[petsc-users] DMPlex from periodic Gmsh and ghost cells
Thibault Bridel-Bertomeu thibault.bridelbertomeu at gmail.com
Wed May 19 03:36:26 CDT 2021
Hello Matt,
Le mar. 18 mai 2021 à 20:31, Matthew Knepley <knepley at gmail.com> a écrit :
> On Tue, May 18, 2021 at 12:16 PM Thibault Bridel-Bertomeu <
> thibault.bridelbertomeu at gmail.com> wrote:
>> Hi Matthew,
>> Thank you very much for your quick answer, as always !
> Cool.
>> Le mar. 18 mai 2021 à 17:46, Matthew Knepley <knepley at gmail.com> a
>> écrit :
>>> On Tue, May 18, 2021 at 5:19 AM Thibault Bridel-Bertomeu <
>>>> Dear all,
>>>> I am playing around with creating DMPlex from a periodic Gmsh mesh
>>>> (still in the same finite volume code that solves the Euler equations)
>>>> because I want to run some classical periodic test cases from the
>>>> literature (like convecting a vortex and so on).
>>>> I got from the mailing list and the examples that I gotta use
>>>> -dm_plex_gmsh_periodic for the reader and the DM creator to do their job
>>>> properly and read the $Periodic section from the Gmsh mesh. That works
>>>> fine, I can write the DM in HDF5 format afterwards and the periodicity is
>>>> clearly there (i can see in Paraview that opposite sides are "attached" to
>>>> each other).
>>>> Now, in the context of the finite volume solver, I wrote my one
>>>> right-hand side term computing routine, and I rely heavily on routines such
>>>> as DMPlexGetFaceFields. Those routines, in turn rely on the ghost cells and
>>>> ... I am having an issue with DMPlexConstructGhostCells. When I use
>>>> -dm_plex_gmsh_periodic, DMPlexCreateFromFile works fine,
>>>> DMSetBasicAdjacency(dm, true, false) works fine, DMPlexDistribute works
>>>> fine, but when I get to DMPlexConstructGhostCells, I get
>>>>  "DM has boundary face 2048 with 2 support cells"
>>>> I understand the DM begin periodic, even the "boundary" faces have two
>>>> neighbors because of the topological folding, so ... yeah, the ghost cells
>>>> cannot really exist. But then how can I proceed ? Because I need that
>>>> "ghost" label for all the routines I call from the RHS computing routine ...
>>> Thanks for the example. I have run this myself.  It looks to me like the
>>> mesh you are providing. Has no boundary. It is doubly periodic (a torus).
>>> When I tell ConstructGhostCells() to
>>> create a label for the boundary, rather than using "Face Sets", it
>>> creates an empty label because no faces have only 1 neighbor.
>> Yes indeed, up is down and right is left for this mesh, the idea being of
>> emulating an infinite medium.
>> So you manage to get through ConstructGhostCells without a segfault ?
>> What did you specify instead of PETSC_NULL_CHARACTER ?
> The NULL tells it to use the label "Face Sets", but that label coming from
> Gmsh marks edges that are not actually boundaries. I asked PETSc
> to create a boundary label named "marker" using
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexMarkBoundaryFaces.html
> It was empty, but everything goes through fine.
OK thanks ! I had to write the F90 wrapper for DMLabelCreate but aside from
that, everything indeed goes through fine with the ConstructGhostCells.
>> Also, does it still create a « ghost » label even if it’s empty ?
> Yes.
>> Do you think that will hold for later uses in the GetFaceFields and
>> similar routines ?
> Yes.
>> I read through the source and it seems it won’t like it much if there are
>> no ghost at all, but since I did not pass the ConstructGhostCell step I’m
>> not sure.
> It should work fine, you just will not need boundary conditions.
Actually, there is an issue with the corner cells. My mesh is periodic in
both directions and it turns out the corner cells accumulate way too much
numerical flux and the computation crashes after 4 iterations or so - it
happens both with quads and tris. Whether I use my version of the RHS
computing routine or the DMPlexTSComputeRHSFunctionFVM leads to the same
crash.
I'll keep investigating, but if you have any idea what could go wrong ...
Thanks !!
Thibault
>   Thanks,
>     Matt
>> Thanks !
>> Thibault
>>>   Thanks,
>>>      Matt
>>>> I attach to this email the periodic Gmsh mesh I am playing with, and
>>>> the routine from my code where I create the DM and so on:
>>>> subroutine initmesh
>>>> PetscErrorCode :: ierr
>>>> DM :: dmDist, dmGhost
>>>> integer :: overlap
>>>> PetscViewer :: vtkViewer
>>>> call PetscLogEventBegin(timer_initmesh, ierr); CHKERRA(ierr)
>>>> ! Number of neighbours taken into account in MP communications(1 -
>>>> Order 1; 2 - Order 2)
>>>> overlap = 1
>>>> call PetscPrintf(PETSC_COMM_WORLD, "Initializing mesh...\n", ierr) ;
>>>> CHKERRA(ierr)
>>>> ! Force DMPlex to use gmsh marker
>>>> ! call PetscOptionsSetValue(PETSC_NULL_OPTIONS,
>>>> "-dm_plex_gmsh_use_marker", "true", ierr); CHKERRA(ierr)
>>>> ! Read mesh from file name 'meshname'
>>>> call DMPlexCreateFromFile(PETSC_COMM_WORLD, meshname, PETSC_TRUE, dm,
>>>> ! Distribute on processors
>>>> ! Start with connectivity
>>>> call DMSetBasicAdjacency(dm, PETSC_TRUE, PETSC_FALSE, ierr) ;
>>>> CHKERRA(ierr)
>>>> call DMPlexDistribute(dm, overlap, PETSC_NULL_SF, dmDist, ierr) ;
>>>> CHKERRA(ierr)
>>>> ! Security check
>>>> if (dmDist /= PETSC_NULL_DM) then
>>>> ! Destroy previous dm
>>>> call DMDestroy(dm, ierr) ; CHKERRA(ierr)
>>>> ! Replace with dmDist
>>>> dm = dmDist
>>>> end if
>>>> ! Finalize setup of the object
>>>> call DMSetFromOptions(dm, ierr) ; CHKERRA(ierr)
>>>> ! Boundary condition with ghost cells
>>>> call DMPlexConstructGhostCells(dm, PETSC_NULL_CHARACTER,
>>>> PETSC_NULL_INTEGER, dmGhost, ierr); CHKERRA(ierr)
>>>> ! Security check
>>>> if (dmGhost /= PETSC_NULL_DM) then
>>>> ! Replace with dmGhost
>>>> dm = dmGhost
>>>> end if
>>>> if (debug) then
>>>> ! Show in terminal
>>>> call PetscPrintf(PETSC_COMM_WORLD, ":: [DEBUG] Visualizing DM in
>>>> console ::\n", ierr); CHKERRA(ierr)
>>>> call DMView(dm, PETSC_VIEWER_STDOUT_WORLD, ierr) ; CHKERRA(ierr)
>>>> ! VTK viewer
>>>> call PetscViewerCreate(PETSC_COMM_WORLD, vtkViewer, ierr) ;
>>>> CHKERRA(ierr)
>>>> call PetscViewerSetType(vtkViewer, PETSCVIEWERHDF5, ierr) ;
>>>> CHKERRA(ierr)
>>>> call PetscViewerFileSetMode(vtkViewer, FILE_MODE_WRITE, ierr) ;
>>>> CHKERRA(ierr)
>>>> call PetscViewerFileSetName(vtkViewer, "debug_initmesh.h5", ierr) ;
>>>> CHKERRA(ierr)
>>>> call DMView(dm, vtkViewer, ierr) ; CHKERRA(ierr)
>>>> call PetscViewerDestroy(vtkViewer, ierr) ; CHKERRA(ierr)
>>>> end if
>>>> call PetscPrintf(PETSC_COMM_WORLD, "Done !\n", ierr) ; CHKERRA(ierr)
>>>> call PetscLogEventEnd(timer_initmesh, ierr); CHKERRA(ierr)
>>>> end subroutine initmesh
>>>> Thank you very much for your help !
>>>> Best regards,
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> Eng, MSc, PhD
>> Research Engineer
>> CEA/CESTA
>> 33114 LE BARP
>> Tel.: (+33)557046924
>> Mob.: (+33)611025322
>> Mail: thibault.bridelbertomeu at gmail.com
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210519/7c38c978/attachment-0001.html>
