[petsc-users] Cuda: Vec and Mat types
Junchao Zhang
junchao.zhang at gmail.com
Wed Oct 27 15:13:36 CDT 2021
On Wed, Oct 27, 2021 at 2:24 PM Karthikeyan Chockalingam - STFC UKRI <
karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Hello,
> I hope, I am framing the question currently.
> Are only distributed arrays (DMDA) of -vec_type and -mat_type only
> supported by CUDA?
I don't understand this question. Currently, CUDA-capable types include
VECCUDA, MATAIJCUDA and MATDENSECUDA, either sequential or MPI.
> I am reading the petsc user manual in section 2.4 distributed arrays are
> introduced but at the start of chapter two there are other vector and
> matrix types as well. I wonder if these types (I don’t how they are
> referred by) are also CUDA supported?
> Can you please point me to some tutorial examples in KSP and SNES that can
> run on gpus?
search "-mat_type aijcusparse" or "-dm_mat_type aijcusparse" in petsc
tests/tutorials, you will find many.
> At the moment I am testing KSP/ex45.c with different preconditioners on
> cpus and gpus.
> I tried to run KSP/ex2.c with -vec_type cuda and -mat_type aijcuda noticed
> there was no gpu flops recorded in my log file.
It is -mat_type aijcusparse
> Many thanks,
> Karthik.
> This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and
> should notify the sender immediately and delete this email from your
> system. UK Research and Innovation (UKRI) has taken every reasonable
> precaution to minimise risk of this email or any attachments containing
> viruses or malware but the recipient should carry out its own virus and
> malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to
> presence of any viruses.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/fe6f647f/attachment-0001.html>
