[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Wed Nov 10 14:08:22 CST 2021
Hi Matthew,
we are continuing our developments around the overlap (funny to say... )
and we have a question about the "adjacency" used.
It is said into the documentation of DMPlexDistributeOverlap that:
"The user can control the definition of adjacency for the mesh using
DMSetAdjacency(). They should choose the combination appropriate for the
function representation on the mesh."
We expected that this could influence whether the overlap computed
includes cells that touch a domain by only one vertex for example.
But we tried "all" combinations of useCone and useClosure on each DM we
create in for the computation of the overlap (as in ex44.c we shared
with you) but the computed overlap is always the same!
However, we have not understood which "field" number to pass, so we used
both PETSC_DEFAULT and DMSetBasicAdjacency but it makes no differences...
Any clue what's wrong?
Eric
On 2021-11-03 7:41 a.m., Matthew Knepley wrote:
> On Tue, Nov 2, 2021 at 10:27 PM Eric Chamberland
> <Eric.Chamberland at giref.ulaval.ca
> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
>     Hi Matthew,
>     yes, it all works now!
>     I modified the example to do a NaturalToGlobal then a
>     GlobalToNatural and test if we have the good result...
>     The test would just need that we "force" the computed partition to
>     a given result, then we could check the result of the
>     NaturalToGlobal independently of the partitioner...
>     Thanks a lot!
> No problem. Thanks for generating a great test. I will get this into
> the CI tonight.
>   Thanks,
>      Matt
>     Eric
>     On 2021-11-02 5:16 a.m., Matthew Knepley wrote:
>>     On Mon, Nov 1, 2021 at 5:24 PM Eric Chamberland
>>         Hi Matthew,
>>         ok, good news then! :)
>>         Meanwhile, I tested it the "other way" with
>>         DMPlexGlobalToNaturalBegin/End and it does not give a
>>         "sensed" result neither.
>>         Probably it does something like "GlobalToSequential" too?
>>     I am not sure how it worked before, but I think I have it fixed.
>>     I get the output you expect for the test. I force-pushed the branch
>>     so you will have to check it out again.
>>       Thanks!
>>          Matt
>>         Thanks!
>>         Eric
>>         On 2021-11-01 3:25 p.m., Matthew Knepley wrote:
>>>         On Sun, Oct 31, 2021 at 10:07 AM Eric Chamberland
>>>             Hi Matthew,
>>>             we do not know if DMPlexNaturalToGlobalBegin/End is
>>>             buggy or if it is our comprehension of what it should do
>>>             that is wrong...
>>>             Would you just check if what we try to do from line 313
>>>             to 356 is good or wrong?
>>>             The expected result is that the global vector
>>>             "lGlobalVec" contains the element numbers from the
>>>             initial partition that have been put into "lNatVec".
>>>             Thanks a lot for any insights!!
>>>         Okay, I have found the problem.I confess to not actually
>>>         looking very closely at the implementation before.
>>>         GlobalToNatural was assuming that
>>>         the "natural" was also sequential, and looking at it all the
>>>         tests are eq-to-parallel distribution. I need to fix it for
>>>         a parallel natural state. Hopefully
>>>         it will not take me long.
>>>           Thanks,
>>>              Matt
>>>             Eric
>>>             On 2021-10-27 2:32 p.m., Eric Chamberland wrote:
>>>>             Hi Matthew,
>>>>             we continued the example.  Now it must be our misuse of
>>>>             PETSc that produced the wrong result.
>>>>             As stated into the code:
>>>>             // The call to DMPlexNaturalToGlobalBegin/End does not
>>>>             produce our expected result...
>>>>               // In lGlobalVec, we expect to have:
>>>>                * Process [0]
>>>>                * 2.
>>>>                * 4.
>>>>                * 8.
>>>>                * 3.
>>>>                * 9.
>>>>                * Process [1]
>>>>                * 1.
>>>>                * 5.
>>>>                * 7.
>>>>                * 0.
>>>>                * 6.
>>>>                * but we obtained:
>>>>                * Process [0]
>>>>                * 2.
>>>>                * 4.
>>>>                * 8.
>>>>                * 0.
>>>>                * 0.
>>>>                * Process [1]
>>>>                * 0.
>>>>                * 0.
>>>>                * 0.
>>>>                * 0.
>>>>                * 0.
>>>>             (see attached ex44.c)
>>>>             Thanks,
>>>>             Eric
>>>>             On 2021-10-27 1:25 p.m., Eric Chamberland wrote:
>>>>>             Great!
>>>>>             Thanks Matthew, it is working for me up to that point!
>>>>>             We are continuing the ex44.c and forward it to you at
>>>>>             the next blocking point...
>>>>>             Eric
>>>>>             On 2021-10-27 11:14 a.m., Matthew Knepley wrote:
>>>>>>             On Wed, Oct 27, 2021 at 8:29 AM Eric Chamberland
>>>>>>                 Hi Matthew,
>>>>>>                 the smallest mesh which crashes the code is a 2x5
>>>>>>                 mesh:
>>>>>>                 See the modified ex44.c
>>>>>>                 With smaller meshes(2x2, 2x4, etc), it passes...
>>>>>>                 But it bugs latter when I try to use
>>>>>>                 DMPlexNaturalToGlobalBegin but let's keep that
>>>>>>                 other problem for later...
>>>>>>                 Thanks a lot for helping digging into this! :)
>>>>>>             I have made a small fix in this branch
>>>>>>             https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-g2n
>>>>>>             <https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-g2n>
>>>>>>             It seems to run for me. Can you check it?
>>>>>>               Thanks,
>>>>>>                  Matt
>>>>>>                 Eric
>>>>>>                 (sorry if you received this for a 2nd times, I
>>>>>>                 have trouble with my mail)
>>>>>>                 On 2021-10-26 4:35 p.m., Matthew Knepley wrote:
>>>>>>>                 On Tue, Oct 26, 2021 at 1:35 PM Eric Chamberland
>>>>>>>                     Here is a screenshot of the partition I hard
>>>>>>>                     coded (top) and vertices/element numbers (down):
>>>>>>>                     I have not yet modified the ex44.c example
>>>>>>>                     to properly assign the coordinates...
>>>>>>>                     (but I would not have done it like it is in
>>>>>>>                     the last version because the sCoords array
>>>>>>>                     is the global array with global vertices number)
>>>>>>>                     I will have time to do this tomorrow...
>>>>>>>                     Maybe I can first try to reproduce all this
>>>>>>>                     with a smaller mesh?
>>>>>>>                 That might make it easier to find a problem.
>>>>>>>                   Thanks!
>>>>>>>                      Matt
>>>>>>>                     Eric
>>>>>>>                     On 2021-10-26 9:46 a.m., Matthew Knepley wrote:
>>>>>>>>                     Okay, I ran it. Something seems off with
>>>>>>>>                     the mesh. First, I cannot simply explain
>>>>>>>>                     the partition. The number of shared
>>>>>>>>                     vertices and edges
>>>>>>>>                     does not seem to come from a straight cut.
>>>>>>>>                     Second, the mesh look scrambled on output.
>>>>>>>>                       Thanks,
>>>>>>>>                         Matt
>>>>>>>>                     On Sun, Oct 24, 2021 at 11:49 PM Eric
>>>>>>>>                     Chamberland
>>>>>>>>                     wrote:
>>>>>>>>                         Hi Matthew,
>>>>>>>>                         ok, I started back from your ex44.c
>>>>>>>>                         example and added the global array of
>>>>>>>>                         coordinates. I just have to code the
>>>>>>>>                         creation of the local coordinates now.
>>>>>>>>                         Eric
>>>>>>>>                         On 2021-10-20 6:55 p.m., Matthew
>>>>>>>>                         Knepley wrote:
>>>>>>>>>                         On Wed, Oct 20, 2021 at 3:06 PM Eric
>>>>>>>>>                         Chamberland
>>>>>>>>>                         wrote:
>>>>>>>>>                             Hi Matthew,
>>>>>>>>>                             we tried to reproduce the error in
>>>>>>>>>                             a simple example.
>>>>>>>>>                             The context is the following: We
>>>>>>>>>                             hard coded the mesh and initial
>>>>>>>>>                             partition into the code (see
>>>>>>>>>                             sConnectivity and
>>>>>>>>>                             sInitialPartition) for 2 ranks and
>>>>>>>>>                             try to create a section in order
>>>>>>>>>                             to use the
>>>>>>>>>                             function to retreive our initial
>>>>>>>>>                             element numbers.
>>>>>>>>>                             Now the call to DMPlexDistribute
>>>>>>>>>                             give different errors depending on
>>>>>>>>>                             what type of component we ask the
>>>>>>>>>                             field to be created.  For our
>>>>>>>>>                             objective, we would like a global
>>>>>>>>>                             field to be created on elements
>>>>>>>>>                             only (like a P0 interpolation).
>>>>>>>>>                             We now have the following error
>>>>>>>>>                             generated:
>>>>>>>>>                             [0]PETSC ERROR:
>>>>>>>>>                             --------------------- Error
>>>>>>>>>                             Message
>>>>>>>>>                             [0]PETSC ERROR: Petsc has
>>>>>>>>>                             generated inconsistent data
>>>>>>>>>                             [0]PETSC ERROR: Inconsistency in
>>>>>>>>>                             indices, 18 should be 17
>>>>>>>>>                             [0]PETSC ERROR: See
>>>>>>>>>                             https://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>>>>>>                             <https://www.mcs.anl.gov/petsc/documentation/faq.html>
>>>>>>>>>                             for trouble shooting.
>>>>>>>>>                             [0]PETSC ERROR: Petsc Release
>>>>>>>>>                             Version 3.15.0, Mar 30, 2021
>>>>>>>>>                             [0]PETSC ERROR: ./bug on a  named
>>>>>>>>>                             rohan by ericc Wed Oct 20 14:52:36
>>>>>>>>>                             2021
>>>>>>>>>                             [0]PETSC ERROR: Configure options
>>>>>>>>>                             --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7
>>>>>>>>>                             --with-mpi-compilers=1
>>>>>>>>>                             --with-mpi-dir=/opt/openmpi-4.1.0_gcc7
>>>>>>>>>                             --with-cxx-dialect=C++14
>>>>>>>>>                             --with-make-np=12
>>>>>>>>>                             --with-shared-libraries=1
>>>>>>>>>                             --with-debugging=yes
>>>>>>>>>                             --with-memalign=64
>>>>>>>>>                             --with-visibility=0
>>>>>>>>>                             --with-64-bit-indices=0
>>>>>>>>>                             --download-ml=yes
>>>>>>>>>                             --download-mumps=yes
>>>>>>>>>                             --download-superlu=yes
>>>>>>>>>                             --download-hpddm=yes
>>>>>>>>>                             --download-slepc=yes
>>>>>>>>>                             --download-superlu_dist=yes
>>>>>>>>>                             --download-parmetis=yes
>>>>>>>>>                             --download-ptscotch=yes
>>>>>>>>>                             --download-metis=yes
>>>>>>>>>                             --download-strumpack=yes
>>>>>>>>>                             --download-suitesparse=yes
>>>>>>>>>                             --download-hypre=yes
>>>>>>>>>                             --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>>>>>>>                             --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>>>>>>>                             --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>>>>>>>                             --with-scalapack=1
>>>>>>>>>                             --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include
>>>>>>>>>                             --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>>>>>>>                             -lmkl_scalapack_lp64
>>>>>>>>>                             -lmkl_blacs_openmpi_lp64"
>>>>>>>>>                             [0]PETSC ERROR: #1
>>>>>>>>>                             PetscSFCreateSectionSF() at
>>>>>>>>>                             /tmp/ompi-opt/petsc-3.15.0-debug/src/vec/is/sf/utils/sfutils.c:409
>>>>>>>>>                             [0]PETSC ERROR: #2
>>>>>>>>>                             DMPlexCreateGlobalToNaturalSF() at
>>>>>>>>>                             /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:184
>>>>>>>>>                             [0]PETSC ERROR: #3
>>>>>>>>>                             DMPlexDistribute() at
>>>>>>>>>                             /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexdistribute.c:1733
>>>>>>>>>                             [0]PETSC ERROR: #4 main() at
>>>>>>>>>                             bug_section.cc:159
>>>>>>>>>                             [0]PETSC ERROR: No PETSc Option
>>>>>>>>>                             Table entries
>>>>>>>>>                             [0]PETSC ERROR:
>>>>>>>>>                             ----------------End of Error
>>>>>>>>>                             Message -------send entire error
>>>>>>>>>                             message to petsc-maint at mcs.anl.gov
>>>>>>>>>                             <mailto:petsc-maint at mcs.anl.gov>----------
>>>>>>>>>                             Hope the attached code is
>>>>>>>>>                             self-explaining, note that to make
>>>>>>>>>                             it short, we have not included the
>>>>>>>>>                             final part of it, just the buggy
>>>>>>>>>                             part we are encountering right now...
>>>>>>>>>                             Thanks for your insights,
>>>>>>>>>                         Thanks for making the example. I
>>>>>>>>>                         tweaked it slightly. I put in a test
>>>>>>>>>                         case that just makes a parallel 7 x 10
>>>>>>>>>                         quad mesh. This works
>>>>>>>>>                         fine. Thus I think it must be
>>>>>>>>>                         something connected with the original
>>>>>>>>>                         mesh. It is hard to get a handle on it
>>>>>>>>>                         without the coordinates.
>>>>>>>>>                         Do you think you could put the
>>>>>>>>>                         coordinate array in? I have added the
>>>>>>>>>                         code to load them (see attached file).
>>>>>>>>>                           Thanks,
>>>>>>>>>                          Matt
>>>>>>>>>                             Eric
>>>>>>>>>                             On 2021-10-06 9:23 p.m., Matthew
>>>>>>>>>                             Knepley wrote:
>>>>>>>>>>                             On Wed, Oct 6, 2021 at 5:43 PM
>>>>>>>>>>                             Eric Chamberland
>>>>>>>>>>                             wrote:
>>>>>>>>>>                                 Hi Matthew,
>>>>>>>>>>                                 we tried to use that. Now, we
>>>>>>>>>>                                 discovered that:
>>>>>>>>>>                                 1- even if we "ask" for
>>>>>>>>>>                                 sfNatural creation with
>>>>>>>>>>                                 DMSetUseNatural, it is not
>>>>>>>>>>                                 created because
>>>>>>>>>>                                 looks for a "section": this
>>>>>>>>>>                                 is not documented in
>>>>>>>>>>                                 DMSetUseNaturalso we are
>>>>>>>>>>                                 asking ourselfs: "is this a
>>>>>>>>>>                                 permanent feature or a
>>>>>>>>>>                                 temporary situation?"
>>>>>>>>>>                             I think explaining this will help
>>>>>>>>>>                             clear up a lot.
>>>>>>>>>>                             What the Natural2Global map does
>>>>>>>>>>                             is permute a solution vector into
>>>>>>>>>>                             the ordering that it would have
>>>>>>>>>>                             had prior to mesh distribution.
>>>>>>>>>>                             Now, in order to do this
>>>>>>>>>>                             permutation, I need to know the
>>>>>>>>>>                             original (global) data layout. If
>>>>>>>>>>                             it is not specified _before_
>>>>>>>>>>                             distribution, we
>>>>>>>>>>                             cannot build the permutation. The
>>>>>>>>>>                             section describes the data
>>>>>>>>>>                             layout, so I need it before
>>>>>>>>>>                             distribution.
>>>>>>>>>>                             I cannot think of another way
>>>>>>>>>>                             that you would implement this,
>>>>>>>>>>                             but if you want something else,
>>>>>>>>>>                             let me know.
>>>>>>>>>>                                 2- We then tried to create a
>>>>>>>>>>                                 "section" in different
>>>>>>>>>>                                 manners: we took the code
>>>>>>>>>>                                 into the example
>>>>>>>>>>                                 petsc/src/dm/impls/plex/tests/ex15.c.
>>>>>>>>>>                                 However, we ended up with a
>>>>>>>>>>                                 segfault:
>>>>>>>>>>                                 corrupted size vs. prev_size
>>>>>>>>>>                                 [rohan:07297] *** Process
>>>>>>>>>>                                 received signal ***
>>>>>>>>>>                                 [rohan:07297] Signal: Aborted (6)
>>>>>>>>>>                                 [rohan:07297] Signal code: (-6)
>>>>>>>>>>                                 [rohan:07297] [ 0]
>>>>>>>>>>                                 /lib64/libpthread.so.0(+0x13f80)[0x7f6f13be3f80]
>>>>>>>>>>                                 [rohan:07297] [ 1]
>>>>>>>>>>                                 /lib64/libc.so.6(gsignal+0x10b)[0x7f6f109b718b]
>>>>>>>>>>                                 [rohan:07297] [ 2]
>>>>>>>>>>                                 /lib64/libc.so.6(abort+0x175)[0x7f6f109b8585]
>>>>>>>>>>                                 [rohan:07297] [ 3]
>>>>>>>>>>                                 /lib64/libc.so.6(+0x7e2f7)[0x7f6f109fb2f7]
>>>>>>>>>>                                 [rohan:07297] [ 4]
>>>>>>>>>>                                 /lib64/libc.so.6(+0x857ea)[0x7f6f10a027ea]
>>>>>>>>>>                                 [rohan:07297] [ 5]
>>>>>>>>>>                                 /lib64/libc.so.6(+0x86036)[0x7f6f10a03036]
>>>>>>>>>>                                 [rohan:07297] [ 6]
>>>>>>>>>>                                 /lib64/libc.so.6(+0x861a3)[0x7f6f10a031a3]
>>>>>>>>>>                                 [rohan:07297] [ 7]
>>>>>>>>>>                                 /lib64/libc.so.6(+0x88740)[0x7f6f10a05740]
>>>>>>>>>>                                 [rohan:07297] [ 8]
>>>>>>>>>>                                 /lib64/libc.so.6(__libc_malloc+0x1b8)[0x7f6f10a070c8]
>>>>>>>>>>                                 [rohan:07297] [ 9]
>>>>>>>>>>                                 /lib64/libc.so.6(__backtrace_symbols+0x134)[0x7f6f10a8b064]
>>>>>>>>>>                                 [rohan:07297] [10]
>>>>>>>>>>                                 /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z12reqBacktraceRNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE+0x4e)[0x4538ce]
>>>>>>>>>>                                 [rohan:07297] [11]
>>>>>>>>>>                                 /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z15attacheDebuggerv+0x120)[0x4523c0]
>>>>>>>>>>                                 [rohan:07297] [12]
>>>>>>>>>>                                 /home/mefpp_ericc/GIREF/lib/libgiref_dev_Util.so(traitementSignal+0x612)[0x7f6f28f503a2]
>>>>>>>>>>                                 [rohan:07297] [13]
>>>>>>>>>>                                 /lib64/libc.so.6(+0x3a210)[0x7f6f109b7210]
>>>>>>>>>>                                 [rohan:07297] [14]
>>>>>>>>>>                                 /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscTrMallocDefault+0x6fd)[0x7f6f22f1b8ed]
>>>>>>>>>>                                 [rohan:07297] [15]
>>>>>>>>>>                                 /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscMallocA+0x5cd)[0x7f6f22f19c2d]
>>>>>>>>>>                                 [rohan:07297] [16]
>>>>>>>>>>                                 /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscSFCreateSectionSF+0xb48)[0x7f6f23268e18]
>>>>>>>>>>                                 [rohan:07297] [17]
>>>>>>>>>>                                 /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexCreateGlobalToNaturalSF+0x13b2)[0x7f6f241a5602]
>>>>>>>>>>                                 [rohan:07297] [18]
>>>>>>>>>>                                 /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexDistribute+0x39b1)[0x7f6f23fdca21]
>>>>>>>>>>                             I am not sure what happened here,
>>>>>>>>>>                             but if you could send a sample
>>>>>>>>>>                             code, I will figure it out.
>>>>>>>>>>                                 If we do not create a
>>>>>>>>>>                                 section, the call to
>>>>>>>>>>                                 DMPlexDistribute is
>>>>>>>>>>                                 successful, but
>>>>>>>>>>                                 DMPlexGetGlobalToNaturalSF
>>>>>>>>>>                                 return a null SF pointer...
>>>>>>>>>>                             Yes, it just ignores it in this
>>>>>>>>>>                             case because it does not have a
>>>>>>>>>>                             global layout.
>>>>>>>>>>                                 Here are the operations we
>>>>>>>>>>                                 are calling ( this is almost
>>>>>>>>>>                                 the code we are using, I just
>>>>>>>>>>                                 removed verifications and
>>>>>>>>>>                                 creation of the connectivity
>>>>>>>>>>                                 which use our parallel
>>>>>>>>>>                                 structure and code):
>>>>>>>>>>                                   PetscInt* lCells      = 0;
>>>>>>>>>>                                   PetscInt lNumCorners = 0;
>>>>>>>>>>                                   PetscInt lDimMail    = 0;
>>>>>>>>>>                                   PetscInt lnumCells   = 0;
>>>>>>>>>>                                   //At this point we create
>>>>>>>>>>                                 the cells for PETSc expected
>>>>>>>>>>                                 input for
>>>>>>>>>>                                 DMPlexBuildFromCellListParallel
>>>>>>>>>>                                 and set lNumCorners, lDimMail
>>>>>>>>>>                                 and lnumCells to correct values.
>>>>>>>>>>                                   DM lDMBete = 0
>>>>>>>>>>                                 DMPlexCreate(lMPIComm,&lDMBete);
>>>>>>>>>>                                 DMSetDimension(lDMBete,
>>>>>>>>>>                                 lDimMail);
>>>>>>>>>>                                 DMPlexBuildFromCellListParallel(lDMBete,
>>>>>>>>>>                                 lnumCells,
>>>>>>>>>>                                 PETSC_DECIDE,
>>>>>>>>>>                                 pLectureElementsLocaux.reqNbTotalSommets(),
>>>>>>>>>>                                 lNumCorners,
>>>>>>>>>>                                 lCells,
>>>>>>>>>>                                 PETSC_NULL);
>>>>>>>>>>                                   DM lDMBeteInterp = 0;
>>>>>>>>>>                                 DMPlexInterpolate(lDMBete,
>>>>>>>>>>                                 &lDMBeteInterp);
>>>>>>>>>>                                 DMDestroy(&lDMBete);
>>>>>>>>>>                                   lDMBete = lDMBeteInterp;
>>>>>>>>>>                                 DMSetUseNatural(lDMBete,PETSC_TRUE);
>>>>>>>>>>                                   PetscSF lSFMigrationSansOvl
>>>>>>>>>>                                 = 0;
>>>>>>>>>>                                   PetscSF lSFMigrationOvl = 0;
>>>>>>>>>>                                   DM lDMDistribueSansOvl = 0;
>>>>>>>>>>                                   DM lDMAvecOverlap = 0;
>>>>>>>>>>                                 PetscPartitioner lPart;
>>>>>>>>>>                                 DMPlexGetPartitioner(lDMBete,
>>>>>>>>>>                                 &lPart);
>>>>>>>>>>                                 PetscPartitionerSetFromOptions(lPart);
>>>>>>>>>>                                 PetscSection section;
>>>>>>>>>>                                 PetscInt numFields   = 1;
>>>>>>>>>>                                 PetscInt numBC       = 0;
>>>>>>>>>>                                 PetscInt numComp[1]  = {1};
>>>>>>>>>>                                 PetscInt numDof[4]   = {1, 0,
>>>>>>>>>>                                 0, 0};
>>>>>>>>>>                                 PetscInt bcFields[1] = {0};
>>>>>>>>>>                                 IS bcPoints[1] = {NULL};
>>>>>>>>>>                                 DMSetNumFields(lDMBete,
>>>>>>>>>>                                 numFields);
>>>>>>>>>>                                 DMPlexCreateSection(lDMBete,
>>>>>>>>>>                                 NULL, numComp, numDof, numBC,
>>>>>>>>>>                                 bcFields, bcPoints, NULL,
>>>>>>>>>>                                 NULL, &section);
>>>>>>>>>>                                 DMSetLocalSection(lDMBete,
>>>>>>>>>>                                 section);
>>>>>>>>>>                                 DMPlexDistribute(lDMBete, 0,
>>>>>>>>>>                                 &lSFMigrationSansOvl,
>>>>>>>>>>                                 &lDMDistribueSansOvl); //
>>>>>>>>>>                                 segfault!
>>>>>>>>>>                                 So we have other
>>>>>>>>>>                                 question/remarks:
>>>>>>>>>>                                 3- Maybe PETSc expect
>>>>>>>>>>                                 something specific that is
>>>>>>>>>>                                 missing/not verified: for
>>>>>>>>>>                                 example, we didn't gave any
>>>>>>>>>>                                 coordinates since we just
>>>>>>>>>>                                 want to partition and compute
>>>>>>>>>>                                 overlap for the mesh... and
>>>>>>>>>>                                 then recover our element
>>>>>>>>>>                                 numbers in a "simple way"
>>>>>>>>>>                                 4- We are telling ourselves
>>>>>>>>>>                                 it is somewhat a "big price
>>>>>>>>>>                                 to pay" to have to build an
>>>>>>>>>>                                 unused section to have the
>>>>>>>>>>                                 global to natural ordering
>>>>>>>>>>                                 set ?  Could this requirement
>>>>>>>>>>                                 be avoided?
>>>>>>>>>>                             I don't think so. There would
>>>>>>>>>>                             have to be _some_ way of
>>>>>>>>>>                             describing your data layout in
>>>>>>>>>>                             terms of mesh points, and I do
>>>>>>>>>>                             not see how you could use less
>>>>>>>>>>                             memory doing that.
>>>>>>>>>>                                 5- Are there any improvement
>>>>>>>>>>                                 towards our usages in 3.16
>>>>>>>>>>                                 release?
>>>>>>>>>>                             Let me try and run the code above.
>>>>>>>>>>                               Thanks,
>>>>>>>>>>                              Matt
>>>>>>>>>>                                 Thanks,
>>>>>>>>>>                                 Eric
>>>>>>>>>>                                 On 2021-09-29 7:39 p.m.,
>>>>>>>>>>>                                 On Wed, Sep 29, 2021 at 5:18
>>>>>>>>>>>                                 PM Eric Chamberland
>>>>>>>>>>>                                 wrote:
>>>>>>>>>>>                                     Hi,
>>>>>>>>>>>                                     I come back with
>>>>>>>>>>>                                     _almost_ the original
>>>>>>>>>>>                                     question:
>>>>>>>>>>>                                     I would like to add an
>>>>>>>>>>>                                     integer information
>>>>>>>>>>>                                     (*our* original element
>>>>>>>>>>>                                     number, not petsc one)
>>>>>>>>>>>                                     on each element of the
>>>>>>>>>>>                                     DMPlex I create with
>>>>>>>>>>>                                     DMPlexBuildFromCellListParallel.
>>>>>>>>>>>                                     I would like this
>>>>>>>>>>>                                     interger to be
>>>>>>>>>>>                                     distribruted by or the
>>>>>>>>>>>                                     same way
>>>>>>>>>>>                                     DMPlexDistribute
>>>>>>>>>>>                                     distribute the mesh.
>>>>>>>>>>>                                     Is it possible to do this?
>>>>>>>>>>>                                 I think we already have
>>>>>>>>>>>                                 support for what you want.
>>>>>>>>>>>                                 If you call
>>>>>>>>>>>                                 https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html
>>>>>>>>>>>                                 <https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html>
>>>>>>>>>>>                                 before DMPlexDistribute(),
>>>>>>>>>>>                                 it will compute a PetscSF
>>>>>>>>>>>                                 encoding the global to
>>>>>>>>>>>                                 natural map. You
>>>>>>>>>>>                                 can get it with
>>>>>>>>>>>                                 https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html
>>>>>>>>>>>                                 <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html>
>>>>>>>>>>>                                 and use it with
>>>>>>>>>>>                                 https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
>>>>>>>>>>>                                 <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html>
>>>>>>>>>>>                                 Is this sufficient?
>>>>>>>>>>>                                   Thanks,
>>>>>>>>>>>                                      Matt
>>>>>>>>>>>                                     Thanks,
>>>>>>>>>>>                                     Eric
>>>>>>>>>>>                                     On 2021-07-14 1:18 p.m.,
>>>>>>>>>>>                                     > Hi,
>>>>>>>>>>>                                     > I want to use
>>>>>>>>>>>                                     DMPlexDistribute from
>>>>>>>>>>>                                     PETSc for computing
>>>>>>>>>>>                                     overlapping
>>>>>>>>>>>                                     > and play with the
>>>>>>>>>>>                                     different partitioners
>>>>>>>>>>>                                     supported.
>>>>>>>>>>>                                     > However, after calling
>>>>>>>>>>>                                     DMPlexDistribute, I
>>>>>>>>>>>                                     noticed the elements are
>>>>>>>>>>>                                     > renumbered and then
>>>>>>>>>>>                                     the original number is lost.
>>>>>>>>>>>                                     > What would be the best
>>>>>>>>>>>                                     way to keep track of the
>>>>>>>>>>>                                     element renumbering?
>>>>>>>>>>>                                     > a) Adding an optional
>>>>>>>>>>>                                     parameter to let the
>>>>>>>>>>>                                     user retrieve a vector or
>>>>>>>>>>>                                     > "IS" giving the old
>>>>>>>>>>>                                     number?
>>>>>>>>>>>                                     > b) Adding a DMLabel
>>>>>>>>>>>                                     (seems a wrong good
>>>>>>>>>>>                                     solution)
>>>>>>>>>>>                                     > c) Other idea?
>>>>>>>>>>>                                     > Of course, I don't
>>>>>>>>>>>                                     want to loose
>>>>>>>>>>>                                     performances with the
>>>>>>>>>>>                                     need of this
>>>>>>>>>>>                                     > "mapping"...
>>>>>>>>>>>                                     > Thanks,
>>>>>>>>>>>                                     > Eric
>>>>>>>>>>>                                     Eric Chamberland, ing.,
>>>>>>>>>>>                                     M. Ing
>>>>>>>>>>>                                     Professionnel de recherche
>>>>>>>>>>>                                     GIREF/Université Laval
>>>>>>>>>>>                                     (418) 656-2131 poste 41
>>>>>>>>>>>                                     22 42
>>>>>>>>>>>                                 What most experimenters take
>>>>>>>>>>>                                 for granted before they
>>>>>>>>>>>                                 begin their experiments is
>>>>>>>>>>>                                 infinitely more interesting
>>>>>>>>>>>                                 than any results to which
>>>>>>>>>>>                                 their experiments lead.
>>>>>>>>>>>                                 -- Norbert Wiener
>>>>>>>>>>>                                 https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>                                 <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>>>                                 Eric Chamberland, ing., M. Ing
>>>>>>>>>>                                 (418) 656-2131 poste 41 22 42
>>>>>>>>>>                             What most experimenters take for
>>>>>>>>>>                             granted before they begin their
>>>>>>>>>>                             experiments is infinitely more
>>>>>>>>>>                             interesting than any results to
>>>>>>>>>>                             which their experiments lead.
>>>>>>>>>>                             -- Norbert Wiener
>>>>>>>>>                         interesting than any results to which
>>>>>>>>>                         -- Norbert Wiener
>>>>>>>>                     What most experimenters take for granted
>>>>>>>>                     before they begin their experiments is
>>>>>>>>                     infinitely more interesting than any
>>>>>>>>                     results to which their experiments lead.
>>>>>>>>                     -- Norbert Wiener
>>>>>>>                 What most experimenters take for granted before
>>>>>>>                 they begin their experiments is infinitely more
>>>>>>>                 interesting than any results to which their
>>>>>>>                 experiments lead.
>>>>>>>                 -- Norbert Wiener
>>>>>>             What most experimenters take for granted before they
>>>>>>             experiments lead.
>>>>>>             -- Norbert Wiener
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211110/ce64c92b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211110/ce64c92b/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211110/ce64c92b/attachment-0003.png>
