[petsc-users] Code speedup after upgrading
    Mohammad Gohardoust
    gohardoust at gmail.com
    Sun Mar 28 12:50:38 CDT 2021
Here is the plot of run time in old and new petsc using 1,2,4,8, and 16
CPUs (in logarithmic scale):
[image: Screenshot from 2021-03-28 10-48-56.png]
On Thu, Mar 25, 2021 at 12:51 PM Mohammad Gohardoust <gohardoust at gmail.com>
wrote:
> That's right, these loops also take roughly half time as well. If I am not
> mistaken, petsc (MatSetValue) is called after doing some calculations over
> each tetrahedral element.
> Thanks for your suggestion. I will try that and will post the results.
> Mohammad
> On Wed, Mar 24, 2021 at 3:23 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> On Wed, Mar 24, 2021 at 2:17 AM Mohammad Gohardoust <gohardoust at gmail.com>
>> wrote:
>>> So the code itself is a finite-element scheme and in stage 1 and 3 there
>>> are expensive loops over entire mesh elements which consume a lot of time.
>> So these expensive loops must also take half time with newer petsc?  And
>> these loops do not call petsc routines?
>> I think you can build two PETSc versions with the same configuration
>> options, then run your code with one MPI rank to see if there is a
>> difference.
>> If they give the same performance, then scale to 2, 4, ... ranks and see
>> what happens.
>>> Mohammad
>>> On Tue, Mar 23, 2021 at 6:08 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> In the new log, I saw
>>>> Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages ---  -- Message Lengths --  -- Reductions --
>>>>                         Avg     %Total     Avg     %Total    Count   %Total     Avg         %Total    Count   %Total
>>>>  0:      Main Stage: 5.4095e+00   2.3%  4.3700e+03   0.0%  4.764e+05   3.0%  3.135e+02        1.0%  2.244e+04  12.6% 1: Solute_Assembly: 1.3977e+02  59.4%  7.3353e+09   4.6%  3.263e+06  20.7%  1.278e+03       26.9%  1.059e+04   6.0%
>>>> But I didn't see any event in this stage had a cost close to 140s. What
>>>> happened?
>>>>  --- Event Stage 1: Solute_Assembly
>>>> BuildTwoSided       3531 1.0 2.8025e+0026.3 0.00e+00 0.0 3.6e+05 4.0e+00 3.5e+03  1  0  2  0  2   1  0 11  0 33     0
>>>> BuildTwoSidedF      3531 1.0 2.8678e+0013.2 0.00e+00 0.0 7.1e+05 3.6e+03 3.5e+03  1  0  5 17  2   1  0 22 62 33     0
>>>> VecScatterBegin     7062 1.0 7.1911e-02 1.9 0.00e+00 0.0 7.1e+05 3.5e+02 0.0e+00  0  0  5  2  0   0  0 22  6  0     0
>>>> VecScatterEnd       7062 1.0 2.1248e-01 3.0 1.60e+06 2.7 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    73
>>>> SFBcastOpBegin      3531 1.0 2.6516e-02 2.4 0.00e+00 0.0 3.6e+05 3.5e+02 0.0e+00  0  0  2  1  0   0  0 11  3  0     0
>>>> SFBcastOpEnd        3531 1.0 9.5041e-02 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>>> SFReduceBegin       3531 1.0 3.8955e-02 2.1 0.00e+00 0.0 3.6e+05 3.5e+02 0.0e+00  0  0  2  1  0   0  0 11  3  0     0
>>>> SFReduceEnd         3531 1.0 1.3791e-01 3.9 1.60e+06 2.7 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   112
>>>> SFPack              7062 1.0 6.5591e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>>> SFUnpack            7062 1.0 7.4186e-03 2.1 1.60e+06 2.7 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2080
>>>> MatAssemblyBegin    3531 1.0 4.7846e+00 1.1 0.00e+00 0.0 7.1e+05 3.6e+03 3.5e+03  2  0  5 17  2   3  0 22 62 33     0
>>>> MatAssemblyEnd      3531 1.0 1.5468e+00 2.7 1.68e+07 2.7 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  2  0  0  0   104
>>>> MatZeroEntries      3531 1.0 3.0998e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>>> --Junchao Zhang
>>>> On Tue, Mar 23, 2021 at 5:24 PM Mohammad Gohardoust <
>>>> gohardoust at gmail.com> wrote:
>>>>> Thanks Dave for your reply.
>>>>> For sure PETSc is awesome :D
>>>>> Yes, in both cases petsc was configured with --with-debugging=0 and
>>>>> fortunately I do have the old and new -log-veiw outputs which I attached.
>>>>> Best,
>>>>> Mohammad
>>>>> On Tue, Mar 23, 2021 at 1:37 AM Dave May <dave.mayhem23 at gmail.com>
>>>>> wrote:
>>>>>> Nice to hear!
>>>>>> The answer is simple, PETSc is awesome :)
>>>>>> Jokes aside, assuming both petsc builds were configured with
>>>>>> —with-debugging=0, I don’t think there is a definitive answer to your
>>>>>> question with the information you provided.
>>>>>> It could be as simple as one specific implementation you use was
>>>>>> improved between petsc releases. Not being an Ubuntu expert, the change
>>>>>> might be associated with using a different compiler, and or a more
>>>>>> efficient BLAS implementation (non threaded vs threaded). However I doubt
>>>>>> this is the origin of your 2x performance increase.
>>>>>> If you really want to understand where the performance improvement
>>>>>> originated from, you’d need to send to the email list the result of
>>>>>> -log_view from both the old and new versions, running the exact same
>>>>>> problem.
>>>>>> From that info, we can see what implementations in PETSc are being
>>>>>> used and where the time reduction is occurring. Knowing that, it should be
>>>>>> clearer to provide an explanation for it.
>>>>>> Thanks,
>>>>>> Dave
>>>>>> On Tue 23. Mar 2021 at 06:24, Mohammad Gohardoust <
>>>>>>> Hi,
>>>>>>> I am using a code which is based on petsc (and also parmetis).
>>>>>>> Recently I made the following changes and now the code is running about two
>>>>>>> times faster than before:
>>>>>>>    - Upgraded Ubuntu 18.04 to 20.04
>>>>>>>    - Upgraded petsc 3.13.4 to 3.14.5
>>>>>>>    - This time I installed parmetis and metis directly via petsc by
>>>>>>>    --download-parmetis --download-metis flags instead of installing them
>>>>>>>    separately and using --with-parmetis-include=... and
>>>>>>>    --with-parmetis-lib=... (the version of installed parmetis was 4.0.3 before)
>>>>>>> I was wondering what can possibly explain this speedup? Does anyone
>>>>>>> have any suggestions?
>>>>>>> Thanks,
>>>>>>> Mohammad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210328/e2cee650/attachment-0001.html>
Name: Screenshot from 2021-03-28 10-48-56.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210328/e2cee650/attachment-0001.png>
