[petsc-users] Open MPI library version error
Matthew Knepley
knepley at gmail.com
Tue May 11 05:56:32 CDT 2021
On Tue, May 11, 2021 at 5:34 AM Daniel Stone <daniel.stone at opengosim.com>
wrote:
> Hi Pierre,
> I'm using 3.12.2, which is a bit old, but needed for the Pflotran version
> I'm using. It certainly predates that merge.
> Many thanks for pointing me to that merge - if nothing else I could now
> study that and try manually implementing
> it to see if it helps my situation.
You might just be able to
cd $PETSC_DIR
git cherry-pick 16dc8964ca763700383c940ec0bdd667c5da14cf
make
Matt
> Thanks,
> Daniel
> On Tue, May 11, 2021 at 10:28 AM Pierre Jolivet <pierre at joliv.et> wrote:
>> Hello Daniel,
>> Which PETSc version are you using?
>> I think this has been addressed there:
>> https://gitlab.com/petsc/petsc/-/merge_requests/3671
>> Thanks,
>> Pierre
>> On 11 May 2021, at 11:22 AM, Daniel Stone <daniel.stone at opengosim.com>
>> wrote:
>> Hello,
>> I have the following error:
>> PETSc Error --- Open MPI library version
>> FUJITSU MPI Library 4.0.0 (4.0.1fj4.0.0) does not match what PETSc was
>> compiled with 4.0, aborting
>> I have to configure and compile petsc in a cross compilation environment
>> and run it
>> in a different one. I'm trying to run src/snes/examples/tutorials/ex19 to
>> confirm things
>> are working.
>> It looks like this error could be down to some confusion with string
>> comparison
>> ("4.0.0" =/= "4.0"), or it could be some nightmare misalignment between
>> the two
>> environments I have to use, and/or my efforts to configure PETSc. I'm
>> trying to
>> determine which.
>> Is there some way to turn off this version checking, to see if it is just
>> a string comparison
>> error and maybe the rest of the program will run fine? Or could someone
>> point me to where
>> in the source code/configuration scripts these numbers are harvested and
>> this error is generated, so I can try to get a better idea about what is
>> going on?
>> Thanks,
>> Daniel Stone
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210511/7da813f4/attachment.html>
