[petsc-users] Code speedup after upgrading
Mohammad Gohardoust
gohardoust at gmail.com
Thu Mar 25 14:51:19 CDT 2021
That's right, these loops also take roughly half time as well. If I am not
mistaken, petsc (MatSetValue) is called after doing some calculations over
each tetrahedral element.
Thanks for your suggestion. I will try that and will post the results.
Mohammad
On Wed, Mar 24, 2021 at 3:23 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> On Wed, Mar 24, 2021 at 2:17 AM Mohammad Gohardoust <gohardoust at gmail.com>
> wrote:
>> So the code itself is a finite-element scheme and in stage 1 and 3 there
>> are expensive loops over entire mesh elements which consume a lot of time.
> So these expensive loops must also take half time with newer petsc? And
> these loops do not call petsc routines?
> I think you can build two PETSc versions with the same configuration
> options, then run your code with one MPI rank to see if there is a
> difference.
> If they give the same performance, then scale to 2, 4, ... ranks and see
> what happens.
>> Mohammad
>> On Tue, Mar 23, 2021 at 6:08 PM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> In the new log, I saw
>>> Summary of Stages: ----- Time ------ ----- Flop ------ --- Messages --- -- Message Lengths -- -- Reductions --
>>> Avg %Total Avg %Total Count %Total Avg %Total Count %Total
>>> 0: Main Stage: 5.4095e+00 2.3% 4.3700e+03 0.0% 4.764e+05 3.0% 3.135e+02 1.0% 2.244e+04 12.6% 1: Solute_Assembly: 1.3977e+02 59.4% 7.3353e+09 4.6% 3.263e+06 20.7% 1.278e+03 26.9% 1.059e+04 6.0%
>>> But I didn't see any event in this stage had a cost close to 140s. What
>>> happened?
>>> --- Event Stage 1: Solute_Assembly
>>> BuildTwoSided 3531 1.0 2.8025e+0026.3 0.00e+00 0.0 3.6e+05 4.0e+00 3.5e+03 1 0 2 0 2 1 0 11 0 33 0
>>> BuildTwoSidedF 3531 1.0 2.8678e+0013.2 0.00e+00 0.0 7.1e+05 3.6e+03 3.5e+03 1 0 5 17 2 1 0 22 62 33 0
>>> VecScatterBegin 7062 1.0 7.1911e-02 1.9 0.00e+00 0.0 7.1e+05 3.5e+02 0.0e+00 0 0 5 2 0 0 0 22 6 0 0
>>> VecScatterEnd 7062 1.0 2.1248e-01 3.0 1.60e+06 2.7 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 73
>>> SFBcastOpBegin 3531 1.0 2.6516e-02 2.4 0.00e+00 0.0 3.6e+05 3.5e+02 0.0e+00 0 0 2 1 0 0 0 11 3 0 0
>>> SFBcastOpEnd 3531 1.0 9.5041e-02 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> SFReduceBegin 3531 1.0 3.8955e-02 2.1 0.00e+00 0.0 3.6e+05 3.5e+02 0.0e+00 0 0 2 1 0 0 0 11 3 0 0
>>> SFReduceEnd 3531 1.0 1.3791e-01 3.9 1.60e+06 2.7 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 112
>>> SFPack 7062 1.0 6.5591e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> SFUnpack 7062 1.0 7.4186e-03 2.1 1.60e+06 2.7 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 2080
>>> MatAssemblyBegin 3531 1.0 4.7846e+00 1.1 0.00e+00 0.0 7.1e+05 3.6e+03 3.5e+03 2 0 5 17 2 3 0 22 62 33 0
>>> MatAssemblyEnd 3531 1.0 1.5468e+00 2.7 1.68e+07 2.7 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 104
>>> MatZeroEntries 3531 1.0 3.0998e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> --Junchao Zhang
>>> On Tue, Mar 23, 2021 at 5:24 PM Mohammad Gohardoust <
>>> gohardoust at gmail.com> wrote:
>>>> Thanks Dave for your reply.
>>>> For sure PETSc is awesome :D
>>>> Yes, in both cases petsc was configured with --with-debugging=0 and
>>>> fortunately I do have the old and new -log-veiw outputs which I attached.
>>>> Best,
>>>> Mohammad
>>>> On Tue, Mar 23, 2021 at 1:37 AM Dave May <dave.mayhem23 at gmail.com>
>>>> wrote:
>>>>> Nice to hear!
>>>>> The answer is simple, PETSc is awesome :)
>>>>> Jokes aside, assuming both petsc builds were configured with
>>>>> —with-debugging=0, I don’t think there is a definitive answer to your
>>>>> question with the information you provided.
>>>>> It could be as simple as one specific implementation you use was
>>>>> improved between petsc releases. Not being an Ubuntu expert, the change
>>>>> might be associated with using a different compiler, and or a more
>>>>> efficient BLAS implementation (non threaded vs threaded). However I doubt
>>>>> this is the origin of your 2x performance increase.
>>>>> If you really want to understand where the performance improvement
>>>>> originated from, you’d need to send to the email list the result of
>>>>> -log_view from both the old and new versions, running the exact same
>>>>> problem.
>>>>> From that info, we can see what implementations in PETSc are being
>>>>> used and where the time reduction is occurring. Knowing that, it should be
>>>>> clearer to provide an explanation for it.
>>>>> Thanks,
>>>>> Dave
>>>>> On Tue 23. Mar 2021 at 06:24, Mohammad Gohardoust <
>>>>>> Hi,
>>>>>> I am using a code which is based on petsc (and also parmetis).
>>>>>> Recently I made the following changes and now the code is running about two
>>>>>> times faster than before:
>>>>>> - Upgraded Ubuntu 18.04 to 20.04
>>>>>> - Upgraded petsc 3.13.4 to 3.14.5
>>>>>> - This time I installed parmetis and metis directly via petsc by
>>>>>> --download-parmetis --download-metis flags instead of installing them
>>>>>> separately and using --with-parmetis-include=... and
>>>>>> --with-parmetis-lib=... (the version of installed parmetis was 4.0.3 before)
>>>>>> I was wondering what can possibly explain this speedup? Does anyone
>>>>>> have any suggestions?
>>>>>> Thanks,
>>>>>> Mohammad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210325/d0acaa04/attachment.html>
