[petsc-users] Fwd: SNES with Fieldsplit + MatNest in parallel
barnafi
nabw91 at gmail.com
Tue Nov 9 11:27:00 CST 2021
I have checked the matrix in a very small problem and they are the
same, so the problem is definitely somewhere in the ordering/ghost
interface from fenics, so PETSc is doing everything fine.
Thanks for your help, I'm moving to the fenics forum.
Best,
NB
On Tue, Nov 9, 2021 at 07:01, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Nov 9, 2021 at 6:52 AM Nicolas Barnafi <nabw91 at gmail.com>
> wrote:
>> Thanks for the help Matthew.
>>> The next step would be to verify that the operators you get in
>>> those slots are correct in parallel. I normally just print out the
>>> matrix
>>> for a small problem. This is the only way I know to debug assembly.
>>> To check the solver, you set it to an exact solver and see that it
>>> takes 1 iterate. That means using LU as the subsolver
>>> for the first block, using the full Schur complement, and solving
>>> the Schur system with a residual tolerance of something like 1e-10.
>> There is certainly something wrong in the nested matrix, as this is
>> the output in serial (LU + full Schur LU):
> Yes, this is why I recommend going to just 2 or 4 cells, so that you
> can see explicitly what is wrong with the matrix.
> Thanks,
> Matt
>> 0 SNES Function norm 3.240309155660e+03
>> 0 KSP Residual norm 3.240309155660e+03
>> 1 KSP Residual norm 3.219893365194e-08
>> 1 SNES Function norm 3.999872813081e+03
>> 0 KSP Residual norm 1.214145680994e+04
>> 1 KSP Residual norm 2.742817643080e-04
>> 2 SNES Function norm 3.663148395735e+01
>> 0 KSP Residual norm 3.980103473350e+03
>> 1 KSP Residual norm 1.814754406828e-05
>> 3 SNES Function norm 2.136252100504e+01
>> 0 KSP Residual norm 6.970609974245e+01
>> 1 KSP Residual norm 1.982821753925e-05
>> 4 SNES Function norm 1.059694009734e-02
>> 0 KSP Residual norm 2.136131725219e+01
>> 1 KSP Residual norm 4.545878835451e-06
>> 2 KSP Residual norm 8.841427426699e-08
>> 3 KSP Residual norm 3.305898584949e-09
>> 5 SNES Function norm 3.729120062850e-03
>> 0 KSP Residual norm 3.846880232871e-03
>> 1 KSP Residual norm 1.740268533385e-06
>> 2 KSP Residual norm 3.013108797112e-08
>> 3 KSP Residual norm 1.105602265959e-09
>> 6 SNES Function norm 1.117697448247e-09
>> whereas in parallel it is this (two processes):
>> 1 KSP Residual norm 2.158162432432e-01
>> 2 KSP Residual norm 2.156121452805e-01
>> 3 KSP Residual norm 2.148639482595e-01
>> 4 KSP Residual norm 2.148248193325e-01
>> 5 KSP Residual norm 1.305140166188e-03
>> Linear solve converged due to CONVERGED_RTOL iterations 5
>> 1 SNES Function norm 4.774611203034e+42
>> Best,
>> NB
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
