[petsc-users] HDF5 time step count
Matthew Knepley
knepley at gmail.com
Sun Oct 10 17:59:55 CDT 2021
On Sun, Oct 10, 2021 at 6:51 PM Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> hi
> Is there any way to query the PETSc HDF5 viewer to find the number of
> time steps in the file?
> A common use case I have is that an HDF5 file from a previous simulation
> is used to get initial conditions for a subsequent run. The most common
> thing you want to do is restart from the last set of results in the
> previous output. To do that you need to know how many time steps there
> are, so you can set the output index to be the last one.
> I thought maybe I could just query the size of the "time" dataset, but I
> can't even see any obvious way to do that using the viewer functions.
There is nothing in there that does it right now. Do you know how to do it
in HDF5?
If so, I can put it in. Otherwise, I will have to learn more HDF5 :)
Matt
> Regards, Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211010/c113916e/attachment.html>
