured out a different way to get what I really wanted, and that is described on this page:
https://petsc.org/release/docs/manualpages/Sys/PetscVFPrintf.html
Philip Fackler
Research Software Engineer, Application Engineering Group
Advanced Computing Systems Research Section
Computer Science and Mathematics Division
Oak Ridge National Laboratory
From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Fackler, Philip via petsc-users <petsc-users at mcs.anl.gov>
Sent: Wednesday, September 8, 2021 11:24
To: Barry Smith <bsmith at petsc.dev>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; xolotl-psi-development at lists.sourceforge.net <xolotl-psi-development at lists.sourceforge.net>
Subject: Re: [petsc-users] [EXTERNAL] Re: Redirecting petsc output
Barry,
Thanks for the quick reply! I'll try those out.
Philip Fackler
Sent: Wednesday, September 8, 2021 11:16
To: Fackler, Philip <facklerpw at ornl.gov>
Cc: xolotl-psi-development at lists.sourceforge.net <xolotl-psi-development at lists.sourceforge.net>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: [EXTERNAL] Re: [petsc-users] Redirecting petsc output
  Philip,
    There a variety of techniques. Some of the command line options take an optional viewer name where the output can be redirected. For example
   -ts_monitor ascii:filename or -ts_view ascii:filename    see https://petsc.org/release/docs/manualpages/Viewer/PetscOptionsGetViewer.html for more details
   It is also possible to change all stdout from PETSc to a different file by setting PETSC_STDOUT = fopen(...)
   Barry
On Sep 8, 2021, at 10:59 AM, Fackler, Philip via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Is there a way to customize how petsc writes information? Instead of writing to stdout (for example: 0 TS dt 0.1 time 0.), what if we want to log that message to a file other output from Xolotl? I'm assuming there are multiple ways of getting this result. What's common practice with petsc folks?
Philip Fackler
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210915/2ee9db34/attachment.html>
