[petsc-users] Code speedup after upgrading
Mohammad Gohardoust
gohardoust at gmail.com
Wed Mar 24 02:24:01 CDT 2021
I built petsc 3.13.4 and got results similar to the old ones. I am
attaching the log-view output file here.
Mohammad
On Tue, Mar 23, 2021 at 6:49 PM Satish Balay via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> On Tue, 23 Mar 2021, Matthew Knepley wrote:
> > On Tue, Mar 23, 2021 at 9:08 PM Junchao Zhang <junchao.zhang at gmail.com>
> > wrote:
> > > In the new log, I saw
> > > Summary of Stages: ----- Time ------ ----- Flop ------ ---
> Messages --- -- Message Lengths -- -- Reductions --
> > > Avg %Total Avg %Total Count
> %Total Avg %Total Count %Total
> > > 0: Main Stage: 5.4095e+00 2.3% 4.3700e+03 0.0% 4.764e+05
> 3.0% 3.135e+02 1.0% 2.244e+04 12.6% 1: Solute_Assembly:
> 1.3977e+02 59.4% 7.3353e+09 4.6% 3.263e+06 20.7% 1.278e+03
> 26.9% 1.059e+04 6.0%
> > > But I didn't see any event in this stage had a cost close to 140s. What
> > > happened?
> > This is true, but all the PETSc operations are speeding up by a factor
> 2x.
> > It is hard to believe these were run on the same machine.
> > For example, VecScale speeds up!?! So it is not network, or
> optimizations.
> > I cannot explain this.
> * Using C compiler:
> /home/mohammad/Programs/petsc/arch-linux-c-opt/bin/mpicc -Wall
> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
> -fvisibility=hidden -Ofast -march=native -mtune=native
> Perhaps the CPU is new enough that '-march=native -mtune=native' makes a
> difference between '18.04 to 20.04'?
> You can build 3.13.4 again and see if the numbers are similar to the old
> or new numbers you currently have..
> * --download-fblaslapack --download-openblas
> You should use one or the other - but not both. Perhaps one is using
> openblas in thread mode [vs single thread for the other]?
> Satish
> > Matt
> > --- Event Stage 1: Solute_Assembly
> > > BuildTwoSided 3531 1.0 2.8025e+0026.3 0.00e+00 0.0 3.6e+05
> 4.0e+00 3.5e+03 1 0 2 0 2 1 0 11 0 33 0
> > > BuildTwoSidedF 3531 1.0 2.8678e+0013.2 0.00e+00 0.0 7.1e+05
> 3.6e+03 3.5e+03 1 0 5 17 2 1 0 22 62 33 0
> > > VecScatterBegin 7062 1.0 7.1911e-02 1.9 0.00e+00 0.0 7.1e+05
> 3.5e+02 0.0e+00 0 0 5 2 0 0 0 22 6 0 0
> > > VecScatterEnd 7062 1.0 2.1248e-01 3.0 1.60e+06 2.7 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 73
> > > SFBcastOpBegin 3531 1.0 2.6516e-02 2.4 0.00e+00 0.0 3.6e+05
> 3.5e+02 0.0e+00 0 0 2 1 0 0 0 11 3 0 0
> > > SFBcastOpEnd 3531 1.0 9.5041e-02 4.7 0.00e+00 0.0 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> > > SFReduceBegin 3531 1.0 3.8955e-02 2.1 0.00e+00 0.0 3.6e+05
> > > SFReduceEnd 3531 1.0 1.3791e-01 3.9 1.60e+06 2.7 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 112
> > > SFPack 7062 1.0 6.5591e-03 2.5 0.00e+00 0.0 0.0e+00
> > > SFUnpack 7062 1.0 7.4186e-03 2.1 1.60e+06 2.7 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 2080
> > > MatAssemblyBegin 3531 1.0 4.7846e+00 1.1 0.00e+00 0.0 7.1e+05
> 3.6e+03 3.5e+03 2 0 5 17 2 3 0 22 62 33 0
> > > MatAssemblyEnd 3531 1.0 1.5468e+00 2.7 1.68e+07 2.7 0.0e+00
> 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 104
> > > MatZeroEntries 3531 1.0 3.0998e-02 1.2 0.00e+00 0.0 0.0e+00
> > > --Junchao Zhang
> > > On Tue, Mar 23, 2021 at 5:24 PM Mohammad Gohardoust <
> gohardoust at gmail.com>
> > > wrote:
> > >> Thanks Dave for your reply.
> > >> For sure PETSc is awesome :D
> > >> Yes, in both cases petsc was configured with --with-debugging=0 and
> > >> fortunately I do have the old and new -log-veiw outputs which I
> attached.
> > >> Best,
> > >> Mohammad
> > >> On Tue, Mar 23, 2021 at 1:37 AM Dave May <dave.mayhem23 at gmail.com>
> wrote:
> > >>> Nice to hear!
> > >>> The answer is simple, PETSc is awesome :)
> > >>> Jokes aside, assuming both petsc builds were configured with
> > >>> —with-debugging=0, I don’t think there is a definitive answer to your
> > >>> question with the information you provided.
> > >>> It could be as simple as one specific implementation you use was
> > >>> improved between petsc releases. Not being an Ubuntu expert, the
> change
> > >>> might be associated with using a different compiler, and or a more
> > >>> efficient BLAS implementation (non threaded vs threaded). However I
> doubt
> > >>> this is the origin of your 2x performance increase.
> > >>> If you really want to understand where the performance improvement
> > >>> originated from, you’d need to send to the email list the result of
> > >>> -log_view from both the old and new versions, running the exact same
> > >>> problem.
> > >>> From that info, we can see what implementations in PETSc are being
> used
> > >>> and where the time reduction is occurring. Knowing that, it should be
> > >>> clearer to provide an explanation for it.
> > >>> Thanks,
> > >>> Dave
> > >>> On Tue 23. Mar 2021 at 06:24, Mohammad Gohardoust <
> > >>> wrote:
> > >>>> Hi,
> > >>>> I am using a code which is based on petsc (and also parmetis).
> Recently
> > >>>> I made the following changes and now the code is running about two
> times
> > >>>> faster than before:
> > >>>> - Upgraded Ubuntu 18.04 to 20.04
> > >>>> - Upgraded petsc 3.13.4 to 3.14.5
> > >>>> - This time I installed parmetis and metis directly via petsc by
> > >>>> --download-parmetis --download-metis flags instead of installing
> them
> > >>>> separately and using --with-parmetis-include=... and
> > >>>> --with-parmetis-lib=... (the version of installed parmetis was
> 4.0.3 before)
> > >>>> I was wondering what can possibly explain this speedup? Does anyone
> > >>>> have any suggestions?
> > >>>> Thanks,
> > >>>> Mohammad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210324/f00154f5/attachment-0001.html>
Type: text/x-python
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210324/f00154f5/attachment-0001.py>
