[petsc-users] Open MPI library version error
Daniel Stone
daniel.stone at opengosim.com
Tue May 11 04:34:09 CDT 2021
Hi Pierre,
I'm using 3.12.2, which is a bit old, but needed for the Pflotran version
I'm using. It certainly predates that merge.
Many thanks for pointing me to that merge - if nothing else I could now
study that and try manually implementing
it to see if it helps my situation.
Daniel
On Tue, May 11, 2021 at 10:28 AM Pierre Jolivet <pierre at joliv.et> wrote:
> Hello Daniel,
> Which PETSc version are you using?
> I think this has been addressed there:
> https://gitlab.com/petsc/petsc/-/merge_requests/3671
> Thanks,
> Pierre
> On 11 May 2021, at 11:22 AM, Daniel Stone <daniel.stone at opengosim.com>
> wrote:
> Hello,
> I have the following error:
> PETSc Error --- Open MPI library version
> FUJITSU MPI Library 4.0.0 (4.0.1fj4.0.0) does not match what PETSc was
> compiled with 4.0, aborting
> I have to configure and compile petsc in a cross compilation environment
> and run it
> in a different one. I'm trying to run src/snes/examples/tutorials/ex19 to
> confirm things
> are working.
> It looks like this error could be down to some confusion with string
> comparison
> ("4.0.0" =/= "4.0"), or it could be some nightmare misalignment between
> the two
> environments I have to use, and/or my efforts to configure PETSc. I'm
> trying to
> determine which.
> Is there some way to turn off this version checking, to see if it is just
> a string comparison
> error and maybe the rest of the program will run fine? Or could someone
> point me to where
> in the source code/configuration scripts these numbers are harvested and
> this error is generated, so I can try to get a better idea about what is
> going on?
> Thanks,
> Daniel Stone
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210511/5d690de8/attachment.html>
