[petsc-users] configure error
Barry Smith
bsmith at petsc.dev
Sat May 15 16:30:33 CDT 2021
Bitbucket is off-line. Do you need fortran stubs at this moment? If not use --with-fortran-interface=0
> On May 15, 2021, at 2:51 PM, Mark Adams <mfadams at lbl.gov> wrote:
> I can build a non-kokkos PETSc here (Cori/GPU) but I get this error with Kokkos.
> Any suggestions?
> Thanks,
> Mark
> ============================================================================================= ============================================================================================= Trying to download git://https://bitbucket.org/petsc/pkg-sowing.git <https://bitbucket.org/petsc/pkg-sowing.git> for SOWING ============================================================================================= ============================================================================================= Trying to download git://https://bitbucket.org/petsc/pkg-sowing.git <https://bitbucket.org/petsc/pkg-sowing.git> for SOWING ============================================================================================= ============================================================================================= Trying to download https://bitbucket.org/petsc/pkg-sowing/get/v1.1.26-p1.tar.gz <https://bitbucket.org/petsc/pkg-sowing/get/v1.1.26-p1.tar.gz> for SOWING ============================================================================================= *******************************************************************************
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> Error during download/extract/detection of SOWING:
> Unable to clone sowing
> Could not execute "['git clone https://bitbucket.org/petsc/pkg-sowing.git <https://bitbucket.org/petsc/pkg-sowing.git> /global/u2/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/externalpackages/git.sowing']":
> Cloning into '/global/u2/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/externalpackages/git.sowing'...
> fatal: unable to access 'https://bitbucket.org/petsc/pkg-sowing.git/ <https://bitbucket.org/petsc/pkg-sowing.git/>': The requested URL returned error: 503
> Unable to download package SOWING from: git://https://bitbucket.org/petsc/pkg-sowing.git <https://bitbucket.org/petsc/pkg-sowing.git>
> * If URL specified manually - perhaps there is a typo?
> * If your network is disconnected - please reconnect and rerun ./configure
> * Or perhaps you have a firewall blocking the download
> * You can run with --with-packages-download-dir=/adirectory and ./configure will instruct you what packages to download manually
> * or you can download the above URL manually, to /yourselectedlocation
> and use the configure option:
> --download-sowing=/yourselectedlocation
> file could not be opened successfully
> Downloaded package SOWING from: https://bitbucket.org/petsc/pkg-sowing/get/v1.1.26-p1.tar.gz <https://bitbucket.org/petsc/pkg-sowing/get/v1.1.26-p1.tar.gz> is not a tarball.
> [or installed python cannot process compressed files]
> * If you are behind a firewall - please fix your proxy and rerun ./configure
> For example at LANL you may need to set the environmental variable http_proxy (or HTTP_PROXY?) to http://proxyout.lanl.gov <http://proxyout.lanl.gov/>
> * or you can download the above URL manually, to /yourselectedlocation/v1.1.26-p1.tar.gz
> --download-sowing=/yourselectedlocation/v1.1.26-p1.tar.gz
> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210515/595032fa/attachment.html>
