[petsc-users] petsc4py - Spike in memory usage when loading a matrix in parallel
    Matthew Knepley
    knepley at gmail.com
    Thu Oct  7 11:32:49 CDT 2021
On Thu, Oct 7, 2021 at 11:59 AM Michael Werner <michael.werner at dlr.de>
wrote:
> Its twice the memory of the entire matrix (when stored on one process). I
> also just sent you the valgrind results, both for a serial run and a
> parallel run. The size on disk of the matrix I used is 20 GB.
> In the serial run, valgrind shows a peak memory usage of 21GB, while in
> the parallel run (with 4 processes) each process shows a peak memory usage
> of 10.8GB
Barry is right that at least proc 0 must have twice its own memory, since
it loads the other pieces. That makes 10GB sounds correct.
     Matt
> Best regards,
> Michael
> On 07.10.21 17:55, Barry Smith wrote:
> On Oct 7, 2021, at 11:35 AM, Michael Werner <michael.werner at dlr.de> wrote:
> Currently I'm using psutil to query every process for its memory usage and
> sum it up. However, the spike was only visible in top (I had a call to
> psutil right before and after A.load(viewer), and both reported only 50 GB
> of RAM usage). That's why I thought it might be directly tied to loading
> the matrix. However, I also had the problem that the computation crashed
> due to running out of memory while loading a matrix that should in theory
> fit into memory. In that case I would expect the OS to free unused meory
> immediatly, right?
> Concerning Barry's questions: the matrix is a sparse matrix and is
> originally created sequentially as SEQAIJ. However, it is then loaded as
> MPIAIJ, and if I look at the memory usage of the various processes, they
> fill up one after another, just as described. Is the origin of the matrix
> somehow preserved in the binary file? I was under the impression that the
> binary format was agnostic to the number of processes?
>  The file format is independent of the number of processes that created it.
> I also varied the number of processes between 1 and 60, as soon as I use
> more than one process I can observe the spike (and its always twice the
> memory, no matter how many processes I'm using).
>   Twice the size of the entire matrix (when stored on one process) or
> twice the size of the resulting matrix stored on the first rank? The latter
> is exactly as expected, since rank 0 has to load the part of the matrix
> destined for the next rank and hence for a short time contains its own part
> of the matrix and the part of one other rank.
>   Barry
> I also tried running Valgrind with the --tool=massif option. However, I
> don't know what to look for. I can send you the output file separately, if
> it helps.
> Best regards,
> Michael
> On 07.10.21 16:09, Matthew Knepley wrote:
> On Thu, Oct 7, 2021 at 10:03 AM Barry Smith <bsmith at petsc.dev> wrote:
>>    How many ranks are you using? Is it a sparse matrix with MPIAIJ?
>>    The intention is that for parallel runs the first rank reads in its
>> own part of the matrix, then reads in the part of the next rank and sends
>> it, then reads the part of the third rank and sends it etc. So there should
>> not be too much of a blip in memory usage. You can run valgrind with the
>> option for tracking memory usage to see exactly where in the code the blip
>> occurs; it could be a regression occurred in the code making it require
>> more memory. But internal MPI buffers might explain some blip.
> Is it possible that we free the memory, but the OS has just not given back
> that memory for use yet? How are you measuring memory usage?
>   Thanks,
>      Matt
>>   Barry
>> > On Oct 7, 2021, at 9:50 AM, Michael Werner <michael.werner at dlr.de>
>> wrote:
>> > Hello,
>> > I noticed that there is a peak in memory consumption when I load an
>> > existing matrix into PETSc. The matrix is previously created by an
>> > external program and saved in the PETSc binary format.
>> > The code I'm using in petsc4py is simple:
>> > viewer = PETSc.Viewer().createBinary(<path/to/existing/matrix>, "r",
>> > comm=PETSc.COMM_WORLD)
>> > A = PETSc.Mat().create(comm=PETSc.COMM_WORLD)
>> > A.load(viewer)
>> > When I run this code in serial, the memory consumption of the process is
>> > about 50GB RAM, similar to the file size of the saved matrix. However,
>> > if I run the code in parallel, for a few seconds the memory consumption
>> > of the process doubles to around 100GB RAM, before dropping back down to
>> > around 50GB RAM. So it seems as if, for some reason, the matrix is
>> > copied after it is read into memory. Is there a way to avoid this
>> > behaviour? Currently, it is a clear bottleneck in my code.
>> > I tried setting the size of the matrix and to explicitly preallocate the
>> > necessary NNZ (with A.setSizes(dim) and A.setPreallocationNNZ(nnz),
>> > respectively) before loading, but that didn't help.
>> > As mentioned above, I'm using petsc4py together with PETSc-3.16 on a
>> > Linux workstation.
>> > Best regards,
>> > Michael Werner
>> > ____________________________________________________
>> > Deutsches Zentrum für Luft- und Raumfahrt e.V. (DLR)
>> > Institut für Aerodynamik und Strömungstechnik | Bunsenstr. 10 | 37073
>> Göttingen
>> > Michael Werner
>> > Telefon 0551 709-2627 | Telefax 0551 709-2811 | Michael.Werner at dlr.de
>> > DLR.de
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211007/52571d2d/attachment-0001.html>
