[petsc-users] configure error
Mark Adams
mfadams at lbl.gov
Sat May 15 14:51:39 CDT 2021
I can build a non-kokkos PETSc here (Cori/GPU) but I get this error with
Kokkos.
Any suggestions?
Trying to
download git://https://bitbucket.org/petsc/pkg-sowing.git for SOWING
Trying to
Trying to
download https://bitbucket.org/petsc/pkg-sowing/get/v1.1.26-p1.tar.gz for
SOWING
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
details):
Error during download/extract/detection of SOWING:
Unable to clone sowing
Could not execute "['git clone https://bitbucket.org/petsc/pkg-sowing.git
/global/u2/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/externalpackages/git.sowing']":
Cloning into
'/global/u2/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/externalpackages/git.sowing'...
fatal: unable to access 'https://bitbucket.org/petsc/pkg-sowing.git/': The
requested URL returned error: 503
Unable to download package SOWING from: git://
* If URL specified manually - perhaps there is a typo?
* If your network is disconnected - please reconnect and rerun ./configure
* Or perhaps you have a firewall blocking the download
* You can run with --with-packages-download-dir=/adirectory and ./configure
will instruct you what packages to download manually
* or you can download the above URL manually, to /yourselectedlocation
and use the configure option:
--download-sowing=/yourselectedlocation
Cloning into
file could not be opened successfully
Downloaded package SOWING from:
https://bitbucket.org/petsc/pkg-sowing/get/v1.1.26-p1.tar.gz is not a
tarball.
[or installed python cannot process compressed files]
* If you are behind a firewall - please fix your proxy and rerun ./configure
For example at LANL you may need to set the environmental variable
http_proxy (or HTTP_PROXY?) to http://proxyout.lanl.gov
/yourselectedlocation/v1.1.26-p1.tar.gz
--download-sowing=/yourselectedlocation/v1.1.26-p1.tar.gz
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210515/ed20e24f/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210515/ed20e24f/attachment-0001.obj>
