[petsc-users] Code speedup after upgrading
Satish Balay
balay at mcs.anl.gov
Tue Mar 23 20:49:16 CDT 2021
On Tue, 23 Mar 2021, Matthew Knepley wrote:
> On Tue, Mar 23, 2021 at 9:08 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> > In the new log, I saw
> > Summary of Stages: ----- Time ------ ----- Flop ------ --- Messages --- -- Message Lengths -- -- Reductions --
> > Avg %Total Avg %Total Count %Total Avg %Total Count %Total
> > 0: Main Stage: 5.4095e+00 2.3% 4.3700e+03 0.0% 4.764e+05 3.0% 3.135e+02 1.0% 2.244e+04 12.6% 1: Solute_Assembly: 1.3977e+02 59.4% 7.3353e+09 4.6% 3.263e+06 20.7% 1.278e+03 26.9% 1.059e+04 6.0%
> > But I didn't see any event in this stage had a cost close to 140s. What
> > happened?
> This is true, but all the PETSc operations are speeding up by a factor 2x.
> It is hard to believe these were run on the same machine.
> For example, VecScale speeds up!?! So it is not network, or optimizations.
> I cannot explain this.
* Using C compiler: /home/mohammad/Programs/petsc/arch-linux-c-opt/bin/mpicc -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -Ofast -march=native -mtune=native
Perhaps the CPU is new enough that '-march=native -mtune=native' makes a difference between '18.04 to 20.04'?
You can build 3.13.4 again and see if the numbers are similar to the old or new numbers you currently have..
* --download-fblaslapack --download-openblas
You should use one or the other - but not both. Perhaps one is using openblas in thread mode [vs single thread for the other]?
Satish
> Matt
> --- Event Stage 1: Solute_Assembly
> > BuildTwoSided 3531 1.0 2.8025e+0026.3 0.00e+00 0.0 3.6e+05 4.0e+00 3.5e+03 1 0 2 0 2 1 0 11 0 33 0
> > BuildTwoSidedF 3531 1.0 2.8678e+0013.2 0.00e+00 0.0 7.1e+05 3.6e+03 3.5e+03 1 0 5 17 2 1 0 22 62 33 0
> > VecScatterBegin 7062 1.0 7.1911e-02 1.9 0.00e+00 0.0 7.1e+05 3.5e+02 0.0e+00 0 0 5 2 0 0 0 22 6 0 0
> > VecScatterEnd 7062 1.0 2.1248e-01 3.0 1.60e+06 2.7 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 73
> > SFBcastOpBegin 3531 1.0 2.6516e-02 2.4 0.00e+00 0.0 3.6e+05 3.5e+02 0.0e+00 0 0 2 1 0 0 0 11 3 0 0
> > SFBcastOpEnd 3531 1.0 9.5041e-02 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> > SFReduceBegin 3531 1.0 3.8955e-02 2.1 0.00e+00 0.0 3.6e+05 3.5e+02 0.0e+00 0 0 2 1 0 0 0 11 3 0 0
> > SFReduceEnd 3531 1.0 1.3791e-01 3.9 1.60e+06 2.7 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 112
> > SFPack 7062 1.0 6.5591e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> > SFUnpack 7062 1.0 7.4186e-03 2.1 1.60e+06 2.7 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 2080
> > MatAssemblyBegin 3531 1.0 4.7846e+00 1.1 0.00e+00 0.0 7.1e+05 3.6e+03 3.5e+03 2 0 5 17 2 3 0 22 62 33 0
> > MatAssemblyEnd 3531 1.0 1.5468e+00 2.7 1.68e+07 2.7 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 104
> > MatZeroEntries 3531 1.0 3.0998e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> > --Junchao Zhang
> > On Tue, Mar 23, 2021 at 5:24 PM Mohammad Gohardoust <gohardoust at gmail.com>
> > wrote:
> >> Thanks Dave for your reply.
> >> For sure PETSc is awesome :D
> >> Yes, in both cases petsc was configured with --with-debugging=0 and
> >> fortunately I do have the old and new -log-veiw outputs which I attached.
> >> Best,
> >> Mohammad
> >> On Tue, Mar 23, 2021 at 1:37 AM Dave May <dave.mayhem23 at gmail.com> wrote:
> >>> Nice to hear!
> >>> The answer is simple, PETSc is awesome :)
> >>> Jokes aside, assuming both petsc builds were configured with
> >>> —with-debugging=0, I don’t think there is a definitive answer to your
> >>> question with the information you provided.
> >>> It could be as simple as one specific implementation you use was
> >>> improved between petsc releases. Not being an Ubuntu expert, the change
> >>> might be associated with using a different compiler, and or a more
> >>> efficient BLAS implementation (non threaded vs threaded). However I doubt
> >>> this is the origin of your 2x performance increase.
> >>> If you really want to understand where the performance improvement
> >>> originated from, you’d need to send to the email list the result of
> >>> -log_view from both the old and new versions, running the exact same
> >>> problem.
> >>> From that info, we can see what implementations in PETSc are being used
> >>> and where the time reduction is occurring. Knowing that, it should be
> >>> clearer to provide an explanation for it.
> >>> Thanks,
> >>> Dave
> >>> On Tue 23. Mar 2021 at 06:24, Mohammad Gohardoust <gohardoust at gmail.com>
> >>> wrote:
> >>>> Hi,
> >>>> I am using a code which is based on petsc (and also parmetis). Recently
> >>>> I made the following changes and now the code is running about two times
> >>>> faster than before:
> >>>> - Upgraded Ubuntu 18.04 to 20.04
> >>>> - Upgraded petsc 3.13.4 to 3.14.5
> >>>> - This time I installed parmetis and metis directly via petsc by
> >>>> --download-parmetis --download-metis flags instead of installing them
> >>>> separately and using --with-parmetis-include=... and
> >>>> --with-parmetis-lib=... (the version of installed parmetis was 4.0.3 before)
> >>>> I was wondering what can possibly explain this speedup? Does anyone
> >>>> have any suggestions?
> >>>> Thanks,
> >>>> Mohammad
