[petsc-users] Cuda: Vec and Mat types
Karthikeyan Chockalingam - STFC UKRI karthikeyan.chockalingam at stfc.ac.uk
Wed Oct 27 14:24:01 CDT 2021
Hello,
I hope, I am framing the question currently.
Are only distributed arrays (DMDA) of -vec_type and -mat_type only supported by CUDA?
I am reading the petsc user manual in section 2.4 distributed arrays are introduced but at the start of chapter two there are other vector and matrix types as well. I wonder if these types (I don’t how they are referred by) are also CUDA supported?
Can you please point me to some tutorial examples in KSP and SNES that can run on gpus?
At the moment I am testing KSP/ex45.c with different preconditioners on cpus and gpus.
I tried to run KSP/ex2.c with -vec_type cuda and -mat_type aijcuda noticed there was no gpu flops recorded in my log file.
Many thanks,
Karthik.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/dcc757f3/attachment.html>
