[petsc-users] DMPlex shared node indexing
Barry Smith bsmith at petsc.dev
Fri Nov 26 09:34:45 CST 2021
   Actually, with DMPLEX the ghost vertices are not at the end of the local vector, they can be anywhere within the list.
   But I have a work-in-progress branch https://gitlab.com/petsc/petsc/-/merge_requests/4542 <https://gitlab.com/petsc/petsc/-/merge_requests/4542> that labels the ghost locations and moves them to the end. You are welcome to try it.
  Barry
> On Nov 26, 2021, at 8:16 AM, Mark Adams <mfadams at lbl.gov> wrote:
> First, ghost vertices only show up in "local" (vs "global") vectors and the ghost values are ordered after the locally owned ones.
> Others might have more to add.
> Mark
> On Fri, Nov 26, 2021 at 12:49 AM 袁煕 <yuanxi at advancesoft.jp <mailto:yuanxi at advancesoft.jp>> wrote:
> Dear PETSc-team,
> When the mesh is distributed, the vertices are renumbered and some vertices are shared by neighboring CPUs. My question is:
> 1. How to check which vertice is a ghost one?
> 2. Are those ghost vertices always at the end of vertices list? If not
> 3. Are there simple ways to let those ghost vertices come after owned ones?
> Many thanks
> Yuan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211126/79e261af/attachment.html>
