[petsc-users] MUMPS failure
Sanjay Govindjee
s_g at berkeley.edu
Tue Mar 23 13:20:37 CDT 2021
I agree. If you are mixing C and Fortran, everything is /nota bene. /It
is easy to miss argument mismatches.
-sanjay
On 3/23/21 11:04 AM, Barry Smith wrote:
> In a pure Fortran code using -fdefault-integer-8 is probably fine.
> But MUMPS is a mixture of Fortran and C code and PETSc uses MUMPs C
> interface. The -fdefault-integer-8 doesn't magically fix anything in
> the C parts of MUMPS. I also don't know about MPI calls and if they
> would need editing.
> I am not saying it is impossible to get it to work but one needs
> are to insure the C portions also switch to 64 bit integers in a
> consistent way. This may be all doable bit is not simply using
> -fdefault-integer-8 on MUMPS.
> Barry
>> On Mar 23, 2021, at 12:07 AM, Sanjay Govindjee <s_g at berkeley.edu
>> <mailto:s_g at berkeley.edu>> wrote:
>> Barry,
>> I am curious about your statement "does not work generically". If I
>> compile with -fdefault-integer-8,
>> I would assume that this produces objects/libraries that will use
>> 64bit integers. As long as I have not declared
>> explicit kind=4 integers, what else could go wrong.
>> -sanjay
>> PS: I am not advocating this as a great idea, but I am curious if
>> there or other obscure compiler level things that could go wrong.
>> On 3/22/21 8:53 PM, Barry Smith wrote:
>>>> On Mar 22, 2021, at 3:24 PM, Junchao Zhang <junchao.zhang at gmail.com
>>>> <mailto:junchao.zhang at gmail.com>> wrote:
>>>> On Mon, Mar 22, 2021 at 1:39 PM Barry Smith <bsmith at petsc.dev
>>>> <mailto:bsmith at petsc.dev>> wrote:
>>>> Version of PETSc and MUMPS? We fixed a bug in MUMPs a couple
>>>> years ago that produced error messages as below. Please confirm
>>>> you are using the latest PETSc and MUMPS.
>>>> You can run your production version with the option
>>>> -malloc_debug ; this will slow it down a bit but if there is
>>>> memory corruption it may detect it and indicate the problematic
>>>> error.
>>>> One also has to be careful about the size of the problem
>>>> passed to MUMPs since PETSc/MUMPs does not fully support using
>>>> all 64 bit integers. Is it only crashing for problems near 2
>>>> billion entries in the sparse matrix?
>>>> "problems near 2 billion entries"? I don't understand. Should not
>>>> be an issue if building petsc with 64-bit indices.
>>> MUMPS does not have proper support for 64 bit indices. It relies
>>> on add-hoc Fortran compiler command line options to support to
>>> converting integer to 64 bit integers and does not work generically.
>>> Yes, Fortran lovers have been doing this for 30 years inside their
>>> applications but it does not really work in a library environment.
>>> But then a big feature of Fortran is "who needs libraries, we just
>>> write all the code we need" (except Eispack,Linpack,LAPACK :=-).
>>>> valgrind is the gold standard for detecting memory
>>>> corruption.
>>>> Barry
>>>>> On Mar 22, 2021, at 12:56 PM, Chris Hewson <chris at resfrac.com
>>>>> <mailto:chris at resfrac.com>> wrote:
>>>>> Hi All,
>>>>> I have been having a problem with MUMPS randomly crashing in
>>>>> our program and causing the entire program to crash. I am
>>>>> compiling in -O2 optimization mode and using --download-mumps
>>>>> etc. to compile PETSc. If I rerun the program, 95%+ of the
>>>>> time I can't reproduce the error. It seems to be a similar
>>>>> issue to this thread:
>>>>> https://lists.mcs.anl.gov/pipermail/petsc-users/2018-October/036372.html
>>>>> <https://lists.mcs.anl.gov/pipermail/petsc-users/2018-October/036372.html>
>>>>> Similar to the resolution there I am going to try and increase
>>>>> icntl_14 and see if that resolves the issue. Any other
>>>>> thoughts on this?
>>>>> Thanks,
>>>>> *Chris Hewson*
>>>>> Senior Reservoir Simulation Engineer
>>>>> ResFrac
>>>>> +1.587.575.9792
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210323/8c6c3396/attachment.html>
