[petsc-users] Configure of 3.16.1 failing on mpich/yaksa
Daniel Stone
daniel.stone at opengosim.com
Mon Nov 8 13:24:07 CST 2021
Hello all,
I've been having some configure failures trying to configure petsc, on
Ubuntu 20, when
downloading mpich.
This seems to be related to the use of
"#!/bin/sh"
found in the script
mpich-3.4.2/modules/yaksa/src/backend/cuda/cudalt.sh
/bin/sh in Ubuntu20 is dash, not bash, and line 35 of the script is:
CMD="${@:2} -Xcompiler -fPIC -o $PIC_FILEPATH"
which is apparently not valid dash syntax. I see "bad substitution" errors
when
trying to run this script in isolation, which can be fixed by replacing the
top line with
"#!/bin/bash"
The petsc config log points to this line in this script:
make[2]: Entering directory
'/home/david/petsc/petsc_opt/externalpackages/mpich-3.4.2/modules/yaksa'
NVCC src/backend/cuda/pup/yaksuri_cudai_pup_hvector__Bool.lo
NVCC src/backend/cuda/pup/yaksuri_cudai_pup_hvector_hvector__Bool.lo
NVCC src/backend/cuda/pup/yaksuri_cudai_pup_hvector_blkhindx__Bool.lo
NVCC src/backend/cuda/pup/yaksuri_cudai_pup_hvector_hindexed__Bool.lo
NVCC src/backend/cuda/pup/yaksuri_cudai_pup_hvector_contig__Bool.lo
NVCC src/backend/cuda/pup/yaksuri_cudai_pup_blkhindx_hvector__Bool.lo
NVCC src/backend/cuda/pup/yaksuri_cudai_pup_hvector_resized__Bool.lo
NVCC src/backend/cuda/pup/yaksuri_cudai_pup_blkhindx__Bool.lo
NVCC src/backend/cuda/pup/yaksuri_cudai_pup_blkhindx_blkhindx__Bool.lo
NVCC src/backend/cuda/pup/yaksuri_cudai_pup_blkhindx_hindexed__Bool.lo
NVCC src/backend/cuda/pup/yaksuri_cudai_pup_blkhindx_contig__Bool.lo
NVCC src/backend/cuda/pup/yaksuri_cudai_pup_blkhindx_resized__Bool.lo
make[2]: Leaving directory
make[1]: Leaving directory
'/home/david/petsc/petsc_opt/externalpackages/mpich-3.4.2'/usr/bin/ar: `u'
modifier ignored since `D' is the default (see `U')
/usr/bin/ar: `u' modifier ignored since `D' is the default (see `U')
./src/backend/cuda/cudalt.sh: 35: Bad substitution
make[2]: *** [Makefile:8697:
src/backend/cuda/pup/yaksuri_cudai_pup_hvector__Bool.lo] Error 2
make[2]: *** Waiting for unfinished jobs....
src/backend/cuda/pup/yaksuri_cudai_pup_hvector_hvector__Bool.lo] Error 2
src/backend/cuda/pup/yaksuri_cudai_pup_hvector_blkhindx__Bool.lo] Error 2
What is interesting is the choice made by the config script here to make
yaksa "cuda-aware", which I do not
understand how to control. By this I mean - the use of NVCC, the use of
files with "cudai" in the name,
and the running of the cudalt.sh script.
This is especially odd given that on another machine, also with Ubuntu20,
none of this occurs, despite
using the exact same configure instructions:
CC src/backend/seq/pup/yaksuri_seqi_pup_blkhindx_resized__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_hindexed__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_hindexed_hvector__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_hindexed_blkhindx__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_hindexed_hindexed__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_hindexed_contig__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_hindexed_resized__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_contig__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_contig_hvector__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_contig_blkhindx__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_contig_hindexed__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_contig_contig__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_contig_resized__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_resized__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_resized_hvector__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_resized_blkhindx__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_resized_hindexed__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_resized_contig__Bool.lo
CC src/backend/seq/pup/yaksuri_seqi_pup_resized_resized__Bool.lo
On both machines petsc locates a working nvcc without trouble. One
difference is
that on the good machine, cuda 11 is installed, built from source, while on
the bad machine
cuda 10 is installed, installed via apt-get. On the good machine, running
the cudalt.sh script in
isolation results in the same bad substitution error.
Can someone help me understand where the difference of behaviour might come
from, w.r.t.
cuda? Adding the --with-cuda=0 flag on the bad machine made no difference.
Is there any way
of communicating to mpich/yaksuri that I don't want whatever features that
involve the cudalt.sh
script being run?
The configure command I use is:
./configure --download-mpich=yes --download-hdf5=yes
--download-fblaslapack=yes --download-metis=yes --download-cmake=yes
--download-ptscotch=yes --download-hypre=yes --with-debugging=0
COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3
-download-hdf5-fortran-bindings=yes --download-sowing
Daniel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211108/f5c5fa09/attachment.html>
