[petsc-users] Did CUDA break again?
Barry Smith
bsmith at petsc.dev
Wed May 26 18:13:24 CDT 2021
What is HOST=cori09 Does it have GPUs?
https://docs.nvidia.com/cuda/cuda-runtime-api/structcudaDeviceProp.html#structcudaDeviceProp_164490976c8e07e028a8f1ce1f5cd42d6 <https://docs.nvidia.com/cuda/cuda-runtime-api/structcudaDeviceProp.html#structcudaDeviceProp_164490976c8e07e028a8f1ce1f5cd42d6>
Seems to clearly state
int cudaDeviceProp <https://docs.nvidia.com/cuda/cuda-runtime-api/structcudaDeviceProp.html#structcudaDeviceProp>::major <https://docs.nvidia.com/cuda/cuda-runtime-api/structcudaDeviceProp.html#structcudaDeviceProp_164490976c8e07e028a8f1ce1f5cd42d6> [inherited]
Major compute capability
Mark, please compile and run this program on the machine you are running configure on
#include <stdio.h>
#include <cuda.h>
#include <cuda_runtime.h>
#include <cuda_runtime_api.h>
#include <cuda_device_runtime_api.h>
int main(int arg,char **args)
struct cudaDeviceProp dp;
cudaGetDeviceProperties(&dp, 0);
printf("%d\n",10*dp.major+dp.minor);
int major,minor;
cuDeviceGetAttribute(&major, CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MAJOR, 0);
cuDeviceGetAttribute(&minor, CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MINOR, 0);
printf("%d\n",10*major+minor);
return(0);
This is what I get
$ nvcc mytest.c -lcuda
~/petsc (main=) arch-main
$ ./a.out
70
70
Which is exactly what it is suppose to do.
Barry
> On May 26, 2021, at 5:31 PM, Barry Smith <bsmith at petsc.dev> wrote:
> Yes, this code which I guess never got hit before
> cudaDeviceProp dp; cudaGetDeviceProperties(&dp, 0); printf("%d\n",10*dp.major+dp.minor); return(0);;
> is using the wrong property for the generation.
> Back to the CUDA documentation for the correct information.
>> On May 26, 2021, at 3:47 PM, Jacob Faibussowitsch <jacob.fai at gmail.com> wrote:
>> 1120 sounds suspiciously like some CUDA version rather than architecture or compute capability…
>> Best regards,
>> (Jacob Fai - booss - oh - vitch)
>> Cell: +1 (312) 694-3391
>>> On May 26, 2021, at 22:29, Mark Adams <mfadams at lbl.gov> wrote:
>>> I started to get this error today on Cori.
>>> nvcc fatal : Unsupported gpu architecture 'compute_1120'
>>> I am pretty sure I had a clean build but I can redo it if you don't know where this is from.
>>> Thanks,
>>> Mark
>>> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210526/0201ef10/attachment.html>
