[petsc-users] Convergence rate for spatially varying Helmholtz system
Matthew Knepley
knepley at gmail.com
Fri Oct 1 05:53:48 CDT 2021
On Fri, Oct 1, 2021 at 2:10 AM Ramakrishnan Thirumalaisamy <
rthirumalaisam1857 at sdsu.edu> wrote:
> We fixed the issue. The linear operator in the matrix-free solver was set
> up correctly, whereas the linear operator in the preconditioner was not set
> up correctly (it was lagging in time). After setting the linear operators
> correctly, we see that the diagonal system is solved in 1 iteration. Thank
> you.
Cool.
Matt
> On Thu, Sep 30, 2021 at 5:49 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Sep 30, 2021 at 6:58 PM Amneet Bhalla <mail2amneet at gmail.com>
>> wrote:
>>>> For a diagonal system with this modest range of values Jacobi should
>>>> converge in a single iteration.
>>> This is what I wanted to confirm (and my expectation also). There could
>>> be a bug in the way we are setting up the linear operators in the
>>> preconditioner and the matrix-free solver. We need to do some debugging.
>>> (with regard to the diagonal).
>>> We have printed the matrix and viewed it in Matlab. It is a diagonal
>>> matrix.
>> Can you send us the matrix? This definitely should converge in 1 iterate
>> now, so something I do not understand is going on.
>> I will take any format you've got :)
>> Thanks,
>> Matt
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211001/4fd4072f/attachment.html>
