[petsc-users] [External] Re: request to add an option similar to use_omp_threads for mumps to cusparse solver
Junchao Zhang junchao.zhang at gmail.com
Wed Oct 13 09:18:24 CDT 2021
On Tue, Oct 12, 2021 at 1:07 PM Mark Adams <mfadams at lbl.gov> wrote:
> On Tue, Oct 12, 2021 at 1:45 PM Chang Liu <cliu at pppl.gov> wrote:
>> Hi Mark,
>> The option I use is like
>> -pc_type bjacobi -pc_bjacobi_blocks 16 -ksp_type fgmres -mat_type
>> aijcusparse *-sub_pc_factor_mat_solver_type cusparse *-sub_ksp_type
>> preonly *-sub_pc_type lu* -ksp_max_it 2000 -ksp_rtol 1.e-300 -ksp_atol
>> 1.e-300
> Note, If you use -log_view the last column (rows are the method like
> MatFactorNumeric) has the percent of work in the GPU.
> Junchao:  *This* implies that we have a cuSparse LU factorization. Is
> that correct? (I don't think we do)
No, we don't have cuSparse LU factorization.  If you check
MatLUFactorSymbolic_SeqAIJCUSPARSE(),you will find it calls
MatLUFactorSymbolic_SeqAIJ()
instead.
So I don't understand Chang's idea. Do you want to make bigger blocks?
> I think this one do both factorization and solve on gpu.
>> You can check the runex72_aijcusparse.sh file in petsc install
>> directory, and try it your self (this is only lu factorization without
>> iterative solve).
>> Chang
>> On 10/12/21 1:17 PM, Mark Adams wrote:
>> > On Tue, Oct 12, 2021 at 11:19 AM Chang Liu <cliu at pppl.gov
>> > <mailto:cliu at pppl.gov>> wrote:
>> >     Hi Junchao,
>> >     No I only needs it to be transferred within a node. I use
>> block-Jacobi
>> >     method and GMRES to solve the sparse matrix, so each direct solver
>> will
>> >     take care of a sub-block of the whole matrix. In this way, I can use
>> >     one
>> >     GPU to solve one sub-block, which is stored within one node.
>> >     It was stated in the documentation that cusparse solver is slow.
>> >     However, in my test using ex72.c, the cusparse solver is faster than
>> >     mumps or superlu_dist on CPUs.
>> > Are we talking about the factorization, the solve, or both?
>> > We do not have an interface to cuSparse's LU factorization (I just
>> > learned that it exists a few weeks ago).
>> > Perhaps your fast "cusparse solver" is '-pc_type lu -mat_type
>> > aijcusparse' ? This would be the CPU factorization, which is the
>> > dominant cost.
>> >     Chang
>> >     On 10/12/21 10:24 AM, Junchao Zhang wrote:
>> >      > Hi, Chang,
>> >      >     For the mumps solver, we usually transfers matrix and vector
>> >     data
>> >      > within a compute node.  For the idea you propose, it looks like
>> >     we need
>> >      > to gather data within MPI_COMM_WORLD, right?
>> >      >     Mark, I remember you said cusparse solve is slow and you
>> would
>> >      > rather do it on CPU. Is it right?
>> >      > --Junchao Zhang
>> >      > On Mon, Oct 11, 2021 at 10:25 PM Chang Liu via petsc-users
>> >      > <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
>> >     <mailto:petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>>
>> >     wrote:
>> >      >     Hi,
>> >      >     Currently, it is possible to use mumps solver in PETSC with
>> >      >     -mat_mumps_use_omp_threads option, so that multiple MPI
>> >     processes will
>> >      >     transfer the matrix and rhs data to the master rank, and then
>> >     master
>> >      >     rank will call mumps with OpenMP to solve the matrix.
>> >      >     I wonder if someone can develop similar option for cusparse
>> >     solver.
>> >      >     Right now, this solver does not work with mpiaijcusparse. I
>> >     think a
>> >      >     possible workaround is to transfer all the matrix data to
>> one MPI
>> >      >     process, and then upload the data to GPU to solve. In this
>> >     way, one can
>> >      >     use cusparse solver for a MPI program.
>> >      >     Chang
>> >      >     Chang Liu
>> >      >     Staff Research Physicist
>> >      >     +1 609 243 3438
>> >      > cliu at pppl.gov <mailto:cliu at pppl.gov> <mailto:cliu at pppl.gov
>> >      >     Princeton Plasma Physics Laboratory
>> >      >     100 Stellarator Rd, Princeton NJ 08540, USA
>> >     Chang Liu
>> >     +1 609 243 3438
>> Chang Liu
>> +1 609 243 3438
>> cliu at pppl.gov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211013/b302d945/attachment.html>
