[petsc-users] How to construct DMPlex of cells with different topological dimension?
袁煕
yuanxi at advancesoft.jp
Wed Nov 3 20:19:15 CDT 2021
I think the above Jed's reply declared what I am worried about. That is: if
I don't use faking 3D elements, automatic topological interpolation is not
available. I also notice your discussion with Nicolas. You suggest users
could do it themselves by using GetRawFaces etc. I think maybe I can try
to do it another time.
Thank you very much
Yuan
2021年11月3日(水) 20:19 Matthew Knepley <knepley at gmail.com>:
> On Tue, Nov 2, 2021 at 10:49 PM 袁煕 <yuanxi at advancesoft.jp> wrote:
>> Well! All objects in this world could definitely be modeled as 3D
>> volumes. But considering costs of meshing and following calculations, in
>> most cases it is neither practical nor necessary. And in some specific
>> cases, e.g., to model cell membranes, 2D membrane elements may behave
>> better than 3D volume ones. It is therefore, in many cases, modeling should
>> be much simplified and in some cases they could be modeled as 2D or 1D ones.
> I have _never_ suggested using 3D elements, as you can see from my reply
> to Nicolas. I said you can use _exactly_ the element you want. I am not
> sure how to be more clear.
> Matt
>> Following paper is obtained after just google "parachute, FSI"
>> *A parallel 3D computational method for fluid-structure interactions in
>> parachute systems
>> <https://www.researchgate.net/publication/228719684_A_parallel_3D_computational_method_for_fluid-structure_interactions_in_parachute_systems>*
>> You can see they use cable (1D) and membrane (2D) elements to model
>> parachutes. Those public software, such as ABAQUS, ANSYS, NASTRAN, etc all
>> allow the mixed usage of topologically different elements. They tell the
>> same story. It is the reality and I don't think such reality would change
>> in the near future.
>> Best regards
>> Yuan
>> 2021年11月2日(火) 18:22 Matthew Knepley <knepley at gmail.com>:
>>> On Mon, Nov 1, 2021 at 11:20 PM 袁煕 <yuanxi at advancesoft.jp> wrote:
>>>> Dear Matthew,
>>>> I built a test problem using the strategy you suggested. It works! It
>>>> is enough for me right now. Thank you very much.
>>>> ! 9----------8----------13
>>>> ! 6---------7---------12 |
>>>> ! | 5------|---4-------|--11--------17------16
>>>> ! 2-- ------3---------10--------14-------15
>>>> coneSize = (/ 8,8,8,8, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 /)
>>>> cones = (/ 2,5,4,3,6,7,8,9, 3,4,11,10,7,12,13,8, &
>>>> 10,14,17,11, 10,14,17,11, 14,15,16,17, 14,15,16,17 /)
>>>> There is still a problem left, however, that is how to build a 3D cell
>>>> from a 2 vertex segment. I think I could construct a virtual tetrahedron.
>>>> Finally, It can't be denied that this approach needs additional effort
>>>> in mesh construction (and It is something strange to construct a 3D object
>>>> from a one dimensional segment). In fact, structures with different
>>>> topological dimensions are not that rare. Parachute, for example, may be
>>>> composed with two dimensional parafoil and one dimensional cord. FRP(Fiber
>>>> reinforced plastics) may be modelled by one dimensional reinforcement and
>>>> three dimensional plastics. It is therefore, I am wondering, if PETSc would
>>>> take into consider of such cases by, for example
>>>> - Enable a face, DM_POLYTOPE_SEGMENT2D, defined by one edge. And
>>>> - Eable cells, such
>>>> as DM_POLYTOPE_QUADRILATERAL3D, DM_POLYTOPE_TRIANGLE3D and
>>>> DM_POLYTOPE_SEGMENT3D, with one face.
>>> I think I am still not being completely clear. These types of cells
>>> definitely exist. However, let's take the case of the parachute. The one
>>> dimensional cords are part of
>>> the two dimensional patches, which are part of a three dimensional
>>> volume. This is how we have modeled it. You assemble different equations on
>>> different pieces, but
>>> that does not affect the mesh.
>>> Thanks,
>>> Matt
>>>> Sorry for a newbie in PETSc to provide such a suggestion. But if it
>>>> could be accomplished, it would help mech structural engineering, civil
>>>> engineering, and solid mechanics applicationers.
>>>> Best regards,
>>>> Yuan
>>>> 2021年11月1日(月) 18:32 Matthew Knepley <knepley at gmail.com>:
>>>>> On Sun, Oct 31, 2021 at 12:21 PM 袁煕 <yuanxi at advancesoft.jp> wrote:
>>>>>> Dear Matt
>>>>>> Thank you for your detailed explanation.
>>>>>> First, I would like to answer your question about my application
>>>>>> where low dimensional features are not embedded in the larger volume. It is
>>>>>> quite general in structural engineering. For example, buildings are
>>>>>> generally modelled as shells and beams, which are two and one dimension
>>>>>> respectively. While building foundation is modelled by solid
>>>>>> elements, which is three dimension, at the same time.
>>>>> I think I see what you want now. Let me make a suggestion (along the
>>>>> lines of what Mark said), and attempt to justify it by answering some
>>>>> questions.
>>>>> Suggestion: I think you should consider using a volumetric mesh for
>>>>> your problem
>>>>> Q1: Can I get the same algebraic system this way?
>>>>> Yes. You would only assign unknowns to faces and edges of the mesh
>>>>> where you have shell and beam elements.
>>>>> Q2: What are the advantages?
>>>>> You would get topological connectivity of all parts of the structure,
>>>>> automatic coupling of the different formulations,
>>>>> and you could separately solve the different structures using block
>>>>> preconditioners, while still forming a unified
>>>>> residual so that you can guarantee a consistent solution.
>>>>> Q3: Wouldn't this be expensive?
>>>>> No. For the shells and beams, you would still need the vertices,
>>>>> edges, and faces. First, by the Euler relation, these would
>>>>> outnumbers the additional cells. Second, since no unknowns would be
>>>>> associated with the cells, only additional memory in
>>>>> the mesh would be used, not the system solves. Memory and time are
>>>>> dominated by the solve, so this should be in the noise.
>>>>> What do you think?
>>>>> Thanks,
>>>>> Matt
>>>>>> Secondly, It is regrettably to find that DMComposite is not available
>>>>>> for me, because all my solid, shell, and beam elements are connected each
>>>>>> other.
>>>>>> At last, I have build a simple program to see if DMPlexSetCellType()
>>>>>> works for me, following the suggestion of functions in PETSc like
>>>>>> DMPlexCreateCGNS. But it failed when it tried to do DMPlexInterpolate
>>>>>> ! 9----------8---------13
>>>>>> ! | 5------|---4-------|-11--------17--------16
>>>>>> ! 2---------3---------10--------14-------15
>>>>>> The calculation result are follows. It seems that the cell type are
>>>>>> set correctly but depth is still 2.
>>>>>> DM Object: TestMesh 2 MPI processes
>>>>>> type: plex
>>>>>> TestMesh in 3 dimensions:
>>>>>> 0-cells: 16 0
>>>>>> 3-cells: 20 (18) 0
>>>>>> Labels:
>>>>>> celltype: 3 strata with value/size (7 (2), 4 (2), 0 (16))
>>>>>> depth: 2 strata with value/size (0 (16), 1 (20))
>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>>> [0]PETSC ERROR: Array was not checked out
>>>>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>>> shooting.
>>>>>> [0]PETSC ERROR: Petsc Development GIT revision:
>>>>>> v3.16.0-351-g743e004674 GIT Date: 2021-10-29 09:32:23 -0500
>>>>>> [0]PETSC ERROR: ./ex3f90 on a arch-linux-c-debug named
>>>>>> DESKTOP-9ITFSBM by hillyuan Mon Nov 1 00:26:39 2021
>>>>>> [0]PETSC ERROR: Configure options --with-cc=mpiicc --with-cxx=mpiicpc
>>>>>> --with-fc=mpiifort --with-fortran-bindings=1
>>>>>> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.3.0
>>>>>> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.3.0
>>>>>> [0]PETSC ERROR: #1 DMRestoreWorkArray() at
>>>>>> /home/hillyuan/programs/petsc/src/dm/interface/dm.c:1580
>>>>>> [0]PETSC ERROR: #2 DMPlexRestoreRawFaces_Internal() at
>>>>>> /home/hillyuan/programs/petsc/src/dm/impls/plex/plexinterpolate.c:323
>>>>>> [0]PETSC ERROR: #3 DMPlexInterpolateFaces_Internal() at
>>>>>> /home/hillyuan/programs/petsc/src/dm/impls/plex/plexinterpolate.c:375
>>>>>> [0]PETSC ERROR: #4 DMPlexInterpolate() at
>>>>>> /home/hillyuan/programs/petsc/src/dm/impls/plex/plexinterpolate.c:1340
>>>>>> I attached my test program in this mail. It is much appreciated that
>>>>>> you could provide any suggestion.
>>>>>> Best regards,
>>>>>> Yuan
>>>>>> 2021年10月31日(日) 21:16 Matthew Knepley <knepley at gmail.com>:
>>>>>>> On Thu, Oct 28, 2021 at 10:48 PM 袁煕 <yuanxi at advancesoft.jp> wrote:
>>>>>>>> Dear Matt,
>>>>>>>> My mesh is something like the following figure, which is
>>>>>>>> composed of three elements : one hexahedron(solid element), one
>>>>>>>> quadrilateral (shell element), and one line (beam element). I found the
>>>>>>>> function "TestEmptyStrata" in file \dm\impls\plex\tests\ex11.c
>>>>>>>> would be a good example to read in such a kind of mesh by using
>>>>>>>> DMPlexSetCone. But a problem is that you should declare all faces and edges
>>>>>>>> of hexahedron element, all edges in quadrilateral element by
>>>>>>>> DMPlexSetCone, otherwise PETsc could not do
>>>>>>>> topological interpolation afterwards. Am I right here?
>>>>>>>> As general in FEM mesh, my mesh does not contain any information
>>>>>>>> about faces or edges of solid elements. That's why I consider
>>>>>>>> using DMCOMPOSITE. That is
>>>>>>>> - Put hexahedron, quadrilateral, and line elements into
>>>>>>>> different DM structures.
>>>>>>>> - do topological interpolation in those DMs separately.
>>>>>>>> - composite them.
>>>>>>>> Is there anything wrong in my above consideration? Any
>>>>>>>> suggestions?
>>>>>>>> / | / | cell 0: Hex
>>>>>>>> | | | | cell 1: Quad
>>>>>>>> cell 2: line
>>>>>>>> Much thanks for your help.
>>>>>>> If you are solving something where everything is embedded in a
>>>>>>> volumetric mesh, then there is no problem. However, if you really have
>>>>>>> the mesh above, where lower dimensional pieces are sticking out of
>>>>>>> the mesh, then Plex can represent the mesh, but automatic interpolation
>>>>>>> (creation of edges and faces) will not work. Why is this? We use
>>>>>>> depth in the DAG as a proxy for cell dimension, but this will no longer work
>>>>>>> if faces are not part of a volume.
>>>>>>> Will DMCOMPOSITE do what you want? It depends. It will be able to
>>>>>>> lay out a vector, but it will not know about any topological connectivity
>>>>>>> between the meshes and will not preallocate a Jacobian with any
>>>>>>> interaction. If the meshes are truly separate, this is fine. If not, it is
>>>>>>> not that
>>>>>>> useful.
>>>>>>> Could you modify the existing code to support this? Yes, it would
>>>>>>> not be terribly difficult. When you load the mesh, you must know what kind
>>>>>>> of cell you are loading. You could explicitly set this using
>>>>>>> DMPlexSetCellType(). Then, instead of taking a certain height stratum of
>>>>>>> the DAG
>>>>>>> to loop over, you would instead use all cells marked with a certain
>>>>>>> cell type. The rest of the interpolation code should work fine.
>>>>>>> What kind of physics do you have where low dimensional features are
>>>>>>> not embedded in the larger volume?
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>>> Yuan
>>>>>>>> 2021年10月28日(木) 22:05 Matthew Knepley <knepley at gmail.com>:
>>>>>>>>> On Thu, Oct 28, 2021 at 4:59 AM 袁煕 <yuanxi at advancesoft.jp> wrote:
>>>>>>>>>> Dear Matt,
>>>>>>>>>> Thank you for your quick response.
>>>>>>>>>> I think what you mean is to build DAG from my mesh at first and
>>>>>>>>>> then call DMPlexCreateFromDAG
>>>>>>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexCreateFromDAG.html#DMPlexCreateFromDAG>()
>>>>>>>>>> to construct DMPlex.
>>>>>>>>> No, I do not mean that.
>>>>>>>>>> A new problem is, as I know, the function DMPlexInterpolate would
>>>>>>>>>> generate points with different depth. What's the difference between those
>>>>>>>>>> faces and segment elements generated by DMPlexInterpolate with that
>>>>>>>>>> defined by the original mesh, or should we not use DMPlexInterpolate in
>>>>>>>>>> such a case?
>>>>>>>>>> On the other hand, can DMComposite be used in this case by
>>>>>>>>>> defining DMPlex with different topological dimensions at first and then
>>>>>>>>>> composite them?
>>>>>>>>> You do not need that. I am obviously not understanding your
>>>>>>>>> question. My short answer is that Plex _already_ handles cells of different
>>>>>>>>> dimension automatically without anything extra.
>>>>>>>>> Maybe it would help if you defined a specific problem you have.
>>>>>>>>> Thanks,
>>>>>>>>> Matt
>>>>>>>>>> Thanks in advance.
>>>>>>>>>> Yuan
>>>>>>>>>> 2021年10月27日(水) 19:27 Matthew Knepley <knepley at gmail.com>:
>>>>>>>>>>> On Wed, Oct 27, 2021 at 4:50 AM 袁煕 <yuanxi at advancesoft.jp>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> I am trying to parallelize my serial FEM program using PETSc.
>>>>>>>>>>>> This program calculates structure deformation by using various types of
>>>>>>>>>>>> elements such as solid, shell, beam, and truss. At the very beginning, I
>>>>>>>>>>>> found it was hard for me to put such kinds of elements into DMPlex. Because
>>>>>>>>>>>> solid elements are topologically three dimensional, shell element two, and
>>>>>>>>>>>> beam or truss are topologically one-dimensional elements. After reading
>>>>>>>>>>>> chapter 2.10: "DMPlex: Unstructured Grids in PETSc" of users manual
>>>>>>>>>>>> carefully, I found the provided functions, such as DMPlexSetCone, cannot
>>>>>>>>>>>> declare those topological differences.
>>>>>>>>>>>> My question is : Is it possible and how to define all those
>>>>>>>>>>>> topologically different elements into a DMPlex struct?
>>>>>>>>>>> Yes. The idea is to program in a dimension-independent way, so
>>>>>>>>>>> that the code can handle cells of any dimension.
>>>>>>>>>>> What you probably want is the "depth" in the DAG representation,
>>>>>>>>>>> which you can think of as the dimension of a cell.
>>>>>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetPointDepth.html#DMPlexGetPointDepth
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Matt
>>>>>>>>>>>> Thanks in advance!
>>>>>>>>>>>> Best regards,
>>>>>>>>>>>> Yuan.
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211104/c24832e2/attachment-0001.html>
