[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Mon Nov 1 16:24:29 CDT 2021
Hi Matthew,
ok, good news then! :)
Meanwhile, I tested it the "other way" with
DMPlexGlobalToNaturalBegin/End and it does not give a "sensed" result
neither.
Probably it does something like "GlobalToSequential" too?
Thanks!
Eric
On 2021-11-01 3:25 p.m., Matthew Knepley wrote:
> On Sun, Oct 31, 2021 at 10:07 AM Eric Chamberland
> <Eric.Chamberland at giref.ulaval.ca
> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
> Hi Matthew,
> we do not know if DMPlexNaturalToGlobalBegin/End is buggy or if it
> is our comprehension of what it should do that is wrong...
> Would you just check if what we try to do from line 313 to 356 is
> good or wrong?
> The expected result is that the global vector "lGlobalVec"
> contains the element numbers from the initial partition that have
> been put into "lNatVec".
> Thanks a lot for any insights!!
> Okay, I have found the problem.I confess to not actually looking very
> closely at the implementation before. GlobalToNatural was assuming that
> the "natural" was also sequential, and looking at it all the tests are
> eq-to-parallel distribution. I need to fix it for a parallel natural
> state. Hopefully
> it will not take me long.
> Thanks,
> Matt
> Eric
> On 2021-10-27 2:32 p.m., Eric Chamberland wrote:
>> Hi Matthew,
>> we continued the example. Now it must be our misuse of PETSc
>> that produced the wrong result.
>> As stated into the code:
>> // The call to DMPlexNaturalToGlobalBegin/End does not produce
>> our expected result...
>> // In lGlobalVec, we expect to have:
>> * Process [0]
>> * 2.
>> * 4.
>> * 8.
>> * 3.
>> * 9.
>> * Process [1]
>> * 1.
>> * 5.
>> * 7.
>> * 0.
>> * 6.
>> * but we obtained:
>> * Process [0]
>> * 2.
>> * 4.
>> * 8.
>> * 0.
>> * 0.
>> * Process [1]
>> * 0.
>> * 0.
>> * 0.
>> * 0.
>> * 0.
>> (see attached ex44.c)
>> Thanks,
>> Eric
>> On 2021-10-27 1:25 p.m., Eric Chamberland wrote:
>>> Great!
>>> Thanks Matthew, it is working for me up to that point!
>>> We are continuing the ex44.c and forward it to you at the next
>>> blocking point...
>>> Eric
>>> On 2021-10-27 11:14 a.m., Matthew Knepley wrote:
>>>> On Wed, Oct 27, 2021 at 8:29 AM Eric Chamberland
>>>> Hi Matthew,
>>>> the smallest mesh which crashes the code is a 2x5 mesh:
>>>> See the modified ex44.c
>>>> With smaller meshes(2x2, 2x4, etc), it passes... But it
>>>> bugs latter when I try to use DMPlexNaturalToGlobalBegin
>>>> but let's keep that other problem for later...
>>>> Thanks a lot for helping digging into this! :)
>>>> I have made a small fix in this branch
>>>> https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-g2n
>>>> <https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-g2n>
>>>> It seems to run for me. Can you check it?
>>>> Thanks,
>>>> Matt
>>>> Eric
>>>> (sorry if you received this for a 2nd times, I have
>>>> trouble with my mail)
>>>> On 2021-10-26 4:35 p.m., Matthew Knepley wrote:
>>>>> On Tue, Oct 26, 2021 at 1:35 PM Eric Chamberland
>>>>> Here is a screenshot of the partition I hard coded
>>>>> (top) and vertices/element numbers (down):
>>>>> I have not yet modified the ex44.c example to properly
>>>>> assign the coordinates...
>>>>> (but I would not have done it like it is in the last
>>>>> version because the sCoords array is the global array
>>>>> with global vertices number)
>>>>> I will have time to do this tomorrow...
>>>>> Maybe I can first try to reproduce all this with a
>>>>> smaller mesh?
>>>>> That might make it easier to find a problem.
>>>>> Thanks!
>>>>> Matt
>>>>> Eric
>>>>> On 2021-10-26 9:46 a.m., Matthew Knepley wrote:
>>>>>> Okay, I ran it. Something seems off with the mesh.
>>>>>> First, I cannot simply explain the partition. The
>>>>>> number of shared vertices and edges
>>>>>> does not seem to come from a straight cut. Second,
>>>>>> the mesh look scrambled on output.
>>>>>> Thanks,
>>>>>> Matt
>>>>>> On Sun, Oct 24, 2021 at 11:49 PM Eric Chamberland
>>>>>> Hi Matthew,
>>>>>> ok, I started back from your ex44.c example and
>>>>>> added the global array of coordinates. I just
>>>>>> have to code the creation of the local
>>>>>> coordinates now.
>>>>>> Eric
>>>>>> On 2021-10-20 6:55 p.m., Matthew Knepley wrote:
>>>>>>> On Wed, Oct 20, 2021 at 3:06 PM Eric Chamberland
>>>>>>> Hi Matthew,
>>>>>>> we tried to reproduce the error in a simple
>>>>>>> example.
>>>>>>> The context is the following: We hard coded
>>>>>>> the mesh and initial partition into the code
>>>>>>> (see sConnectivity and sInitialPartition)
>>>>>>> for 2 ranks and try to create a section in
>>>>>>> order to use the DMPlexNaturalToGlobalBegin
>>>>>>> function to retreive our initial element
>>>>>>> numbers.
>>>>>>> Now the call to DMPlexDistribute give
>>>>>>> different errors depending on what type of
>>>>>>> component we ask the field to be created.
>>>>>>> For our objective, we would like a global
>>>>>>> field to be created on elements only (like a
>>>>>>> P0 interpolation).
>>>>>>> We now have the following error generated:
>>>>>>> [0]PETSC ERROR: --------------------- Error
>>>>>>> Message
>>>>>>> [0]PETSC ERROR: Petsc has generated
>>>>>>> inconsistent data
>>>>>>> [0]PETSC ERROR: Inconsistency in indices, 18
>>>>>>> should be 17
>>>>>>> [0]PETSC ERROR: See
>>>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>>>> <https://www.mcs.anl.gov/petsc/documentation/faq.html>
>>>>>>> for trouble shooting.
>>>>>>> [0]PETSC ERROR: Petsc Release Version
>>>>>>> 3.15.0, Mar 30, 2021
>>>>>>> [0]PETSC ERROR: ./bug on a named rohan by
>>>>>>> ericc Wed Oct 20 14:52:36 2021
>>>>>>> [0]PETSC ERROR: Configure options
>>>>>>> --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7
>>>>>>> --with-mpi-compilers=1
>>>>>>> --with-mpi-dir=/opt/openmpi-4.1.0_gcc7
>>>>>>> --with-cxx-dialect=C++14 --with-make-np=12
>>>>>>> --with-shared-libraries=1
>>>>>>> --with-debugging=yes --with-memalign=64
>>>>>>> --with-visibility=0 --with-64-bit-indices=0
>>>>>>> --download-ml=yes --download-mumps=yes
>>>>>>> --download-superlu=yes --download-hpddm=yes
>>>>>>> --download-slepc=yes
>>>>>>> --download-superlu_dist=yes
>>>>>>> --download-parmetis=yes
>>>>>>> --download-ptscotch=yes --download-metis=yes
>>>>>>> --download-strumpack=yes
>>>>>>> --download-suitesparse=yes
>>>>>>> --download-hypre=yes
>>>>>>> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>>>>> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>>>>> --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>>>>> --with-scalapack=1
>>>>>>> --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include
>>>>>>> --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>>>>> -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
>>>>>>> [0]PETSC ERROR: #1 PetscSFCreateSectionSF()
>>>>>>> at
>>>>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/vec/is/sf/utils/sfutils.c:409
>>>>>>> [0]PETSC ERROR: #2
>>>>>>> DMPlexCreateGlobalToNaturalSF() at
>>>>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:184
>>>>>>> [0]PETSC ERROR: #3 DMPlexDistribute() at
>>>>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexdistribute.c:1733
>>>>>>> [0]PETSC ERROR: #4 main() at bug_section.cc:159
>>>>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>>>>> [0]PETSC ERROR: ----------------End of Error
>>>>>>> Message -------send entire error message to
>>>>>>> petsc-maint at mcs.anl.gov
>>>>>>> <mailto:petsc-maint at mcs.anl.gov>----------
>>>>>>> Hope the attached code is self-explaining,
>>>>>>> note that to make it short, we have not
>>>>>>> included the final part of it, just the
>>>>>>> buggy part we are encountering right now...
>>>>>>> Thanks for your insights,
>>>>>>> Thanks for making the example. I tweaked it
>>>>>>> slightly. I put in a test case that just makes a
>>>>>>> parallel 7 x 10 quad mesh. This works
>>>>>>> fine. Thus I think it must be something
>>>>>>> connected with the original mesh. It is hard to
>>>>>>> get a handle on it without the coordinates.
>>>>>>> Do you think you could put the coordinate array
>>>>>>> in? I have added the code to load them (see
>>>>>>> attached file).
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>> Eric
>>>>>>> On 2021-10-06 9:23 p.m., Matthew Knepley wrote:
>>>>>>>> On Wed, Oct 6, 2021 at 5:43 PM Eric
>>>>>>>> Chamberland
>>>>>>>> wrote:
>>>>>>>> Hi Matthew,
>>>>>>>> we tried to use that. Now, we
>>>>>>>> discovered that:
>>>>>>>> 1- even if we "ask" for sfNatural
>>>>>>>> creation with DMSetUseNatural, it is
>>>>>>>> not created because
>>>>>>>> DMPlexCreateGlobalToNaturalSF looks for
>>>>>>>> a "section": this is not documented in
>>>>>>>> DMSetUseNaturalso we are asking
>>>>>>>> ourselfs: "is this a permanent feature
>>>>>>>> or a temporary situation?"
>>>>>>>> I think explaining this will help clear up
>>>>>>>> a lot.
>>>>>>>> What the Natural2Global map does is permute
>>>>>>>> a solution vector into the ordering that it
>>>>>>>> would have had prior to mesh distribution.
>>>>>>>> Now, in order to do this permutation, I
>>>>>>>> need to know the original (global) data
>>>>>>>> layout. If it is not specified _before_
>>>>>>>> distribution, we
>>>>>>>> cannot build the permutation. The section
>>>>>>>> describes the data layout, so I need it
>>>>>>>> before distribution.
>>>>>>>> I cannot think of another way that you
>>>>>>>> would implement this, but if you want
>>>>>>>> something else, let me know.
>>>>>>>> 2- We then tried to create a "section"
>>>>>>>> in different manners: we took the code
>>>>>>>> into the example
>>>>>>>> petsc/src/dm/impls/plex/tests/ex15.c.
>>>>>>>> However, we ended up with a segfault:
>>>>>>>> corrupted size vs. prev_size
>>>>>>>> [rohan:07297] *** Process received
>>>>>>>> signal ***
>>>>>>>> [rohan:07297] Signal: Aborted (6)
>>>>>>>> [rohan:07297] Signal code: (-6)
>>>>>>>> [rohan:07297] [ 0]
>>>>>>>> /lib64/libpthread.so.0(+0x13f80)[0x7f6f13be3f80]
>>>>>>>> [rohan:07297] [ 1]
>>>>>>>> /lib64/libc.so.6(gsignal+0x10b)[0x7f6f109b718b]
>>>>>>>> [rohan:07297] [ 2]
>>>>>>>> /lib64/libc.so.6(abort+0x175)[0x7f6f109b8585]
>>>>>>>> [rohan:07297] [ 3]
>>>>>>>> /lib64/libc.so.6(+0x7e2f7)[0x7f6f109fb2f7]
>>>>>>>> [rohan:07297] [ 4]
>>>>>>>> /lib64/libc.so.6(+0x857ea)[0x7f6f10a027ea]
>>>>>>>> [rohan:07297] [ 5]
>>>>>>>> /lib64/libc.so.6(+0x86036)[0x7f6f10a03036]
>>>>>>>> [rohan:07297] [ 6]
>>>>>>>> /lib64/libc.so.6(+0x861a3)[0x7f6f10a031a3]
>>>>>>>> [rohan:07297] [ 7]
>>>>>>>> /lib64/libc.so.6(+0x88740)[0x7f6f10a05740]
>>>>>>>> [rohan:07297] [ 8]
>>>>>>>> /lib64/libc.so.6(__libc_malloc+0x1b8)[0x7f6f10a070c8]
>>>>>>>> [rohan:07297] [ 9]
>>>>>>>> /lib64/libc.so.6(__backtrace_symbols+0x134)[0x7f6f10a8b064]
>>>>>>>> [rohan:07297] [10]
>>>>>>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z12reqBacktraceRNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE+0x4e)[0x4538ce]
>>>>>>>> [rohan:07297] [11]
>>>>>>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z15attacheDebuggerv+0x120)[0x4523c0]
>>>>>>>> [rohan:07297] [12]
>>>>>>>> /home/mefpp_ericc/GIREF/lib/libgiref_dev_Util.so(traitementSignal+0x612)[0x7f6f28f503a2]
>>>>>>>> [rohan:07297] [13]
>>>>>>>> /lib64/libc.so.6(+0x3a210)[0x7f6f109b7210]
>>>>>>>> [rohan:07297] [14]
>>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscTrMallocDefault+0x6fd)[0x7f6f22f1b8ed]
>>>>>>>> [rohan:07297] [15]
>>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscMallocA+0x5cd)[0x7f6f22f19c2d]
>>>>>>>> [rohan:07297] [16]
>>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscSFCreateSectionSF+0xb48)[0x7f6f23268e18]
>>>>>>>> [rohan:07297] [17]
>>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexCreateGlobalToNaturalSF+0x13b2)[0x7f6f241a5602]
>>>>>>>> [rohan:07297] [18]
>>>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexDistribute+0x39b1)[0x7f6f23fdca21]
>>>>>>>> I am not sure what happened here, but if
>>>>>>>> you could send a sample code, I will figure
>>>>>>>> it out.
>>>>>>>> If we do not create a section, the call
>>>>>>>> to DMPlexDistribute is successful, but
>>>>>>>> DMPlexGetGlobalToNaturalSF return a
>>>>>>>> null SF pointer...
>>>>>>>> Yes, it just ignores it in this case
>>>>>>>> because it does not have a global layout.
>>>>>>>> Here are the operations we are calling
>>>>>>>> ( this is almost the code we are using,
>>>>>>>> I just removed verifications and
>>>>>>>> creation of the connectivity which use
>>>>>>>> our parallel structure and code):
>>>>>>>> PetscInt* lCells = 0;
>>>>>>>> PetscInt lNumCorners = 0;
>>>>>>>> PetscInt lDimMail = 0;
>>>>>>>> PetscInt lnumCells = 0;
>>>>>>>> //At this point we create the cells
>>>>>>>> for PETSc expected input for
>>>>>>>> DMPlexBuildFromCellListParallel and set
>>>>>>>> lNumCorners, lDimMail and lnumCells to
>>>>>>>> correct values.
>>>>>>>> DM lDMBete = 0
>>>>>>>> DMPlexCreate(lMPIComm,&lDMBete);
>>>>>>>> DMSetDimension(lDMBete, lDimMail);
>>>>>>>> DMPlexBuildFromCellListParallel(lDMBete,
>>>>>>>> lnumCells,
>>>>>>>> PETSC_DECIDE,
>>>>>>>> pLectureElementsLocaux.reqNbTotalSommets(),
>>>>>>>> lNumCorners,
>>>>>>>> lCells,
>>>>>>>> PETSC_NULL);
>>>>>>>> DM lDMBeteInterp = 0;
>>>>>>>> DMPlexInterpolate(lDMBete, &lDMBeteInterp);
>>>>>>>> DMDestroy(&lDMBete);
>>>>>>>> lDMBete = lDMBeteInterp;
>>>>>>>> DMSetUseNatural(lDMBete,PETSC_TRUE);
>>>>>>>> PetscSF lSFMigrationSansOvl = 0;
>>>>>>>> PetscSF lSFMigrationOvl = 0;
>>>>>>>> DM lDMDistribueSansOvl = 0;
>>>>>>>> DM lDMAvecOverlap = 0;
>>>>>>>> PetscPartitioner lPart;
>>>>>>>> DMPlexGetPartitioner(lDMBete, &lPart);
>>>>>>>> PetscPartitionerSetFromOptions(lPart);
>>>>>>>> PetscSection section;
>>>>>>>> PetscInt numFields = 1;
>>>>>>>> PetscInt numBC = 0;
>>>>>>>> PetscInt numComp[1] = {1};
>>>>>>>> PetscInt numDof[4] = {1, 0, 0, 0};
>>>>>>>> PetscInt bcFields[1] = {0};
>>>>>>>> IS bcPoints[1] = {NULL};
>>>>>>>> DMSetNumFields(lDMBete, numFields);
>>>>>>>> DMPlexCreateSection(lDMBete, NULL,
>>>>>>>> numComp, numDof, numBC, bcFields,
>>>>>>>> bcPoints, NULL, NULL, §ion);
>>>>>>>> DMSetLocalSection(lDMBete, section);
>>>>>>>> DMPlexDistribute(lDMBete, 0,
>>>>>>>> &lSFMigrationSansOvl,
>>>>>>>> &lDMDistribueSansOvl); // segfault!
>>>>>>>> So we have other question/remarks:
>>>>>>>> 3- Maybe PETSc expect something
>>>>>>>> specific that is missing/not verified:
>>>>>>>> for example, we didn't gave any
>>>>>>>> coordinates since we just want to
>>>>>>>> partition and compute overlap for the
>>>>>>>> mesh... and then recover our element
>>>>>>>> numbers in a "simple way"
>>>>>>>> 4- We are telling ourselves it is
>>>>>>>> somewhat a "big price to pay" to have
>>>>>>>> to build an unused section to have the
>>>>>>>> global to natural ordering set ? Could
>>>>>>>> this requirement be avoided?
>>>>>>>> I don't think so. There would have to be
>>>>>>>> _some_ way of describing your data layout
>>>>>>>> in terms of mesh points, and I do not see
>>>>>>>> how you could use less memory doing that.
>>>>>>>> 5- Are there any improvement towards
>>>>>>>> our usages in 3.16 release?
>>>>>>>> Let me try and run the code above.
>>>>>>>> Thanks,
>>>>>>>> Matt
>>>>>>>> Thanks,
>>>>>>>> Eric
>>>>>>>> On 2021-09-29 7:39 p.m., Matthew
>>>>>>>> Knepley wrote:
>>>>>>>>> On Wed, Sep 29, 2021 at 5:18 PM Eric
>>>>>>>>> Chamberland
>>>>>>>>> wrote:
>>>>>>>>> Hi,
>>>>>>>>> I come back with _almost_ the
>>>>>>>>> original question:
>>>>>>>>> I would like to add an integer
>>>>>>>>> information (*our* original element
>>>>>>>>> number, not petsc one) on each
>>>>>>>>> element of the DMPlex I create with
>>>>>>>>> DMPlexBuildFromCellListParallel.
>>>>>>>>> I would like this interger to be
>>>>>>>>> distribruted by or the same way
>>>>>>>>> DMPlexDistribute distribute the mesh.
>>>>>>>>> Is it possible to do this?
>>>>>>>>> I think we already have support for
>>>>>>>>> what you want. If you call
>>>>>>>>> https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html
>>>>>>>>> <https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html>
>>>>>>>>> before DMPlexDistribute(), it will
>>>>>>>>> compute a PetscSF encoding the global
>>>>>>>>> to natural map. You
>>>>>>>>> can get it with
>>>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html
>>>>>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html>
>>>>>>>>> and use it with
>>>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
>>>>>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html>
>>>>>>>>> Is this sufficient?
>>>>>>>>> Thanks,
>>>>>>>>> Matt
>>>>>>>>> Thanks,
>>>>>>>>> Eric
>>>>>>>>> On 2021-07-14 1:18 p.m., Eric
>>>>>>>>> Chamberland wrote:
>>>>>>>>> > Hi,
>>>>>>>>> > I want to use DMPlexDistribute
>>>>>>>>> from PETSc for computing overlapping
>>>>>>>>> > and play with the different
>>>>>>>>> partitioners supported.
>>>>>>>>> > However, after calling
>>>>>>>>> DMPlexDistribute, I noticed the
>>>>>>>>> elements are
>>>>>>>>> > renumbered and then the original
>>>>>>>>> number is lost.
>>>>>>>>> > What would be the best way to
>>>>>>>>> keep track of the element renumbering?
>>>>>>>>> > a) Adding an optional parameter
>>>>>>>>> to let the user retrieve a vector or
>>>>>>>>> > "IS" giving the old number?
>>>>>>>>> > b) Adding a DMLabel (seems a
>>>>>>>>> wrong good solution)
>>>>>>>>> > c) Other idea?
>>>>>>>>> > Of course, I don't want to loose
>>>>>>>>> performances with the need of this
>>>>>>>>> > "mapping"...
>>>>>>>>> > Thanks,
>>>>>>>>> > Eric
>>>>>>>>> Eric Chamberland, ing., M. Ing
>>>>>>>>> Professionnel de recherche
>>>>>>>>> GIREF/Université Laval
>>>>>>>>> (418) 656-2131 poste 41 22 42
>>>>>>>>> What most experimenters take for
>>>>>>>>> granted before they begin their
>>>>>>>>> experiments is infinitely more
>>>>>>>>> interesting than any results to which
>>>>>>>>> their experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>> What most experimenters take for granted
>>>>>>>> before they begin their experiments is
>>>>>>>> infinitely more interesting than any
>>>>>>>> results to which their experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> What most experimenters take for granted before
>>>>>>> they begin their experiments is infinitely more
>>>>>>> interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> What most experimenters take for granted before they
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> What most experimenters take for granted before they begin
>>>>> their experiments is infinitely more interesting than any
>>>>> -- Norbert Wiener
>>>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211101/a74d2399/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211101/a74d2399/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211101/a74d2399/attachment-0003.png>
