[petsc-users] Binary format in real vs. complex scalar type configurations
Frederico Teixeira
teixeira at zmt.swiss
Wed May 12 08:14:13 CDT 2021
Matt, I initially had in mind to output the real and imaginary matrices separately, instead of the equivalent real matrix.
Pierre, if you think there is value on it, I can contribute an implementation of "Mat[Real,Imaginary]PartLoad()" as you suggested, instead of solving the problem on my side with Python etc..
Frederico.
To: "Pierre Jolivet" <pierre at joliv.et>
Cc: "Frederico Teixeira" <teixeira at zmt.swiss>, "petsc-users" <petsc-users at mcs.anl.gov>
Sent: Wednesday, May 12, 2021 1:35:55 PM
Subject: Re: [petsc-users] Binary format in real vs. complex scalar type configurations
On Wed, May 12, 2021 at 2:17 AM Pierre Jolivet < [ mailto:pierre at joliv.et | pierre at joliv.et ] > wrote:
BQ_BEGIN
On 11 May 2021, at 6:26 PM, Matthew Knepley < [ mailto:knepley at gmail.com | knepley at gmail.com ] > wrote:
On Tue, May 11, 2021 at 12:03 PM Pierre Jolivet < [ mailto:pierre at joliv.et | pierre at joliv.et ] > wrote:
BQ_BEGIN
Hello Frederico,
I’m not sure that’s possible.
Here is what I do, it makes me sick, but mixing precisions/scalar types with PETSc is difficult (crossing my fingers this will be better with future).
In MATLAB (after putting petsc/share/petsc/matlab in the path):
A = PetscBinaryRead('your_binary_mat_with_re+im.dat','complex',true); % scalar-type=complex
PetscBinaryWrite('re.dat',real(A)); % scalar-type=real
PetscBinaryWrite('im.dat',imag(A)); % scalar-type=real
So what you want to happen is that MatLoad() looks at the datatype, sees that it is complex and PetscScalar is real, and returns two matrices with the real and imaginary parts?
The hard part is that the MatLoad interface returns a single matrix.
BQ_END
There is Mat[Real,Imaginary]Part(), maybe there could be Mat[Real,Imaginary]PartLoad()?
It will be inefficient (complex Mat read twice in a very naive implementation), but functional and would not require tinkering with the options (but maybe you had something clear in mind).
Also, just for reference, [ https://gitlab.com/petsc/petsc/-/issues/901 | https://gitlab.com/petsc/petsc/-/issues/901 ] .
Frederico, as Barry wrote, it will work with Octave or Python. In fact, it will work in any code that does not include petsc.h or link to libpetsc.
If you want to stick to C, I think you could simply copy/paste the MatLoad_SeqAIJ_Binary() implementation [ https://www.mcs.anl.gov/petsc/petsc-current/src/mat/impls/aij/seq/aij.c.html#line4811 | https://www.mcs.anl.gov/petsc/petsc-3.15.0/src/mat/impls/aij/seq/aij.c.html#line4811 ] and replace PETSC_SCALAR line 4861 by PETSC_COMPLEX.
Then, as Matt wrote, instead of assembling a single Mat, assemble two Mats by splitting a->a in two PetscScalar arrays (remember that this is for your scalar-type=real configuration).
BQ_END
Should this make two matrices, or the equivalent real matrix?
/ R Q \
\ -Q R /
THanks,
Matt
BQ_BEGIN
Pierre
BQ_BEGIN
I guess we could have a flag that says what to do with complex numbers (read real, read imaginary, read norm, etc.)
and you could read it twice. Would that work?
Matt
BQ_BEGIN
Pierre
BQ_BEGIN
On 11 May 2021, at 3:30 PM, Frederico Teixeira < [ mailto:teixeira at zmt.swiss | teixeira at zmt.swiss ] > wrote:
Dear fellows,
I hope this message finds you safe and well.
I have a complex-valued matrix and its real/imaginary components in binary format . They were extracted from a solver that only works with "scalar-type=complex" configuration.
I am getting weird results when I load them into a small test program that's configured with "scalar-type=real", but I believe this is expected.
At the end of the day, I would like to have both real and imaginary components as real-valued matrices.
Is it possible to do it? I want to test preconditioners that are tailored for this sort of problem.
Frederico.
BQ_END
BQ_END
-- Norbert Wiener
[ http://www.cse.buffalo.edu/~knepley/ | https://www.cse.buffalo.edu/~knepley/ ]
BQ_END
BQ_END
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210512/7317f922/attachment.html>
