[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Matthew Knepley
knepley at gmail.com
Wed Nov 3 06:41:21 CDT 2021
On Tue, Nov 2, 2021 at 10:27 PM Eric Chamberland <
Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi Matthew,
> yes, it all works now!
> I modified the example to do a NaturalToGlobal then a GlobalToNatural and
> test if we have the good result...
> The test would just need that we "force" the computed partition to a given
> result, then we could check the result of the NaturalToGlobal independently
> of the partitioner...
> Thanks a lot!
> No problem. Thanks for generating a great test. I will get this into the
CI tonight.
Matt
> Eric
> On 2021-11-02 5:16 a.m., Matthew Knepley wrote:
> On Mon, Nov 1, 2021 at 5:24 PM Eric Chamberland <
>> Hi Matthew,
>> ok, good news then! :)
>> Meanwhile, I tested it the "other way" with
>> DMPlexGlobalToNaturalBegin/End and it does not give a "sensed" result
>> neither.
>> Probably it does something like "GlobalToSequential" too?
> I am not sure how it worked before, but I think I have it fixed. I get the
> output you expect for the test. I force-pushed the branch
> so you will have to check it out again.
> Thanks!
> Matt
>> Thanks!
>> Eric
>> On 2021-11-01 3:25 p.m., Matthew Knepley wrote:
>> On Sun, Oct 31, 2021 at 10:07 AM Eric Chamberland <
>>> Hi Matthew,
>>> we do not know if DMPlexNaturalToGlobalBegin/End is buggy or if it is
>>> our comprehension of what it should do that is wrong...
>>> Would you just check if what we try to do from line 313 to 356 is good
>>> or wrong?
>>> The expected result is that the global vector "lGlobalVec" contains the
>>> element numbers from the initial partition that have been put into
>>> "lNatVec".
>>> Thanks a lot for any insights!!
>> Okay, I have found the problem.I confess to not actually looking very
>> closely at the implementation before. GlobalToNatural was assuming that
>> the "natural" was also sequential, and looking at it all the tests are
>> eq-to-parallel distribution. I need to fix it for a parallel natural state.
>> Hopefully
>> it will not take me long.
>> Thanks,
>> Matt
>>> Eric
>>> On 2021-10-27 2:32 p.m., Eric Chamberland wrote:
>>> Hi Matthew,
>>> we continued the example. Now it must be our misuse of PETSc that
>>> produced the wrong result.
>>> As stated into the code:
>>> // The call to DMPlexNaturalToGlobalBegin/End does not produce our
>>> expected result...
>>> // In lGlobalVec, we expect to have:
>>> * Process [0]
>>> * 2.
>>> * 4.
>>> * 8.
>>> * 3.
>>> * 9.
>>> * Process [1]
>>> * 1.
>>> * 5.
>>> * 7.
>>> * 0.
>>> * 6.
>>> * but we obtained:
>>> * Process [0]
>>> * 2.
>>> * 4.
>>> * 8.
>>> * 0.
>>> * 0.
>>> * Process [1]
>>> * 0.
>>> * 0.
>>> * 0.
>>> * 0.
>>> * 0.
>>> (see attached ex44.c)
>>> Thanks,
>>> Eric
>>> On 2021-10-27 1:25 p.m., Eric Chamberland wrote:
>>> Great!
>>> Thanks Matthew, it is working for me up to that point!
>>> We are continuing the ex44.c and forward it to you at the next blocking
>>> point...
>>> Eric
>>> On 2021-10-27 11:14 a.m., Matthew Knepley wrote:
>>> On Wed, Oct 27, 2021 at 8:29 AM Eric Chamberland <
>>>> Hi Matthew,
>>>> the smallest mesh which crashes the code is a 2x5 mesh:
>>>> See the modified ex44.c
>>>> With smaller meshes(2x2, 2x4, etc), it passes... But it bugs latter
>>>> when I try to use DMPlexNaturalToGlobalBegin but let's keep that other
>>>> problem for later...
>>>> Thanks a lot for helping digging into this! :)
>>> I have made a small fix in this branch
>>> https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-g2n
>>> It seems to run for me. Can you check it?
>>> Thanks,
>>> Matt
>>>> Eric
>>>> (sorry if you received this for a 2nd times, I have trouble with my
>>>> mail)
>>>> On 2021-10-26 4:35 p.m., Matthew Knepley wrote:
>>>> On Tue, Oct 26, 2021 at 1:35 PM Eric Chamberland <
>>>>> Here is a screenshot of the partition I hard coded (top) and
>>>>> vertices/element numbers (down):
>>>>> I have not yet modified the ex44.c example to properly assign the
>>>>> coordinates...
>>>>> (but I would not have done it like it is in the last version because
>>>>> the sCoords array is the global array with global vertices number)
>>>>> I will have time to do this tomorrow...
>>>>> Maybe I can first try to reproduce all this with a smaller mesh?
>>>> That might make it easier to find a problem.
>>>> Thanks!
>>>> Matt
>>>>> Eric
>>>>> On 2021-10-26 9:46 a.m., Matthew Knepley wrote:
>>>>> Okay, I ran it. Something seems off with the mesh. First, I cannot
>>>>> simply explain the partition. The number of shared vertices and edges
>>>>> does not seem to come from a straight cut. Second, the mesh look
>>>>> scrambled on output.
>>>>> Thanks,
>>>>> Matt
>>>>> On Sun, Oct 24, 2021 at 11:49 PM Eric Chamberland <
>>>>>> Hi Matthew,
>>>>>> ok, I started back from your ex44.c example and added the global
>>>>>> array of coordinates. I just have to code the creation of the local
>>>>>> coordinates now.
>>>>>> Eric
>>>>>> On 2021-10-20 6:55 p.m., Matthew Knepley wrote:
>>>>>> On Wed, Oct 20, 2021 at 3:06 PM Eric Chamberland <
>>>>>>> Hi Matthew,
>>>>>>> we tried to reproduce the error in a simple example.
>>>>>>> The context is the following: We hard coded the mesh and initial
>>>>>>> partition into the code (see sConnectivity and sInitialPartition) for 2
>>>>>>> ranks and try to create a section in order to use the
>>>>>>> DMPlexNaturalToGlobalBegin function to retreive our initial element numbers.
>>>>>>> Now the call to DMPlexDistribute give different errors depending on
>>>>>>> what type of component we ask the field to be created. For our objective,
>>>>>>> we would like a global field to be created on elements only (like a P0
>>>>>>> interpolation).
>>>>>>> We now have the following error generated:
>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>> [0]PETSC ERROR: Petsc has generated inconsistent data
>>>>>>> [0]PETSC ERROR: Inconsistency in indices, 18 should be 17
>>>>>>> [0]PETSC ERROR: See
>>>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>>>> shooting.
>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021
>>>>>>> [0]PETSC ERROR: ./bug on a named rohan by ericc Wed Oct 20 14:52:36
>>>>>>> 2021
>>>>>>> [0]PETSC ERROR: Configure options
>>>>>>> --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7 --with-mpi-compilers=1
>>>>>>> --with-mpi-dir=/opt/openmpi-4.1.0_gcc7 --with-cxx-dialect=C++14
>>>>>>> --with-make-np=12 --with-shared-libraries=1 --with-debugging=yes
>>>>>>> --with-memalign=64 --with-visibility=0 --with-64-bit-indices=0
>>>>>>> --download-ml=yes --download-mumps=yes --download-superlu=yes
>>>>>>> --download-hpddm=yes --download-slepc=yes --download-superlu_dist=yes
>>>>>>> --download-parmetis=yes --download-ptscotch=yes --download-metis=yes
>>>>>>> --download-strumpack=yes --download-suitesparse=yes --download-hypre=yes
>>>>>>> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>>>>> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>>>>> --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>>>>> --with-scalapack=1
>>>>>>> --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include
>>>>>>> --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>>>>> -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
>>>>>>> [0]PETSC ERROR: #1 PetscSFCreateSectionSF() at
>>>>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/vec/is/sf/utils/sfutils.c:409
>>>>>>> [0]PETSC ERROR: #2 DMPlexCreateGlobalToNaturalSF() at
>>>>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:184
>>>>>>> [0]PETSC ERROR: #3 DMPlexDistribute() at
>>>>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexdistribute.c:1733
>>>>>>> [0]PETSC ERROR: #4 main() at bug_section.cc:159
>>>>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>>>>> [0]PETSC ERROR: ----------------End of Error Message -------send
>>>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>>>> Hope the attached code is self-explaining, note that to make it
>>>>>>> short, we have not included the final part of it, just the buggy part we
>>>>>>> are encountering right now...
>>>>>>> Thanks for your insights,
>>>>>> Thanks for making the example. I tweaked it slightly. I put in a test
>>>>>> case that just makes a parallel 7 x 10 quad mesh. This works
>>>>>> fine. Thus I think it must be something connected with the original
>>>>>> mesh. It is hard to get a handle on it without the coordinates.
>>>>>> Do you think you could put the coordinate array in? I have added the
>>>>>> code to load them (see attached file).
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> Eric
>>>>>>> On 2021-10-06 9:23 p.m., Matthew Knepley wrote:
>>>>>>> On Wed, Oct 6, 2021 at 5:43 PM Eric Chamberland <
>>>>>>>> Hi Matthew,
>>>>>>>> we tried to use that. Now, we discovered that:
>>>>>>>> 1- even if we "ask" for sfNatural creation with DMSetUseNatural, it
>>>>>>>> is not created because DMPlexCreateGlobalToNaturalSF looks for a "section":
>>>>>>>> this is not documented in DMSetUseNaturalso we are asking ourselfs: "is
>>>>>>>> this a permanent feature or a temporary situation?"
>>>>>>> I think explaining this will help clear up a lot.
>>>>>>> What the Natural2Global map does is permute a solution vector into
>>>>>>> the ordering that it would have had prior to mesh distribution.
>>>>>>> Now, in order to do this permutation, I need to know the original
>>>>>>> (global) data layout. If it is not specified _before_ distribution, we
>>>>>>> cannot build the permutation. The section describes the data
>>>>>>> layout, so I need it before distribution.
>>>>>>> I cannot think of another way that you would implement this, but if
>>>>>>> you want something else, let me know.
>>>>>>>> 2- We then tried to create a "section" in different manners: we
>>>>>>>> took the code into the example petsc/src/dm/impls/plex/tests/ex15.c.
>>>>>>>> However, we ended up with a segfault:
>>>>>>>> corrupted size vs. prev_size
>>>>>>>> [rohan:07297] *** Process received signal ***
>>>>>>>> [rohan:07297] Signal: Aborted (6)
>>>>>>>> [rohan:07297] Signal code: (-6)
>>>>>>>> [rohan:07297] [ 0] /lib64/libpthread.so.0(+0x13f80)[0x7f6f13be3f80]
>>>>>>>> [rohan:07297] [ 1] /lib64/libc.so.6(gsignal+0x10b)[0x7f6f109b718b]
>>>>>>>> [rohan:07297] [ 2] /lib64/libc.so.6(abort+0x175)[0x7f6f109b8585]
>>>>>>>> [rohan:07297] [ 3] /lib64/libc.so.6(+0x7e2f7)[0x7f6f109fb2f7]
>>>>>>>> [rohan:07297] [ 4] /lib64/libc.so.6(+0x857ea)[0x7f6f10a027ea]
>>>>>>>> [rohan:07297] [ 5] /lib64/libc.so.6(+0x86036)[0x7f6f10a03036]
>>>>>>>> [rohan:07297] [ 6] /lib64/libc.so.6(+0x861a3)[0x7f6f10a031a3]
>>>>>>>> [rohan:07297] [ 7] /lib64/libc.so.6(+0x88740)[0x7f6f10a05740]
>>>>>>>> [rohan:07297] [ 8]
>>>>>>>> /lib64/libc.so.6(__libc_malloc+0x1b8)[0x7f6f10a070c8]
>>>>>>>> [rohan:07297] [ 9]
>>>>>>>> /lib64/libc.so.6(__backtrace_symbols+0x134)[0x7f6f10a8b064]
>>>>>>>> [rohan:07297] [10]
>>>>>>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z12reqBacktraceRNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE+0x4e)[0x4538ce]
>>>>>>>> [rohan:07297] [11]
>>>>>>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z15attacheDebuggerv+0x120)[0x4523c0]
>>>>>>>> [rohan:07297] [12]
>>>>>>>> /home/mefpp_ericc/GIREF/lib/libgiref_dev_Util.so(traitementSignal+0x612)[0x7f6f28f503a2]
>>>>>>>> [rohan:07297] [13] /lib64/libc.so.6(+0x3a210)[0x7f6f109b7210]
>>>>>>>> [rohan:07297] [14]
>>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscTrMallocDefault+0x6fd)[0x7f6f22f1b8ed]
>>>>>>>> [rohan:07297] [15]
>>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscMallocA+0x5cd)[0x7f6f22f19c2d]
>>>>>>>> [rohan:07297] [16]
>>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscSFCreateSectionSF+0xb48)[0x7f6f23268e18]
>>>>>>>> [rohan:07297] [17]
>>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexCreateGlobalToNaturalSF+0x13b2)[0x7f6f241a5602]
>>>>>>>> [rohan:07297] [18]
>>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexDistribute+0x39b1)[0x7f6f23fdca21]
>>>>>>> I am not sure what happened here, but if you could send a sample
>>>>>>> code, I will figure it out.
>>>>>>>> If we do not create a section, the call to DMPlexDistribute is
>>>>>>>> successful, but DMPlexGetGlobalToNaturalSF return a null SF pointer...
>>>>>>> Yes, it just ignores it in this case because it does not have a
>>>>>>> global layout.
>>>>>>>> Here are the operations we are calling ( this is almost the code we
>>>>>>>> are using, I just removed verifications and creation of the connectivity
>>>>>>>> which use our parallel structure and code):
>>>>>>>> PetscInt* lCells = 0;
>>>>>>>> PetscInt lNumCorners = 0;
>>>>>>>> PetscInt lDimMail = 0;
>>>>>>>> PetscInt lnumCells = 0;
>>>>>>>> //At this point we create the cells for PETSc expected input for
>>>>>>>> DMPlexBuildFromCellListParallel and set lNumCorners, lDimMail and lnumCells
>>>>>>>> to correct values.
>>>>>>>> DM lDMBete = 0
>>>>>>>> DMPlexCreate(lMPIComm,&lDMBete);
>>>>>>>> DMSetDimension(lDMBete, lDimMail);
>>>>>>>> DMPlexBuildFromCellListParallel(lDMBete,
>>>>>>>> lnumCells,
>>>>>>>> PETSC_DECIDE,
>>>>>>>> pLectureElementsLocaux.reqNbTotalSommets(),
>>>>>>>> lNumCorners,
>>>>>>>> lCells,
>>>>>>>> PETSC_NULL);
>>>>>>>> DM lDMBeteInterp = 0;
>>>>>>>> DMPlexInterpolate(lDMBete, &lDMBeteInterp);
>>>>>>>> DMDestroy(&lDMBete);
>>>>>>>> lDMBete = lDMBeteInterp;
>>>>>>>> DMSetUseNatural(lDMBete,PETSC_TRUE);
>>>>>>>> PetscSF lSFMigrationSansOvl = 0;
>>>>>>>> PetscSF lSFMigrationOvl = 0;
>>>>>>>> DM lDMDistribueSansOvl = 0;
>>>>>>>> DM lDMAvecOverlap = 0;
>>>>>>>> PetscPartitioner lPart;
>>>>>>>> DMPlexGetPartitioner(lDMBete, &lPart);
>>>>>>>> PetscPartitionerSetFromOptions(lPart);
>>>>>>>> PetscSection section;
>>>>>>>> PetscInt numFields = 1;
>>>>>>>> PetscInt numBC = 0;
>>>>>>>> PetscInt numComp[1] = {1};
>>>>>>>> PetscInt numDof[4] = {1, 0, 0, 0};
>>>>>>>> PetscInt bcFields[1] = {0};
>>>>>>>> IS bcPoints[1] = {NULL};
>>>>>>>> DMSetNumFields(lDMBete, numFields);
>>>>>>>> DMPlexCreateSection(lDMBete, NULL, numComp, numDof, numBC,
>>>>>>>> bcFields, bcPoints, NULL, NULL, §ion);
>>>>>>>> DMSetLocalSection(lDMBete, section);
>>>>>>>> DMPlexDistribute(lDMBete, 0, &lSFMigrationSansOvl,
>>>>>>>> &lDMDistribueSansOvl); // segfault!
>>>>>>>> So we have other question/remarks:
>>>>>>>> 3- Maybe PETSc expect something specific that is missing/not
>>>>>>>> verified: for example, we didn't gave any coordinates since we just want to
>>>>>>>> partition and compute overlap for the mesh... and then recover our element
>>>>>>>> numbers in a "simple way"
>>>>>>>> 4- We are telling ourselves it is somewhat a "big price to pay" to
>>>>>>>> have to build an unused section to have the global to natural ordering set
>>>>>>>> ? Could this requirement be avoided?
>>>>>>> I don't think so. There would have to be _some_ way of describing
>>>>>>> your data layout in terms of mesh points, and I do not see how you could
>>>>>>> use less memory doing that.
>>>>>>>> 5- Are there any improvement towards our usages in 3.16 release?
>>>>>>> Let me try and run the code above.
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>>> Thanks,
>>>>>>>> Eric
>>>>>>>> On 2021-09-29 7:39 p.m., Matthew Knepley wrote:
>>>>>>>> On Wed, Sep 29, 2021 at 5:18 PM Eric Chamberland <
>>>>>>>>> Hi,
>>>>>>>>> I come back with _almost_ the original question:
>>>>>>>>> I would like to add an integer information (*our* original element
>>>>>>>>> number, not petsc one) on each element of the DMPlex I create with
>>>>>>>>> DMPlexBuildFromCellListParallel.
>>>>>>>>> I would like this interger to be distribruted by or the same way
>>>>>>>>> DMPlexDistribute distribute the mesh.
>>>>>>>>> Is it possible to do this?
>>>>>>>> I think we already have support for what you want. If you call
>>>>>>>> https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html
>>>>>>>> before DMPlexDistribute(), it will compute a PetscSF encoding the
>>>>>>>> global to natural map. You
>>>>>>>> can get it with
>>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html
>>>>>>>> and use it with
>>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
>>>>>>>> Is this sufficient?
>>>>>>>> Thanks,
>>>>>>>> Matt
>>>>>>>>> Thanks,
>>>>>>>>> Eric
>>>>>>>>> On 2021-07-14 1:18 p.m., Eric Chamberland wrote:
>>>>>>>>> > Hi,
>>>>>>>>> > I want to use DMPlexDistribute from PETSc for computing
>>>>>>>>> overlapping
>>>>>>>>> > and play with the different partitioners supported.
>>>>>>>>> > However, after calling DMPlexDistribute, I noticed the elements
>>>>>>>>> are
>>>>>>>>> > renumbered and then the original number is lost.
>>>>>>>>> > What would be the best way to keep track of the element
>>>>>>>>> renumbering?
>>>>>>>>> > a) Adding an optional parameter to let the user retrieve a
>>>>>>>>> vector or
>>>>>>>>> > "IS" giving the old number?
>>>>>>>>> > b) Adding a DMLabel (seems a wrong good solution)
>>>>>>>>> > c) Other idea?
>>>>>>>>> > Of course, I don't want to loose performances with the need of
>>>>>>>>> this
>>>>>>>>> > "mapping"...
>>>>>>>>> > Thanks,
>>>>>>>>> > Eric
>>>>>>>>> Eric Chamberland, ing., M. Ing
>>>>>>>>> Professionnel de recherche
>>>>>>>>> GIREF/Université Laval
>>>>>>>>> (418) 656-2131 poste 41 22 42
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211103/fae3d757/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211103/fae3d757/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211103/fae3d757/attachment-0003.png>
