[petsc-users] Still reachable memory in valgrind
Pierre Seize
pierre.seize at onera.fr
Tue Oct 12 10:06:50 CDT 2021
With 3.14 : both malloc and PetscMalloc1 are definitely lost, which is
what I want:
==5463== Memcheck, a memory error detector
==5463== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
==5463== Using Valgrind-3.12.0 and LibVEX; rerun with -h for copyright info
==5463== Command: ./build/bin/yanss data/box.yaml
==5463==
==5463==
==5463== HEAP SUMMARY:
==5463== in use at exit: 48 bytes in 3 blocks
==5463== total heap usage: 2,092 allocs, 2,089 frees, 9,139,664 bytes
allocated
==5463==
==5463== 8 bytes in 1 blocks are definitely lost in loss record 1 of 3
==5463== at 0x4C29BE3: malloc (vg_replace_malloc.c:299)
==5463== by 0x4191A1: main (main.c:62)
==5463==
==5463== 8 bytes in 1 blocks are definitely lost in loss record 2 of 3
==5463== at 0x4C2BE2D: memalign (vg_replace_malloc.c:858)
==5463== by 0x5655AEF: PetscMallocAlign (mal.c:52)
==5463== by 0x5657465: PetscMallocA (mal.c:425)
==5463== by 0x4191D3: main (main.c:63)
==5463==
==5463== LEAK SUMMARY:
==5463== definitely lost: 16 bytes in 2 blocks
==5463== indirectly lost: 0 bytes in 0 blocks
==5463== possibly lost: 0 bytes in 0 blocks
==5463== still reachable: 32 bytes in 1 blocks
==5463== suppressed: 0 bytes in 0 blocks
==5463== Reachable blocks (those to which a pointer was found) are not
shown.
==5463== To see them, rerun with: --leak-check=full --show-leak-kinds=all
==5463==
==5463== For counts of detected and suppressed errors, rerun with: -v
==5463== ERROR SUMMARY: 2 errors from 2 contexts (suppressed: 0 from 0)
but on a more recent version, the lost memory from PetscMalloc1 is
marked ad reachable. It bothers me as I use valgrind to make sure I free
everything. Usually the lost memory would be reported right away, but
now it isn't.
If I understand Barry's answer, this is because the memory block is
large ("1,636 bytes in 1 blocks") and valgrind gives up on this block
tracing ? Then out of curiosity, why is this block 8 bytes in 3.14 and
1636 bytes today ?
Thank you for your time
Pierre
On 12/10/21 16:51, Barry Smith wrote:
> Do you have the valgrind output from 3.14 ?
>> 1,636 bytes in 1 blocks are still reachable in loss record 4
>> > of 4
>> > ==2036== at 0x4C2BE2D: memalign (vg_replace_malloc.c:858)
>> > ==2036== by 0x54AC0CB: PetscMallocAlign (mal.c:54)
>> > ==2036== by 0x54AFBA9: PetscTrMallocDefault (mtr.c:183)
>> > ==2036== by 0x54ADDD2: PetscMallocA (mal.c:423)
>> > ==2036== by 0x41A52F: main (main.c:9)
>> > ==2036==
> Given the large amount of memory in the block I think tracing of
> PETSc's memory allocation is turned on with this run, this may mean
> the memory is reachable but with your 3.14 run I would guess the
> memory size is 8 bytes and tracing is not turned on so the memory is
> listed as "lost". But I do not understand the subtleties of reachable.
> Barry
>> On Oct 12, 2021, at 10:38 AM, Pierre Seize <Pierre.Seize at onera.fr
>> <mailto:Pierre.Seize at onera.fr>> wrote:
>> The "bug" is that memory from PetscMalloc1 that is not freed is
>> reported as "definitely lost" in v3.14 (OK) but as "still reachable"
>> in today's release (not OK).
>> Here I forget to free the memory on purpose, I would like valgrind to
>> report it's lost and not still reachable.
>> Pierre
>> On 12/10/21 16:24, Matthew Knepley wrote:
>>> On Tue, Oct 12, 2021 at 10:16 AM Pierre Seize <pierre.seize at onera.fr
>>> <mailto:pierre.seize at onera.fr>> wrote:
>>> Sorry, I should have tried this before:
>>> I checked out to v3.14, and now both malloc and PetscMalloc1 are
>>> reported as definitely lost, so I would say it's a bug.
>>> I am not sure what would be the bug. This is correctly reporting
>>> that you did not free the memory.
>>> Thanks,
>>> Matt
>>> Pierre
>>> On 12/10/21 15:58, Pierre Seize wrote:
>>> > Hello petsc-users
>>> > I am using Valgrind with my PETSc application, and I noticed
>>> something:
>>> > 1 #include <petscsys.h>
>>> > 2
>>> > 3 int main(int argc, char **argv){
>>> > 4 PetscErrorCode ierr = 0;
>>> > 5
>>> > 6 ierr = PetscInitialize(&argc, &argv, NULL, ""); if (ierr)
>>> return
>>> > ierr;
>>> > 7 PetscReal *foo;
>>> > 8 malloc(sizeof(PetscReal));
>>> > 9 ierr = PetscMalloc1(1, &foo); CHKERRQ(ierr);
>>> > 10 ierr = PetscFinalize();
>>> > 11 return ierr;
>>> > 12 }
>>> > With this example, with today's release branch, I've got this
>>> Valgrind
>>> > result (--leak-check=full --show-leak-kinds=all):
>>> > ==2036== Memcheck, a memory error detector
>>> > ==2036== Copyright (C) 2002-2015, and GNU GPL'd, by Julian
>>> Seward et al.
>>> > ==2036== Using Valgrind-3.12.0 and LibVEX; rerun with -h for
>>> copyright
>>> > info
>>> > ==2036== Command: ./build/bin/yanss data/box.yaml
>>> > ==2036==
>>> > ==2036==
>>> > ==2036== HEAP SUMMARY:
>>> > ==2036== in use at exit: 1,746 bytes in 4 blocks
>>> > ==2036== total heap usage: 2,172 allocs, 2,168 frees, 9,624,690
>>> > bytes allocated
>>> > ==2036==
>>> > ==2036== 8 bytes in 1 blocks are definitely lost in loss
>>> record 1 of 4
>>> > ==2036== at 0x4C29BE3: malloc (vg_replace_malloc.c:299)
>>> > ==2036== by 0x41A4FD: main (main.c:8)
>>> > ==2036==
>>> > ==2036== 32 bytes in 1 blocks are still reachable in loss
>>> record 2 of 4
>>> > ==2036== at 0x4C2B975: calloc (vg_replace_malloc.c:711)
>>> > ==2036== by 0xACF461F: _dlerror_run (in
>>> /usr/lib64/libdl-2.17.so <http://libdl-2.17.so/>)
>>> > ==2036== by 0xACF4127: dlsym (in /usr/lib64/libdl-2.17.so
>>> > ==2036== by 0x56ECBB5: PetscInitialize_Common (pinit.c:785)
>>> > ==2036== by 0x56EF325: PetscInitialize (pinit.c:1203)
>>> > ==2036== by 0x41A4E2: main (main.c:6)
>>> > ==2036==
>>> > ==2036== 70 bytes in 1 blocks are still reachable in loss
>>> record 3 of 4
>>> > ==2036== by 0x400F0D0: _dl_signal_error (in
>>> /usr/lib64/ld-2.17.so <http://ld-2.17.so/>)
>>> > ==2036== by 0x400F26D: _dl_signal_cerror (in
>>> > ==2036== by 0x400A4BC: _dl_lookup_symbol_x (in
>>> > ==2036== by 0x83B9F02: do_sym (in /usr/lib64/libc-2.17.so
>>> <http://libc-2.17.so/>)
>>> > ==2036== by 0xACF40D3: dlsym_doit (in
>>> > ==2036== by 0x400F2D3: _dl_catch_error (in
>>> > ==2036== by 0xACF45BC: _dlerror_run (in
>>> > ==2036==
>>> > ==2036== 1,636 bytes in 1 blocks are still reachable in loss
>>> record 4
>>> > of 4
>>> > ==2036==
>>> > ==2036== LEAK SUMMARY:
>>> > ==2036== definitely lost: 8 bytes in 1 blocks
>>> > ==2036== indirectly lost: 0 bytes in 0 blocks
>>> > ==2036== possibly lost: 0 bytes in 0 blocks
>>> > ==2036== still reachable: 1,738 bytes in 3 blocks
>>> > ==2036== suppressed: 0 bytes in 0 blocks
>>> > ==2036==
>>> > ==2036== For counts of detected and suppressed errors, rerun
>>> with: -v
>>> > ==2036== ERROR SUMMARY: 1 errors from 1 contexts (suppressed:
>>> 0 from 0)
>>> > The first report is the malloc on line 8, fine.
>>> > The second and the third correspond to still reachable memory
>>> from
>>> > PetscInitialize on line 6, I often got these so I usually
>>> discard it.
>>> > The fourth and last is the one that worries me : the memory from
>>> > PetscMalloc1 on line 9 is reported as "still reachable", but I
>>> don't
>>> > think it should.
>>> > Is there something I do not understand, or is this a bug ?
>>> > Thanks in advance,
>>> > Pierre
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/%7Eknepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211012/575e472d/attachment-0001.html>
