[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Matthew Knepley
knepley at gmail.com
Tue Nov 2 04:16:30 CDT 2021
On Mon, Nov 1, 2021 at 5:24 PM Eric Chamberland <
Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi Matthew,
> ok, good news then! :)
> Meanwhile, I tested it the "other way" with DMPlexGlobalToNaturalBegin/End
> and it does not give a "sensed" result neither.
> Probably it does something like "GlobalToSequential" too?
I am not sure how it worked before, but I think I have it fixed. I get the
output you expect for the test. I force-pushed the branch
so you will have to check it out again.
Thanks!
Matt
> Thanks!
> Eric
> On 2021-11-01 3:25 p.m., Matthew Knepley wrote:
> On Sun, Oct 31, 2021 at 10:07 AM Eric Chamberland <
>> Hi Matthew,
>> we do not know if DMPlexNaturalToGlobalBegin/End is buggy or if it is our
>> comprehension of what it should do that is wrong...
>> Would you just check if what we try to do from line 313 to 356 is good or
>> wrong?
>> The expected result is that the global vector "lGlobalVec" contains the
>> element numbers from the initial partition that have been put into
>> "lNatVec".
>> Thanks a lot for any insights!!
> Okay, I have found the problem.I confess to not actually looking very
> closely at the implementation before. GlobalToNatural was assuming that
> the "natural" was also sequential, and looking at it all the tests are
> eq-to-parallel distribution. I need to fix it for a parallel natural state.
> Hopefully
> it will not take me long.
> Thanks,
> Matt
>> Eric
>> On 2021-10-27 2:32 p.m., Eric Chamberland wrote:
>> Hi Matthew,
>> we continued the example. Now it must be our misuse of PETSc that
>> produced the wrong result.
>> As stated into the code:
>> // The call to DMPlexNaturalToGlobalBegin/End does not produce our
>> expected result...
>> // In lGlobalVec, we expect to have:
>> * Process [0]
>> * 2.
>> * 4.
>> * 8.
>> * 3.
>> * 9.
>> * Process [1]
>> * 1.
>> * 5.
>> * 7.
>> * 0.
>> * 6.
>> * but we obtained:
>> * Process [0]
>> * 2.
>> * 4.
>> * 8.
>> * 0.
>> * 0.
>> * Process [1]
>> * 0.
>> * 0.
>> * 0.
>> * 0.
>> * 0.
>> (see attached ex44.c)
>> Thanks,
>> Eric
>> On 2021-10-27 1:25 p.m., Eric Chamberland wrote:
>> Great!
>> Thanks Matthew, it is working for me up to that point!
>> We are continuing the ex44.c and forward it to you at the next blocking
>> point...
>> Eric
>> On 2021-10-27 11:14 a.m., Matthew Knepley wrote:
>> On Wed, Oct 27, 2021 at 8:29 AM Eric Chamberland <
>>> Hi Matthew,
>>> the smallest mesh which crashes the code is a 2x5 mesh:
>>> See the modified ex44.c
>>> With smaller meshes(2x2, 2x4, etc), it passes... But it bugs latter
>>> when I try to use DMPlexNaturalToGlobalBegin but let's keep that other
>>> problem for later...
>>> Thanks a lot for helping digging into this! :)
>> I have made a small fix in this branch
>> https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-g2n
>> It seems to run for me. Can you check it?
>> Thanks,
>> Matt
>>> Eric
>>> (sorry if you received this for a 2nd times, I have trouble with my
>>> mail)
>>> On 2021-10-26 4:35 p.m., Matthew Knepley wrote:
>>> On Tue, Oct 26, 2021 at 1:35 PM Eric Chamberland <
>>>> Here is a screenshot of the partition I hard coded (top) and
>>>> vertices/element numbers (down):
>>>> I have not yet modified the ex44.c example to properly assign the
>>>> coordinates...
>>>> (but I would not have done it like it is in the last version because
>>>> the sCoords array is the global array with global vertices number)
>>>> I will have time to do this tomorrow...
>>>> Maybe I can first try to reproduce all this with a smaller mesh?
>>> That might make it easier to find a problem.
>>> Thanks!
>>> Matt
>>>> Eric
>>>> On 2021-10-26 9:46 a.m., Matthew Knepley wrote:
>>>> Okay, I ran it. Something seems off with the mesh. First, I cannot
>>>> simply explain the partition. The number of shared vertices and edges
>>>> does not seem to come from a straight cut. Second, the mesh look
>>>> scrambled on output.
>>>> Thanks,
>>>> Matt
>>>> On Sun, Oct 24, 2021 at 11:49 PM Eric Chamberland <
>>>>> Hi Matthew,
>>>>> ok, I started back from your ex44.c example and added the global array
>>>>> of coordinates. I just have to code the creation of the local coordinates
>>>>> now.
>>>>> Eric
>>>>> On 2021-10-20 6:55 p.m., Matthew Knepley wrote:
>>>>> On Wed, Oct 20, 2021 at 3:06 PM Eric Chamberland <
>>>>>> Hi Matthew,
>>>>>> we tried to reproduce the error in a simple example.
>>>>>> The context is the following: We hard coded the mesh and initial
>>>>>> partition into the code (see sConnectivity and sInitialPartition) for 2
>>>>>> ranks and try to create a section in order to use the
>>>>>> DMPlexNaturalToGlobalBegin function to retreive our initial element numbers.
>>>>>> Now the call to DMPlexDistribute give different errors depending on
>>>>>> what type of component we ask the field to be created. For our objective,
>>>>>> we would like a global field to be created on elements only (like a P0
>>>>>> interpolation).
>>>>>> We now have the following error generated:
>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>> [0]PETSC ERROR: Petsc has generated inconsistent data
>>>>>> [0]PETSC ERROR: Inconsistency in indices, 18 should be 17
>>>>>> [0]PETSC ERROR: See
>>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>>> shooting.
>>>>>> [0]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021
>>>>>> [0]PETSC ERROR: ./bug on a named rohan by ericc Wed Oct 20 14:52:36
>>>>>> 2021
>>>>>> [0]PETSC ERROR: Configure options
>>>>>> --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7 --with-mpi-compilers=1
>>>>>> --with-mpi-dir=/opt/openmpi-4.1.0_gcc7 --with-cxx-dialect=C++14
>>>>>> --with-make-np=12 --with-shared-libraries=1 --with-debugging=yes
>>>>>> --with-memalign=64 --with-visibility=0 --with-64-bit-indices=0
>>>>>> --download-ml=yes --download-mumps=yes --download-superlu=yes
>>>>>> --download-hpddm=yes --download-slepc=yes --download-superlu_dist=yes
>>>>>> --download-parmetis=yes --download-ptscotch=yes --download-metis=yes
>>>>>> --download-strumpack=yes --download-suitesparse=yes --download-hypre=yes
>>>>>> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>>>> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>>>> --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>>>> --with-scalapack=1
>>>>>> --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include
>>>>>> --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>>>> -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
>>>>>> [0]PETSC ERROR: #1 PetscSFCreateSectionSF() at
>>>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/vec/is/sf/utils/sfutils.c:409
>>>>>> [0]PETSC ERROR: #2 DMPlexCreateGlobalToNaturalSF() at
>>>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:184
>>>>>> [0]PETSC ERROR: #3 DMPlexDistribute() at
>>>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexdistribute.c:1733
>>>>>> [0]PETSC ERROR: #4 main() at bug_section.cc:159
>>>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>>>> [0]PETSC ERROR: ----------------End of Error Message -------send
>>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>>> Hope the attached code is self-explaining, note that to make it
>>>>>> short, we have not included the final part of it, just the buggy part we
>>>>>> are encountering right now...
>>>>>> Thanks for your insights,
>>>>> Thanks for making the example. I tweaked it slightly. I put in a test
>>>>> case that just makes a parallel 7 x 10 quad mesh. This works
>>>>> fine. Thus I think it must be something connected with the original
>>>>> mesh. It is hard to get a handle on it without the coordinates.
>>>>> Do you think you could put the coordinate array in? I have added the
>>>>> code to load them (see attached file).
>>>>> Thanks,
>>>>> Matt
>>>>>> Eric
>>>>>> On 2021-10-06 9:23 p.m., Matthew Knepley wrote:
>>>>>> On Wed, Oct 6, 2021 at 5:43 PM Eric Chamberland <
>>>>>>> Hi Matthew,
>>>>>>> we tried to use that. Now, we discovered that:
>>>>>>> 1- even if we "ask" for sfNatural creation with DMSetUseNatural, it
>>>>>>> is not created because DMPlexCreateGlobalToNaturalSF looks for a "section":
>>>>>>> this is not documented in DMSetUseNaturalso we are asking ourselfs: "is
>>>>>>> this a permanent feature or a temporary situation?"
>>>>>> I think explaining this will help clear up a lot.
>>>>>> What the Natural2Global map does is permute a solution vector into
>>>>>> the ordering that it would have had prior to mesh distribution.
>>>>>> Now, in order to do this permutation, I need to know the original
>>>>>> (global) data layout. If it is not specified _before_ distribution, we
>>>>>> cannot build the permutation. The section describes the data layout,
>>>>>> so I need it before distribution.
>>>>>> I cannot think of another way that you would implement this, but if
>>>>>> you want something else, let me know.
>>>>>>> 2- We then tried to create a "section" in different manners: we took
>>>>>>> the code into the example petsc/src/dm/impls/plex/tests/ex15.c. However,
>>>>>>> we ended up with a segfault:
>>>>>>> corrupted size vs. prev_size
>>>>>>> [rohan:07297] *** Process received signal ***
>>>>>>> [rohan:07297] Signal: Aborted (6)
>>>>>>> [rohan:07297] Signal code: (-6)
>>>>>>> [rohan:07297] [ 0] /lib64/libpthread.so.0(+0x13f80)[0x7f6f13be3f80]
>>>>>>> [rohan:07297] [ 1] /lib64/libc.so.6(gsignal+0x10b)[0x7f6f109b718b]
>>>>>>> [rohan:07297] [ 2] /lib64/libc.so.6(abort+0x175)[0x7f6f109b8585]
>>>>>>> [rohan:07297] [ 3] /lib64/libc.so.6(+0x7e2f7)[0x7f6f109fb2f7]
>>>>>>> [rohan:07297] [ 4] /lib64/libc.so.6(+0x857ea)[0x7f6f10a027ea]
>>>>>>> [rohan:07297] [ 5] /lib64/libc.so.6(+0x86036)[0x7f6f10a03036]
>>>>>>> [rohan:07297] [ 6] /lib64/libc.so.6(+0x861a3)[0x7f6f10a031a3]
>>>>>>> [rohan:07297] [ 7] /lib64/libc.so.6(+0x88740)[0x7f6f10a05740]
>>>>>>> [rohan:07297] [ 8]
>>>>>>> /lib64/libc.so.6(__libc_malloc+0x1b8)[0x7f6f10a070c8]
>>>>>>> [rohan:07297] [ 9]
>>>>>>> /lib64/libc.so.6(__backtrace_symbols+0x134)[0x7f6f10a8b064]
>>>>>>> [rohan:07297] [10]
>>>>>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z12reqBacktraceRNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE+0x4e)[0x4538ce]
>>>>>>> [rohan:07297] [11]
>>>>>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z15attacheDebuggerv+0x120)[0x4523c0]
>>>>>>> [rohan:07297] [12]
>>>>>>> /home/mefpp_ericc/GIREF/lib/libgiref_dev_Util.so(traitementSignal+0x612)[0x7f6f28f503a2]
>>>>>>> [rohan:07297] [13] /lib64/libc.so.6(+0x3a210)[0x7f6f109b7210]
>>>>>>> [rohan:07297] [14]
>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscTrMallocDefault+0x6fd)[0x7f6f22f1b8ed]
>>>>>>> [rohan:07297] [15]
>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscMallocA+0x5cd)[0x7f6f22f19c2d]
>>>>>>> [rohan:07297] [16]
>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscSFCreateSectionSF+0xb48)[0x7f6f23268e18]
>>>>>>> [rohan:07297] [17]
>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexCreateGlobalToNaturalSF+0x13b2)[0x7f6f241a5602]
>>>>>>> [rohan:07297] [18]
>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexDistribute+0x39b1)[0x7f6f23fdca21]
>>>>>> I am not sure what happened here, but if you could send a sample
>>>>>> code, I will figure it out.
>>>>>>> If we do not create a section, the call to DMPlexDistribute is
>>>>>>> successful, but DMPlexGetGlobalToNaturalSF return a null SF pointer...
>>>>>> Yes, it just ignores it in this case because it does not have a
>>>>>> global layout.
>>>>>>> Here are the operations we are calling ( this is almost the code we
>>>>>>> are using, I just removed verifications and creation of the connectivity
>>>>>>> which use our parallel structure and code):
>>>>>>> PetscInt* lCells = 0;
>>>>>>> PetscInt lNumCorners = 0;
>>>>>>> PetscInt lDimMail = 0;
>>>>>>> PetscInt lnumCells = 0;
>>>>>>> //At this point we create the cells for PETSc expected input for
>>>>>>> DMPlexBuildFromCellListParallel and set lNumCorners, lDimMail and lnumCells
>>>>>>> to correct values.
>>>>>>> DM lDMBete = 0
>>>>>>> DMPlexCreate(lMPIComm,&lDMBete);
>>>>>>> DMSetDimension(lDMBete, lDimMail);
>>>>>>> DMPlexBuildFromCellListParallel(lDMBete,
>>>>>>> lnumCells,
>>>>>>> PETSC_DECIDE,
>>>>>>> pLectureElementsLocaux.reqNbTotalSommets(),
>>>>>>> lNumCorners,
>>>>>>> lCells,
>>>>>>> PETSC_NULL);
>>>>>>> DM lDMBeteInterp = 0;
>>>>>>> DMPlexInterpolate(lDMBete, &lDMBeteInterp);
>>>>>>> DMDestroy(&lDMBete);
>>>>>>> lDMBete = lDMBeteInterp;
>>>>>>> DMSetUseNatural(lDMBete,PETSC_TRUE);
>>>>>>> PetscSF lSFMigrationSansOvl = 0;
>>>>>>> PetscSF lSFMigrationOvl = 0;
>>>>>>> DM lDMDistribueSansOvl = 0;
>>>>>>> DM lDMAvecOverlap = 0;
>>>>>>> PetscPartitioner lPart;
>>>>>>> DMPlexGetPartitioner(lDMBete, &lPart);
>>>>>>> PetscPartitionerSetFromOptions(lPart);
>>>>>>> PetscSection section;
>>>>>>> PetscInt numFields = 1;
>>>>>>> PetscInt numBC = 0;
>>>>>>> PetscInt numComp[1] = {1};
>>>>>>> PetscInt numDof[4] = {1, 0, 0, 0};
>>>>>>> PetscInt bcFields[1] = {0};
>>>>>>> IS bcPoints[1] = {NULL};
>>>>>>> DMSetNumFields(lDMBete, numFields);
>>>>>>> DMPlexCreateSection(lDMBete, NULL, numComp, numDof, numBC,
>>>>>>> bcFields, bcPoints, NULL, NULL, §ion);
>>>>>>> DMSetLocalSection(lDMBete, section);
>>>>>>> DMPlexDistribute(lDMBete, 0, &lSFMigrationSansOvl,
>>>>>>> &lDMDistribueSansOvl); // segfault!
>>>>>>> So we have other question/remarks:
>>>>>>> 3- Maybe PETSc expect something specific that is missing/not
>>>>>>> verified: for example, we didn't gave any coordinates since we just want to
>>>>>>> partition and compute overlap for the mesh... and then recover our element
>>>>>>> numbers in a "simple way"
>>>>>>> 4- We are telling ourselves it is somewhat a "big price to pay" to
>>>>>>> have to build an unused section to have the global to natural ordering set
>>>>>>> ? Could this requirement be avoided?
>>>>>> I don't think so. There would have to be _some_ way of describing
>>>>>> your data layout in terms of mesh points, and I do not see how you could
>>>>>> use less memory doing that.
>>>>>>> 5- Are there any improvement towards our usages in 3.16 release?
>>>>>> Let me try and run the code above.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> Thanks,
>>>>>>> Eric
>>>>>>> On 2021-09-29 7:39 p.m., Matthew Knepley wrote:
>>>>>>> On Wed, Sep 29, 2021 at 5:18 PM Eric Chamberland <
>>>>>>>> Hi,
>>>>>>>> I come back with _almost_ the original question:
>>>>>>>> I would like to add an integer information (*our* original element
>>>>>>>> number, not petsc one) on each element of the DMPlex I create with
>>>>>>>> DMPlexBuildFromCellListParallel.
>>>>>>>> I would like this interger to be distribruted by or the same way
>>>>>>>> DMPlexDistribute distribute the mesh.
>>>>>>>> Is it possible to do this?
>>>>>>> I think we already have support for what you want. If you call
>>>>>>> https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html
>>>>>>> before DMPlexDistribute(), it will compute a PetscSF encoding the
>>>>>>> global to natural map. You
>>>>>>> can get it with
>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html
>>>>>>> and use it with
>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
>>>>>>> Is this sufficient?
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>>> Thanks,
>>>>>>>> Eric
>>>>>>>> On 2021-07-14 1:18 p.m., Eric Chamberland wrote:
>>>>>>>> > Hi,
>>>>>>>> > I want to use DMPlexDistribute from PETSc for computing
>>>>>>>> overlapping
>>>>>>>> > and play with the different partitioners supported.
>>>>>>>> > However, after calling DMPlexDistribute, I noticed the elements
>>>>>>>> are
>>>>>>>> > renumbered and then the original number is lost.
>>>>>>>> > What would be the best way to keep track of the element
>>>>>>>> renumbering?
>>>>>>>> > a) Adding an optional parameter to let the user retrieve a vector
>>>>>>>> or
>>>>>>>> > "IS" giving the old number?
>>>>>>>> > b) Adding a DMLabel (seems a wrong good solution)
>>>>>>>> > c) Other idea?
>>>>>>>> > Of course, I don't want to loose performances with the need of
>>>>>>>> this
>>>>>>>> > "mapping"...
>>>>>>>> > Thanks,
>>>>>>>> > Eric
>>>>>>>> Eric Chamberland, ing., M. Ing
>>>>>>>> Professionnel de recherche
>>>>>>>> GIREF/Université Laval
>>>>>>>> (418) 656-2131 poste 41 22 42
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211102/9f2a061e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211102/9f2a061e/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211102/9f2a061e/attachment-0003.png>
